[openSmoke] libOpenSMOKE
Like Tree133Likes
Old   May 28, 2013, 06:48
danz is on a distinguished road
Hi Tobi!
I have my flamelet library(using CANTERA) now and I want to interpolate the temperatue over the mixture fraction and stoichiomertic scalar dissipation rate. My question is how do you interpolate the mixture fraction grid since you have different discretization of the flamelets (One have more discretization points near the exctinction).
In libOpenSmoke, I can just see the stoichiomertic scalar dissipation rate interpolation.
Thanks.
Best,
Danz
danz is offline   Reply With Quote
Old   May 28, 2013, 13:42
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Originally Posted by danz View Post
Hi Tobi!
Thanks.
Best,
Danz
This is a area-weighted interpolation function! Have a look into the flamelet basic cpp file!
Tobi is offline   Reply With Quote
Old   June 8, 2013, 06:59
Default flameletPisoFoam
  #183
Tobi's Avatar
Tobias Holzmann
Hi all,
I am very happy to tell everybody that I build the flameletPisoFoam solver.
The solver is running and in the attachment are the first results.
At the moment I am running the Sandia-Flame tutorial and hope that the case is running without problems.
If everything is working fine, I ll make a validation with the measurement data files and let you know how accurate the solver is working.
Regards,
Happy Tobi
MPJ, immortality and babakflame like this.
Old   June 8, 2013, 09:28
Default Update
  #184
Tobi's Avatar
Tobias Holzmann
Hi all,
I think its done.
The solver is running without problems (attachment).
I ll let the testcase run until I get a steady-state solution and after that I am going to test the mixture fraction variance transport equation. At the beginning I had problems with that so I used the algebraic equation at the moment but it seems to work
Next steps:
  • Calculating till 1 second
  • Recalculating till 1 second with mixture fraction transport equation
  • Start calculation from steady-state solution (flameletSimpleFoam)
  • Compare steady and unsteady solution
  • Compare unsteady solution with measurements
  • Clean and upload the new solver + tutorial to the 2.2.x flamelet model on github
Tobi
Old   June 8, 2013, 14:02
Bobby
babakflame is on a distinguished road
Hi Tobi
Congratulations.
Can I ask how did you solve the problem of division by zero in pressure?
Bobi
babakflame is offline   Reply With Quote
Old   June 11, 2013, 07:30
Tobi's Avatar
Tobias Holzmann
Hi all,
  • flameletPisoFoam solver runs stable and gives better residual as the flameletSimpleFoam solver
  • Since yesterday I am working on the Validation of that solver and the comparision with the SIMPLE algo too. There is a Problem with my flameletSimpleFoam solver,... I dont know why the Validation with that solver is so bad (I did that Validation three times, with 1.7x, 2.1.x and 2.2.x )
    I think I made a mistake yesterday (too tired)
  • I ll upload the flameletPisoFoam solver hence everything is working without Problems
@Bobi:
I am not sure why I always get Problems building the transient solver. The only change is the PISO algo instead of the PIMPLE.
But at least I can not say if the solver works correct, since I don t get the validation.
Old   June 11, 2013, 07:37
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
whree's the solver?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 11, 2013, 10:54
Tobi's Avatar
Tobias Holzmann
I ll upload the solver here: github.com/shor-ty/flameletModel 2.2.x
But first of all I have to be sure that the solver is working correct. It makes no sence to share this solver without any Argument that it s calculating the values correct.
Tobi
immortality likes this.
Old   June 12, 2013, 18:03
Tobi's Avatar
Tobias Holzmann
Hi all,
first results are avaiable.
I made the validation with the following profiles:
- axial
- xD = 20
- xD = 40
- xD = 60
The solutions are very good. It seems that in the steady state flame area the flameltSimpleFoam gives a more accurate solution than the PISO foam. In some graphics you could see that the piso foam solver is getting a more accurate result.
At least I would say that both solvers are working fine at free-stream velocity flames.
If someone has an validation case for a complexed (twisted?) flow please let me know.
In a few days I ll upload everything.
Good night.
Old   June 15, 2013, 13:18
Default First Update - Validation
  #190
Tobi's Avatar
Tobias Holzmann
Hi all,
see attachment!
Further information are comming.
Old   June 16, 2013, 16:49
Tobi's Avatar
Tobias Holzmann
Hi all,
here we go:
https://github.com/shor-ty/flameletModel-2.2.x
I updated my github and now it contains the new flameletPisoFoam solver + tutorial. Hope that I upated my github correct (not tested).
If you have problems - let me know.
Here is the validation:
http://www.holzmann-cfd.de/validatio...dationPiso.pdf
2014-12-04 - Warning: The git repository was deleted. For the latest mirror repository, go to post #407
Old   June 16, 2013, 17:08
Ehsan
how much is its volume?my browser is continuing to download.now is 25meg!
Old   June 17, 2013, 01:59
Tobi's Avatar
Tobias Holzmann
Its volume is 222 MB ... thats coused by the flamelet libs.
I ll try to link it to decrease the volume.
Tobi
Old   June 17, 2013, 08:48
Ehsan
wow,then that was good that I discontinued it!
Old   June 17, 2013, 13:04
Tobi's Avatar
Tobias Holzmann
Do you have a limitation of traffic ?
I updated my github and now the tool is about 77MB
Hope that is better - thanks for your hint!
Tobi
Old   June 30, 2013, 07:37
Bobby
Greetings to all
Does anybody else experienced problem with downloading Tobi code?
My Internet is 1 Mb/s ; however my download speed for pisofoamflamelet code is just 1 Kb/s
For God's sake, WHY?????
@Tobi
Thanks buddy for all you have done for flamelet researchers.
Did you take a look at my code?
Regards
Bobi
Old   June 30, 2013, 07:49
Retired Super Moderator
Bruno Santos
Greetings to all!
Given Bobi's predicament, I've created a mirror repository at http://repo.or.cz/w/flameletModel-2.2.x.git
To git clone from it, use either one of the following commands:
  • Code:
    git clone git://repo.or.cz/flameletModel-2.2.x.git
  • Code:
    git clone http://repo.or.cz/r/flameletModel-2.2.x.git
For those who don't have git, use one of the snapshot links from here: http://repo.or.cz/w/flameletModel-2.2.x.git/tree
Best regards,
Bruno
2014-12-04 - Warning: This repository was deleted. For the latest mirror repository, go to post #414
Tobi and babakflame like this.
Old   June 30, 2013, 12:25
Bobby
Many Thanks to Bruno
Old   July 2, 2013, 07:45
Tobi's Avatar
Tobias Holzmann
I ll have a look at that Problem today evening!
I was offline for a while (many things to do )
Old   July 6, 2013, 02:00
Bobby
Hi Tobi
During Compiling flamelet model2.2.x , I confronted this error:
babak@babak-System:~/OpenFOAM/babak-2.2.x/flameletModel-2.2.x/applications/solvers/combustion/flameletSimpleFoam$ wmake
options:16:12: warning: backslash and newline separated by space [enabled by default]
linux64GccDPOpt/options:6: *** missing separator.  Stop.
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/babak/OpenFOAM/babak-2.2.x/flameletModel-2.2.x/applications/solvers/combustion/flameletSimpleFoam
Would you please help me
The libraries compiled successfully however it seems there is problem with both solvers compilation.
Regards
Numerical treatment of the source term in combustion equations Tobi Main CFD Forum 37 September 15, 2020 14:42
[openSmoke] flameletSmoke + new ODESolver (by Alberto Cuoci) Tobi OpenFOAM Community Contributions 1 November 21, 2017 19:24
Unsteady solver with Flamelet Model (libOpenSMOKE) francesco_capuano OpenFOAM Running, Solving & CFD 11 November 26, 2013 05:50
LibOpenSmoke, getting the species in ParaFoam Christoph_84 OpenFOAM 1 May 31, 2012 15:42
