[swak4Foam] log velocity profile with groovyBC - syntax
Like Tree5Likes
Old   May 14, 2013, 11:48
Lamia
LamiaOF2.1 is on a distinguished road
when I did what you said, to add "-normal()*profile(pos().y)"it gives me that message
Create time
Create mesh for time = 0
Reading field p
Reading field U
--> FOAM FATAL IO ERROR:
attempt to read beyond EOF
file: /home/lamia/Bureau/CASE/0/U::boundaryField::inlet::lookuptables at line 38.
From function ITstream::read(token&)
in file db/IOstreams/Tstreams/ITstream.C at line 83.
FOAM exiting
why?
LamiaOF2.1 is offline   Reply With Quote
Old   May 14, 2013, 11:53
Lamia
it's okey, I could fix it
Old   May 15, 2013, 12:42
Default tabular data with groovyBc
  #23
Lamia
Hi
if I use this program as condition of my inlet :
boundaryField
inlet
type groovyBC;
fields
U yn
lookuptables (
name profile;
outOfBounds clamp;
fileName "$FOAM_CASE/profile.data";
valueExpression "-normal()*profile(pos().U)";
and the attached file is the following:
(0.00000 0.00000)
(0.14580 0.00001)
(0.19580 0.00002)
(0.22580 0.00003)
(0.25580 0.00004)
(0.27580 0.00005)
(0.29580 0.00006)
(0.30580 0.00007)
(0.31580 0.00008)
(0.32580 0.00009)
(0.33580 0.00010)
(0.34580 0.00011)
(0.35580 0.00012)
(0.36580 0.00013)
(0.37580 0.00014)
(0.38580 0.00015)
(0.39580 0.00017)
(0.40580 0.00018)
(0.41580 0.00020)
(0.42580 0.00021)
(0.43580 0.00023)
(0.44580 0.00025)
(0.45580 0.00027)
(0.46580 0.00029)
(0.48580 0.00033)
(0.47580 0.00033)
(0.49580 0.00035)
(0.50580 0.00038)
(0.51580 0.00040)
(0.52580 0.00043)
(0.53580 0.00046)
(0.54580 0.00048)
(0.55580 0.00051)
(0.56580 0.00055)
(0.57580 0.00058)
(0.58580 0.00061)
(0.59580 0.00065)
(0.60580 0.00068)
(0.61580 0.00072)
(0.62580 0.00076)
(0.63580 0.00080)
(0.64580 0.00085)
(0.65580 0.00089)
(0.66580 0.00094)
(0.67580 0.00098)
(0.68580 0.00103)
(0.69580 0.00108)
(0.70580 0.00114)
(0.71580 0.00119)
(0.72580 0.00125)
(0.73580 0.00130)
(0.74580 0.00136)
(0.75580 0.00143)
(0.76580 0.00149)
(0.77580 0.00155)
(0.78580 0.00162)
(0.79580 0.00169)
(0.80580 0.00176)
(0.81580 0.00184)
(0.82580 0.00191)
(0.83580 0.00199)
(0.84580 0.00207)
(0.85580 0.00215)
(0.86580 0.00224)
(0.87580 0.00232)
(0.88580 0.00241)
(0.89580 0.00250)
(0.90580 0.00260)
(0.91580 0.00269)
(0.92580 0.00279)
(0.93580 0.00289)
(0.94580 0.00300)
(0.95580 0.00310)
(0.96580 0.00321)
(0.97580 0.00332)
(0.98580 0.00344)
(0.99580 0.00356)
(1.00580 0.00368)
(1.01580 0.00380)
(1.02580 0.00392)
(1.03580 0.00405)
(1.04580 0.00418)
(1.05580 0.00432)
(1.06580 0.00445)
(1.07580 0.00459)
(1.08580 0.00474)
(1.09580 0.00488)
(1.10580 0.00503)
(1.11580 0.00518)
(1.12580 0.00534)
(1.13580 0.00550)
(1.14580 0.00566)
(1.15580 0.00583)
(1.16580 0.00600)
(1.17580 0.00617)
(1.18580 0.00634)
(1.19580 0.00652)
(1.20580 0.00670)
(1.21580 0.00689)
(1.22580 0.00708)
(1.23580 0.00727)
(1.24580 0.00747)
(1.25580 0.00767)
(1.26580 0.00788)
(1.27580 0.00808)
(1.28580 0.00830)
(1.29580 0.00851)
(1.30580 0.00873)
(1.31580 0.00895)
(1.32580 0.00918)
(1.33580 0.00941)
(1.34580 0.00965)
(1.35580 0.00989)
(1.36580 0.01013)
(1.37580 0.01038)
(1.38580 0.01063)
(1.39580 0.01089)
(1.40580 0.01115)
(1.41580 0.01142)
(1.42580 0.01169)
(1.43580 0.01196)
(1.44580 0.01224)
(1.45580 0.01252)
(1.46580 0.01281)
(1.47580 0.01310)
(1.48580 0.01340)
(1.49580 0.01370)
(1.50580 0.01400)
(1.51580 0.01431)
(1.52580 0.01463)
(1.53580 0.01495)
(1.54580 0.01527)
(1.55580 0.01560)
(1.56580 0.01594)
(1.57580 0.01628)
(1.58580 0.01662)
(1.59580 0.01697)
(1.60580 0.01733)
(1.61580 0.01769)
(1.62580 0.01805)
(1.63580 0.01843)
(1.64580 0.01880)
(1.65580 0.01918)
(1.66580 0.01957)
(1.67580 0.01996)
(1.68580 0.02036)
(1.69580 0.02076)
(1.70580 0.02117)
(1.71580 0.02158)
(1.72580 0.02200)
(1.73580 0.02243)
(1.74580 0.02286)
(1.75580 0.02330)
(1.76580 0.02374)
(1.77580 0.02419)
(1.78580 0.02464)
(1.79580 0.02510)
(1.80580 0.02557)
(1.81580 0.02604)
(1.82580 0.02652)
(1.83580 0.02701)
(1.84580 0.02750)
(1.85580 0.02799)
(1.86580 0.02850)
(1.87580 0.02901)
(1.88580 0.02952)
(1.89580 0.03004)
(1.90580 0.03057)
(1.91580 0.03111)
(1.92580 0.03165)
(1.93580 0.03220)
(1.94580 0.03275)
(1.95580 0.03331)
(1.96580 0.03388)
(1.97580 0.03445)
(1.98580 0.03504)
(1.99580 0.03562)
(2.00580 0.03620)
(2.01580 0.03682)
(2.02580 0.03743)
(2.03580 0.03805)
(2.04580 0.03867)
(2.05580 0.03930)
(2.06580 0.03994)
(2.07580 0.04058)
(2.08580 0.04123)
(2.09580 0.04189)
(2.10580 0.04256)
(2.11580 0.04323)
(2.12580 0.04391)
(2.13580 0.04460)
(2.14580 0.04530)
(2.15580 0.04600)
(2.16580 0.04671)
(2.17580 0.04743)
(2.18580 0.04816)
(2.19580 0.04889)
(2.20580 0.04963)
(2.21580 0.05038)
(2.22580 0.05114)
(2.23580 0.05190)
(2.24580 0.05268)
(2.25580 0.05346)
(2.26580 0.05425)
(2.27580 0.05505)
(2.28580 0.05585)
(2.29580 0.05667)
(2.30580 0.05749)
(2.31580 0.05832)
(2.32580 0.05916)
(2.33580 0.06001)
(2.34580 0.06086)
(2.35580 0.06173)
(2.36580 0.06260)
(2.37580 0.06348)
(2.38580 0.06437)
(2.39580 0.06527)
(2.40580 0.06618)
(2.41580 0.06709)
(2.42580 0.06802)
(2.43580 0.06895)
(2.44580 0.06989)
(2.45580 0.07084)
(2.46580 0.07181)
(2.47580 0.07278)
(2.48580 0.07375)
(2.49580 0.07474)
(2.50580 0.07574)
(2.51580 0.07675)
(2.52580 0.07776)
(2.53580 0.07879)
(2.54580 0.07982)
(2.55580 0.08087)
(2.56580 0.08192)
(2.57580 0.08298)
(2.58580 0.08405)
(2.59580 0.08514)
(2.60580 0.08623)
(2.61580 0.08733)
(2.62580 0.08844)
(2.63580 0.08956)
(2.64580 0.09069)
(2.65580 0.09184)
(2.66580 0.09299)
(2.67580 0.09415)
(2.68580 0.09532)
(2.69580 0.09650)
(2.70580 0.09769)
(2.71580 0.09889)
(2.72580 0.10011)
(2.73580 0.10133)
(2.74580 0.10256)
(2.75580 0.10380)
(2.76580 0.10506)
(2.77580 0.10632)
(2.78580 0.10760)
(2.79580 0.10888)
(2.80580 0.11018)
(2.81580 0.11149)
(2.82580 0.11280)
(2.83580 0.11413)
(2.84580 0.11547)
(2.85580 0.11682)
(2.86580 0.11818)
(2.87580 0.11956)
(2.88580 0.12094)
(2.89580 0.12233)
(2.90580 0.12374)
(2.91580 0.12516)
(2.92580 0.12659)
(2.93580 0.12803)
(2.94580 0.12948)
(2.95580 0.13094)
(2.96580 0.13241)
(2.97580 0.13390)
(2.98580 0.13540)
(2.99580 0.13690)
(3.00580 0.13842)
(3.01580 0.13996)
(3.02580 0.14150)
(3.03580 0.14306)
(3.04580 0.14463)
(3.05580 0.14621)
(3.06580 0.14780)
(3.07580 0.14940)
(3.08580 0.15102)
(3.09580 0.15265)
(3.10580 0.15429)
(3.11580 0.15594)
(3.12580 0.15760)
(3.13580 0.15928)
(3.14580 0.16097)
(3.15580 0.16267)
(3.16580 0.16439)
(3.17580 0.16612)
(3.18580 0.16786)
(3.19580 0.16961)
(3.20580 0.17137)
(3.21580 0.17315)
(3.22580 0.17494)
(3.23580 0.17675)
(3.24580 0.17856)
(3.25580 0.18039)
(3.26580 0.18224)
(3.27580 0.18409)
(3.28580 0.18596)
(3.29580 0.18784)
(3.30580 0.18974)
(3.31580 0.19165)
(3.32580 0.19357)
(3.33580 0.19551)
(3.34580 0.19746)
(3.35580 0.19942)
(3.36580 0.20140)
(3.37580 0.20339)
(3.38580 0.20539)
(3.39580 0.20741)
(3.40580 0.20944)
(3.41580 0.21148)
(3.42580 0.21354)
(3.43580 0.21562)
(3.44580 0.21770)
(3.45580 0.21980)
(3.46580 0.22192)
(3.47580 0.22405)
(3.48580 0.22619)
(3.49580 0.22835)
(3.50580 0.23052)
(3.51580 0.23271)
(3.52580 0.23491)
(3.53580 0.23713)
(3.54580 0.23936)
(3.55580 0.24160)
(3.56580 0.24386)
(3.57580 0.24614)
(3.58580 0.24842)
(3.59580 0.25073)
(3.60580 0.25305)
(3.61580 0.25538)
(3.62580 0.25773)
(3.63580 0.26009)
(3.64580 0.26247)
(3.65580 0.26486)
(3.66580 0.26727)
(3.67580 0.26970)
(3.68580 0.27214)
(3.69580 0.27459)
(3.70580 0.27706)
(3.71580 0.27955)
(3.72580 0.28205)
(3.73580 0.28457)
(3.74580 0.28710)
(3.75580 0.28965)
(3.76580 0.29221)
(3.77580 0.29479)
(3.78580 0.29739)
(3.79580 0.30000)
(3.81580 0.30527)
(3.82580 0.30793)
(3.83580 0.31061)
(3.84580 0.31330)
(3.85580 0.31601)
(3.86580 0.31873)
(3.87580 0.32147)
(3.88580 0.32423)
(3.89580 0.32700)
(3.90580 0.32979)
(3.91580 0.33260)
(3.92580 0.33542)
(3.93580 0.33827)
(3.94580 0.34112)
(3.95580 0.34400)
(3.96580 0.34689)
(3.97580 0.34979)
(3.98580 0.35272)
(3.99580 0.35566)
(4.00580 0.35862)
(4.01580 0.36160)
(4.02580 0.36459)
(4.03580 0.36760)
(4.05580 0.37367)
(4.15580 0.37673)
(4.15580 0.38291)
(4.15580 0.38603)
(4.15580 0.38916)
(4.15580 0.39231)
(4.15580 0.39548)
(4.15580 0.39866)
(4.15580 0.40187)
(4.15580 0.45000)
(4.15580 0.50000)
(4.15580 0.55000)
(4.15580 0.65000)
(4.15580 0.70000)
(4.15580 0.75000)
(4.15580 0.80000)
(4.15580 0.85000)
(4.15580 0.87500)
knowing that the first column is the velocity U while the second represents y
and I get this message:
Create time
Reading field p
Reading field U
--> FOAM FATAL ERROR:
out-of-order value: 0.4758 at index 25
From function Foam::interpolationTable<Type>::checkOrder() const
in file /opt/openfoam211/src/OpenFOAM/lnInclude/interpolationTable.C at line 226.
FOAM exiting
why can I do??
please I need to understand what's wrong
Old   May 15, 2013, 17:50
Assistant Moderator
Bernhard Gschaider
Originally Posted by LamiaOF2.1 View Post
Hi
boundaryField
inlet
type groovyBC;
fields
U yn
lookuptables (
name profile;
outOfBounds clamp;
(0.00000 0.00000)
(0.14580 0.00001)
<snip>
(0.45580 0.00027)
(0.46580 0.00029)
(0.48580 0.00033)
(0.47580 0.00033)
(0.49580 0.00035)
(0.50580 0.00038)
<snipY
(4.15580 0.65000)
(4.15580 0.70000)
(4.15580 0.75000)
(4.15580 0.80000)
(4.15580 0.85000)
(4.15580 0.87500)
Create time
Reading field p
Reading field U
FOAM exiting
why can I do??
I think it is rather clear if you look at your data file: the point 0.4758 is out of sequence (it is smaller than the point before it). Clean that up. You'll probably also have a problem in the end where you have multiple values for 4.15580
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 24, 2013, 16:13
Default attempt to read beyond EOF (groovyBC)
  #25
Clément_G's Avatar
Clément Gouriou
Clément_G is on a distinguished road
Good afternoon,
I'm on OF 2.2 and I'm trying to put velocity inlet boundary conditions. It's a profile of velocity 2D saved in a data file named "test_profile.data" with 2 columns of datas: 1) U (m/s) and 2) y (altitude in meter) looks like that:
(0.0 0)
(5.3 10)
(5.9 20)
(6.4 30)
(7.0 40)
(7.9 50)
(8.0 60)
I have reproduced all the syntax you've proposed but the compilation doesn't work and I don't understand the reason of the error:
"--> FOAM FATAL IO ERROR:
file: /home/cgouriou/OpenFOAM/cgouriou-2.2.0/run/tutorials/ejemplo/LIPC/LIPC_2D_refined/lipc4/0/U.boundaryField.inlet.lookuptables at line 55.
FOAM exiting"
The syntax of my velocity file U is like that:
boundaryField
inlet
type groovyBC;
fields
y U
lookuptables
name test_profile;
outOfBounds clamp;
fileName "$FOAM_CASE/test_profile.data";
valueExpression "vector(velocity(pos().y),0,0)";
I've simplified at the maximum my case in order to get a value of velocity at each point of the mesh, but it still doesn't run. Is that possible to put a velocity profile with less points that the mesh contains?
Could you give me some ideas, please?
thank you for you attention
Clément
Clément_G is offline   Reply With Quote
Old   June 24, 2013, 19:43
Assistant Moderator
Bernhard Gschaider
Originally Posted by Clément_G View Post
Good afternoon,
(0.0 0)
(5.3 10)
(5.9 20)
(6.4 30)
(7.0 40)
(7.9 50)
(8.0 60)
FOAM exiting"
boundaryField
inlet
type groovyBC;
fields
y U
lookuptables
name test_profile;
outOfBounds clamp;
Clément
"read beyond EOF" usually is because the user made an error during editing (for instance forgotten ; ). In this concrete case the problem probably is that valueExpression is in the list of the lookuptables (that is probably the line 55 the error message is referring to. It is good practice to go to the reported line in the file and go upwards from it and have a look at the file
Old   June 24, 2013, 20:19
Default answer
  #27
Clément_G's Avatar
Clément Gouriou
Thank you very much for your quick answer.
That was right I removed the "ValueExpression" from the the "lookuptables" and changed the "vector(velocity(pos().y),0,0)" by "-normal()*test_profile(pos().y)" and it ran perfectly!
boundaryField
inlet
type groovyBC;
fields
U y
lookuptables
name test_profile;
outOfBounds clamp;
valueExpression "-normal()*test_profile(pos().y)";
Thank you so much
sincerly
Clément
Old   June 26, 2013, 12:51
Default inlet boundary condition for U and k
  #28
Clément_G's Avatar
Clément Gouriou
Good morning,
I have succeded in writing velocity inlet boundary conditions thanks to you help on this forum, but now I'd like to add turbulence boundary conditions. I have choosen a "simpleFoam" solveur (turbulence model komegaSST) and just have change the inlet conditions for k (0.org/k) in the same way that I did it for the file 0.org/U (see below).
"#include "include/initialConditions"
dimensions [0 2 -2 0 0 0 0];
internalField uniform $turbulentKE;
boundaryField
//- Set patchGroups for constraint patches
#include "${WM_PROJECT_DIR}/etc/caseDicts/setConstraintTypes"
//- Define inlet conditions
//#include "include/fixedInlet"
inlet
type groovyBC;
fields
U y
lookuptables
name profile_tke_inv;
outOfBounds clamp;
fileName "$FOAM_CASE/profile_tke_inv.data";
valueExpression "vector(profile_tke_inv(pos().y),0,0)";
//"-normal()*profile_tke_inv(pos().y)";
atmosphere
type symmetryPlane;
outlet
type inletOutlet;
inletValue $internalField;
value $internalField;
ground
type kqRWallFunction;
frontAndBack
type empty;
Morover I have adapted the file include/initialConditions like that:
"//flowVelocity (6 0 0);
pressure 0;
turbulentKE 0;
turbulentOmega 1.78;
#inputMode merge
Finally when I look and the log.simplefoam file I get this error message:
"Create time
Reading field p
Reading field U
--> FOAM Warning :
From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(c onst fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict)
in file groovyBCFvPatchField.C at line 131
No value defined for U on inlet therefore using 400{(0 0 0)}
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
--> FOAM Warning :
No value defined for k on inlet therefore using 400{0}
bounding k, min: 0 max: 0 average: 0
kOmegaSSTCoeffs
alphaK1 0.85034;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.85616;
gamma1 0.5532;
gamma2 0.4403;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
Creating finite volume options
No finite volume options present
SIMPLE: no convergence criteria found. Calculations will run for 500 steps.
Starting time loop
Time = 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0549726, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0741149, No Iterations 7
time step continuity errors : sum local = 0.0787424, global = -0.00602472, cumulative = -0.00602472
smoothSolver: Solving for omega, Initial residual = 0.967767, Final residual = 0.0353544, No Iterations 2
The expected return type scalar is different from the stored result type "vector"
From function tmp<Field<Type> > ExpressionResult::getResult()
in file ../swak4FoamParsers/lnInclude/ExpressionResultI.H at line 238.
FOAM exiting"
I think that the problem comes from my variable "k" but I have no idea where I can change the type of the stored result, as indicated in the error message.
Thank you for your help
sincerly
Clément
Old   June 26, 2013, 13:57
Assistant Moderator
Bernhard Gschaider
Please use CODE for output and configuration files. It makes the post MUCH more readable
Good morning,
Starting time loop
Time = 1
FOAM exiting"
sincerly
Clément
k is a volScalarField. Your expression
returns a vector. That is what swak complains about. What you probably wanted to say was
valueExpression "profile_tke_inv(pos().y)";
Old   June 26, 2013, 15:23
  #30
Clément_G's Avatar
Clément Gouriou
Hello Bernhard,
Thank you very much an other time for your quick answer.
I will do that now.
Is was exactly what I meant and which was wrong. Now my two profile run "quasi" perfectly.
But I still have an other question: my velocity profile has the right form but the values are wrong (around 10 times higher), and I don't understand how can I get velocity value of 60m/s when my velocity inlet profile has a maximum value of only 8m/s! In which part of my program do I have to change something, please?
Here are my screenshot of the velocity field and the correspondant velocity profile obtained from my velocity inlet conditions.
Thank you for your advices very helpful.
Clément
Old   June 26, 2013, 19:14
Assistant Moderator
Bernhard Gschaider
Hello Bernhard,
I will do that now.
Clément
No idea (and I'm not even sure which side you set the profile on. Also you only show the absolute value of the velocity. I've got no idea in which direction it goes)
But my first guess would be the boundary-conditions.
Old   June 27, 2013, 13:33
Default boundary layer error value
  #32
Clément_G's Avatar
Clément Gouriou
Good morning Bernhard,
I understand. In fact the flow goes from the left side at a maximum highspeed of 8m/s.
I'm facing 3 problems that I present to you:
1) When you see at the velocity profile the trend is very good except at the boundary (60m of height) where we can see an absurd horizontal line. I've looked for the reasons of appearance of this abberation but I still haven't found.
Here are my boundary conditions:
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type    groovyBC;
    fields
      U y
    lookuptables
            name profile_reel_U;
            outOfBounds clamp;
            fileName "$FOAM_CASE/profile_reel_U.data";
      valueExpression "vector(profile_reel_U(pos().y),0,0)";
    //"-normal()*profile_reel_U(pos().y)";
    atmosphere
        type            symmetryPlane;
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    ground
        type            fixedValue;
        value           uniform (0 0 0);
    frontAndBack
        type            empty;
and here is the velocity inlet list:
((0.000000 0.000000)
(0.530444 0.250000)
(1.027199 0.500000)
(1.491419 0.750000)
(1.924262 1.000000)
(2.326884 1.250000)
(2.700441 1.500000)
(3.046090 1.750000)
(3.364986 2.000000)
(3.658287 2.250000)
(3.927147 2.500000)
(4.172725 2.750000)
(4.396175 3.000000)
(4.598654 3.250000)
(4.781319 3.500000)
(4.945325 3.750000)
(5.091830 4.000000)
(5.221988 4.250000)
(5.336958 4.500000)
(5.437894 4.750000)
(5.525954 5.000000)
(5.602293 5.250000)
(5.668067 5.500000)
(5.724434 5.750000)
(5.772549 6.000000)
(5.813569 6.250000)
(5.848650 6.500000)
(5.878948 6.750000)
(5.905619 7.000000)
(5.929820 7.250000)
(5.952707 7.500000)
(5.975243 7.750000)
(5.997618 8.000000)
(6.019825 8.250000)
(6.041863 8.500000)
(6.063725 8.750000)
(6.085408 9.000000)
(6.106907 9.250000)
(6.128219 9.500000)
(6.149338 9.750000)
(6.170260 10.000000)
(6.190982 10.250000)
(6.211498 10.500000)
(6.231805 10.750000)
(6.251898 11.000000)
(6.271772 11.250000)
(6.291424 11.500000)
(6.310849 11.750000)
(6.330042 12.000000)
(6.349001 12.250000)
(6.367719 12.500000)
(6.386193 12.750000)
(6.404418 13.000000)
(6.422390 13.250000)
(6.440106 13.500000)
(6.457563 13.750000)
(6.474764 14.000000)
(6.491714 14.250000)
(6.508415 14.500000)
(6.524870 14.750000)
(6.541083 15.000000)
(6.557057 15.250000)
(6.572795 15.500000)
(6.588301 15.750000)
(6.603577 16.000000)
(6.618627 16.250000)
(6.633455 16.500000)
(6.648063 16.750000)
(6.662454 17.000000)
(6.676633 17.250000)
(6.690602 17.500000)
(6.704364 17.750000)
(6.717923 18.000000)
(6.731282 18.250000)
(6.744444 18.500000)
(6.757413 18.750000)
(6.770191 19.000000)
(6.782782 19.250000)
(6.795189 19.500000)
(6.807416 19.750000)
(6.819466 20.000000)
(6.831341 20.250000)
(6.843046 20.500000)
(6.854583 20.750000)
(6.865956 21.000000)
(6.877168 21.250000)
(6.888222 21.500000)
(6.899122 21.750000)
(6.909870 22.000000)
(6.920470 22.250000)
(6.930926 22.500000)
(6.941239 22.750000)
(6.951415 23.000000)
(6.961455 23.250000)
(6.971364 23.500000)
(6.981144 23.750000)
(6.990799 24.000000)
(7.000332 24.250000)
(7.009746 24.500000)
(7.019044 24.750000)
(7.028230 25.000000)
(7.037307 25.250000)
(7.046279 25.500000)
(7.055147 25.750000)
(7.063917 26.000000)
(7.072590 26.250000)
(7.081171 26.500000)
(7.089662 26.750000)
(7.098067 27.000000)
(7.106388 27.250000)
(7.114630 27.500000)
(7.122796 27.750000)
(7.130888 28.000000)
(7.138910 28.250000)
(7.146865 28.500000)
(7.154757 28.750000)
(7.162588 29.000000)
(7.170362 29.250000)
(7.178083 29.500000)
(7.185753 29.750000)
(7.193375 30.000000)
(7.200954 30.250000)
(7.208492 30.500000)
(7.215992 30.750000)
(7.223458 31.000000)
(7.230893 31.250000)
(7.238300 31.500000)
(7.245682 31.750000)
(7.253044 32.000000)
(7.260387 32.250000)
(7.267715 32.500000)
(7.275032 32.750000)
(7.282341 33.000000)
(7.289644 33.250000)
(7.296946 33.500000)
(7.304249 33.750000)
(7.311557 34.000000)
(7.318872 34.250000)
(7.326199 34.500000)
(7.333541 34.750000)
(7.340900 35.000000)
(7.348280 35.250000)
(7.355684 35.500000)
(7.363116 35.750000)
(7.370578 36.000000)
(7.378075 36.250000)
(7.385608 36.500000)
(7.393182 36.750000)
(7.400800 37.000000)
(7.408465 37.250000)
(7.416179 37.500000)
(7.423948 37.750000)
(7.431773 38.000000)
(7.439658 38.250000)
(7.447606 38.500000)
(7.455620 38.750000)
(7.463704 39.000000)
(7.471862 39.250000)
(7.480095 39.500000)
(7.488408 39.750000)
(7.496803 40.000000)
(7.505285 40.250000)
(7.513856 40.500000)
(7.522519 40.750000)
(7.531277 41.000000)
(7.540135 41.250000)
(7.549095 41.500000)
(7.558161 41.750000)
(7.567335 42.000000)
(7.576621 42.250000)
(7.586022 42.500000)
(7.595542 42.750000)
(7.605183 43.000000)
(7.614949 43.250000)
(7.624844 43.500000)
(7.634870 43.750000)
(7.645030 44.000000)
(7.655329 44.250000)
(7.665769 44.500000)
(7.676353 44.750000)
(7.687085 45.000000)
(7.697968 45.250000)
(7.709005 45.500000)
(7.720199 45.750000)
(7.731554 46.000000)
(7.743073 46.250000)
(7.754760 46.500000)
(7.766616 46.750000)
(7.778647 47.000000)
(7.790854 47.250000)
(7.803242 47.500000)
(7.815813 47.750000)
(7.828571 48.000000)
(7.841518 48.250000)
(7.854659 48.500000)
(7.867996 48.750000)
(7.881533 49.000000)
(7.895273 49.250000)
(7.909219 49.500000)
(7.923375 49.750000)
(7.937743 50.000000)
(8      60)
2) Moreover I don't understand why at the initial time (t=0), we don't see anything in the velocity field ("all is blue"), although I have put my inlet velocity profile. (see attached files U_t0_x0.png and the correspondant curve_U_t0_x0.png and it's exactly the same for the "tke" profile at t=0)
3) Finally, when I see the film of my simulation at x=0 (entry patch), I don't understand why the inlet velocity profile changes. I thought that it would always be the same because it's constant boundary condition (see last attached file named curve_U_t5_x0.png). Do you have an idea to explain these changing?
I hope my explainations are enough clear.
Thank you,
Sincerly
Clément
potentialFoam likes this.
Old   June 27, 2013, 15:40
Assistant Moderator
Bernhard Gschaider
(0.530444 0.250000)
(1.027199 0.500000)
(1.491419 0.750000)
(1.924262 1.000000)
(2.326884 1.250000)
<snip>
(8      60)
Is this some kind of test? To test my patience? Did it never occur to you that the problem might be that simply you and OF disagree on which column has which meaning? USUALLY in tables the value you look up with is in the left column, the resulting value in the right. So what is happening here is that at height 8 you've got the velocity 60 which stays constant from then on. Please. Next time think "I have a maximum velocity 60 in my results .... where did I see 60 before .... ah. That is the maximum height of my geometry ...."
That is because paraview does not "understand groovyBC". It uses the value-entry to display the data. Which is 0 at t=0
Old   June 27, 2013, 20:35
Default groovyBC 2D resolved
  #34
Clément_G's Avatar
Clément Gouriou
Sorry it wasn't a patience's test, I just hadn't found the solution because I believed that the part like that
fields
      U y
could specify the signification of each column, that's why I had given up that hypothesis.
Clear explainations.
And finally thank you for the time you took to analyse my problem, it runs perfectly now.
Sincerly
Clément
Old   June 28, 2013, 05:50
Assistant Moderator
Bernhard Gschaider
fields
      U y
I don't think that this fields-entry does anything (that is only used in the simpleFunctionObjects AFAIK and groovyBC ignores it)
Good
Old   October 28, 2015, 12:41
Natan Zawadzki
heling is on a distinguished road
Hello Bernhard,
I've got just one question regarding the Clement's case: since the input data is a discrete velocity field, an interpolation might be required for grid points between the specified values. Does the OpenFOAM interpolate automatically (if yes, which interpolation method is set as default?) or user has to specify the inlet data exactly at boundary points?
Many thanks!
Edit1: I've tried it out, and ideed, OF seems to interpolate the prescribed discrete velocity profile on the boundary. However, I still couldn't find any information on the interpolation method that has been applied. It would be great, if you could provide some info. Thx!
heling is offline   Reply With Quote
Old   July 6, 2018, 09:33
Default Remark: Warning at initialising groovyBC
  #37
Peter
potentialFoam is on a distinguished road
Thanks for all the hints - I found this thread really helpful! That's why I would like to add a warning where I spend some hours on:
During the first iteration/ time step with a groovyBC-boundary Foam printed:
--> FOAM Warning :
    From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(const fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict)
    No value defined for nuTilda on INLET therefore using the internal field next to the patch
(Here for a SpalartAllmaras model with specified nuTilda at the inlet.) I took this warning for a sign that groovyBC was not working - wrong! It works perfectly fine as one can see after the first iteration in paraFoam e.g.
So thanks a lot again for the wonderful tool!
potentialFoam is offline   Reply With Quote
Old   July 7, 2018, 10:57
Assistant Moderator
Bernhard Gschaider
--> FOAM Warning :
Sorry that this warning message is confusing. This really only happens during initialization. groovyBC can't do any calclations because some of the fields it uses in valueExpression might not yet be in memory (which would lead to the death of the simulation) and there is no "value" defined on the patch. Then it can only "guess" the value. 0 is not a good idea (think of T. or p in a compressible case) so it falls back to using the internal field (which should have a sensible value). But that happens only at the start. All other time-steps work as expected. I only added this warning because in some esoteric cases it could be a problem and the warning would help
Old   December 7, 2020, 12:23
Default logarithmatic velocity inlet
  #39
Kabir Shariff
Kbshariff is on a distinguished road
Hi foamers,
I would to specify logaritmatic velocity at the inlet of the form
U=2.5Um*ln*(z*Um/nu) + A
NB/ nu is kinematic viscosity, A and Um defined in variables
My groovyBC look like
    inlet
     type            groovyBC;
     variables "zp=pos().z;a=0.197*normal();u_f=0.00787*normal();";
     valueExpression "2.5*u_f*log((zp*u_f)/(nu))+a";
I have the error when i run the case file.
swak4Foam: Allocating new repository for sampledGlobalVariables
 Parser Error for driver PatchValueExpressionDriver at "1.26" :"syntax error, unexpected ')'"
Context of the error:
- From dictionary: /home/2016014/kshari01/OpenFOAM/v2006/run/case0_vs/0/U.boundaryField.inlet
  Evaluating expression "2.5*u_f*log((zp*u_f)/(nu))+a"
    From parsingValue
    in file lnInclude/CommonValueExpressionDriverI.H at line 1258.
FOAM exiting
Kindly assist please
I notice the error is within the log function because i tried a case constant value in the argument and the case was fine.
How do I define the log correctly in terms of position and a constant value nu from the transport properties.
Thank you
Kabir
Kbshariff is offline   Reply With Quote
Old   December 7, 2020, 18:12
Assistant Moderator
Bernhard Gschaider
Originally Posted by Kbshariff View Post
Hi foamers,
    inlet
     type            groovyBC;
    From parsingValue
FOAM exiting
Thank you
Kabir
This is swak4Foams obscure way or saying "I beg your pardon: how is the logarithm of a vector defined?". You multiply the vector u_f with a scalar and divide it by a scalar. Result is a scalar. swak4Foam expects a scalar as the argument for the log-function. So it says "Surely Kabir meant to do something to the vector to give me the scalar that I so desperately need. But I see a ')' which means I won't get the scalar. This makes me sad and I will therefore kill the program" (swak4Foam acts like a spoilt child if it doesn't get what it wants. It learned that from OpenFOAM itself)
My guess is that you wanted to use the absolute value of u_f (with the mag-function) or a component of it
groovybc, logarithmic, syntax, velocity profile
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 04:44
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
[swak4Foam] Problem with fully developed velocity profile groovyBC in 2D axi-sym mesh harshad88 OpenFOAM Community Contributions 7 July 24, 2014 15:28
[swak4Foam] groovyBC error: velocity profile (2D) >> what's wrong? vitorspadeto OpenFOAM Community Contributions 4 June 19, 2014 16:31
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 18, 2009 00:36
