[swak4Foam] log velocity profile with groovyBC - syntax
Like Tree5Likes
Old   December 8, 2020, 06:22
Kabir Shariff
Kbshariff is on a distinguished road
Hi, thank you Bernhard for the observation, I have modified the groovyBC as follows; I define the variables a and u_f as scalars and i use the *normal() to make the expression a vector. My main concern now is pos().z,
    inlet
     type            groovyBC;
     variables "a=0.197;u_f=0.00787;n=1e-5;";
     valueExpression "(2.5*u_f*log((u_f*pos().z)/(n))+a)*normal()";
My main concern now is the defination of z as pos().z, when i run the case i get this error. Its no clear for me what is the source of error.
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p      tolerance 0.001
    field U      tolerance 0.0001
    field "(k|epsilon)"  tolerance 0.0001
Reading field p
Reading field U
--> FOAM Warning :
    From groovyBCFvPatchField<Type>::groovyBCFvPatchField(const fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict)
    in file groovyBCFvPatchField.C at line 141
    No value defined for U on inlet therefore using the internal field next to the patch
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.11;
    C3              0;
    sigmak          1;
No MRF models present
Creating finite volume options from "constant/fvOptions"
Selecting finite volume options type actuationDiskSource
    Source: disk1
    - selecting cells using cellSet actuationDisk1
    - selected 1036 cell(s) with volume 9.78444444444e-05
    - selecting cells using points
    - creating actuation disk zone: disk1
    - force computation method: Froude
Starting time loop
Time = 1
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib64/libpthread.so.0
#3  log in /lib64/libm.so.6
#4  Foam::log(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
#5  Foam::log(Foam::UList<double> const&) at ??:?
#6  parserPatch::PatchValueExpressionParser::parse() at ??:?
#7  Foam::PatchValueExpressionDriver::parseInternal(int) at ??:?
#8  Foam::CommonValueExpressionDriver::parse(Foam::exprString const&, Foam::word const&) at ??:?
#9  Foam::tmp<Foam::Field<Foam::Vector<double> > > Foam::CommonValueExpressionDriver::evaluate<Foam::Vector<double> >(Foam::exprString const&, bool) at ??:?
#10  Foam::groovyBCFvPatchField<Foam::Vector<double> >::updateCoeffs() at ??:?
#11  Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:?
#12  ? at ??:?
#13  ? at ??:?
#14  __libc_start_main in /lib64/libc.so.6
#15  ? at ??:?
Floating point exception
Thank you for your time and support.
Kbshariff is offline   Reply With Quote
Old   December 8, 2020, 07:01
Kabir Shariff
i attached herewith files perusal
0/U
boundaryField
    inlet
     type            groovyBC;
    	outlet
       			type            zeroGradient;
	top
			type		slip;
	bottom
			type		slip;
	walls
			type		slip;
"proc.*"
    type            processor;
0/p
internalField   uniform 0;
boundaryField
	inlet
        		type           zeroGradient;
    	outlet
       			type           fixedValue;
			value		uniform 0;
	top
			type		slip;
	bottom
			type		slip;
	walls
			type		slip;
"proc.*"
    type            processor;
0/eps
internalField   uniform 1.821e-5;  //4.851e-5;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 1.821e-5;  //4.851e-5;
    outlet
        type            zeroGradient;
    top
        type            epsilonWallFunction;
    bottom
    walls
"proc.*"
    type            processor;
0/k
internalField   uniform 0.00001756;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0.00001756;
    outlet
        type            zeroGradient;
    top
        type            kqRWallFunction;
    bottom
    walls
"proc.*"
    type            processor;
Old   December 8, 2020, 18:47
Assistant Moderator
Bernhard Gschaider
    inlet
     type            groovyBC;
Create time
Reading field p
Reading field U
--> FOAM Warning :
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.11;
    C3              0;
    sigmak          1;
    Source: disk1
Starting time loop
Time = 1
#12  ? at ??:?
#13  ? at ??:?
#15  ? at ??:?
Seems that the log function is used outside the range on which it is defined (either 0 or negative). swak4Foam can't protect you from that. Of course you can always use max to make sure that you're in the comfort zone of the function: log(max(1e-10,x)) with x being the function you want to use. But of course you should think WHY is this outside of the comfort zone (because it might be a problem in your setup)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 9, 2020, 16:36
Kabir Shariff
Thank you Bernhard,
Yes, the log function was used with wrong z position. Initially, z coordinates ranges from - 0.15 to 0.15. Calculating log of negative is mathematically wrong. I have now change the coordinates to 0 to 0.3.
The simulation now works well. Thank you once again.
groovybc, logarithmic, syntax, velocity profile
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 04:44
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
[swak4Foam] Problem with fully developed velocity profile groovyBC in 2D axi-sym mesh harshad88 OpenFOAM Community Contributions 7 July 24, 2014 15:28
[swak4Foam] groovyBC error: velocity profile (2D) >> what's wrong? vitorspadeto OpenFOAM Community Contributions 4 June 19, 2014 16:31
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 18, 2009 00:36
