#21 |
Massachusetts
Rep Power: 13 ![]() |
Step 1 of the openFoam installation cleared up the 'mpicc' messages
A fresh install solved GUI problem. When I try to import .stl surface - discretizersetup shuts down ben@ben-MS-7760:~/OpenFOAM/discretizer$ ./discretizersetup.sh /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/icoFoam /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/simpleFoam /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/rhoPimpleFoam /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/interFoam /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/solidDisplacementFoam /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam /home/ben/OpenFOAM/OpenFOAM-2.1.1/bin/paraFoam /home/ben/OpenFOAM/ThirdParty-2.1.1/platforms/linux64Gcc/paraview-3.12.0/bin/paraview /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/foamToVTK /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/transformPoints /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/fluentMeshToFoam /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/foamMeshToFluent /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/renumberMesh /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/setFields /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/snappyHexMesh /home/ben/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh execute from /home/ben/OpenFOAM/discretizer/discretizer200, dialogs from /home/ben/OpenFOAM/discretizer/discretizer200 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 currentsize 2 discretizersetup.rb:977:in `to_i': NaN (FloatDomainError) from discretizersetup.rb:977:in `write_uniform_blockMesh' from discretizersetup.rb:959:in `onCmdOpenStl' from discretizersetup.rb:2662:in `run' from discretizersetup.rb:2662 Ben Last edited by Ben Chapman; October 27, 2013 at 12:48. |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Hi Ben,
Is it an ASCII or a binary STL file? Because I think Discretizer is not able to handle binary STL files. Best regards, Bruno
#23 |
Rep Power: 0 ![]() |
I'm a german mechanical engineering student, and i want to install discretizer but i have several problems with the installation. For the first problem i have a solution. But now i have a new problem. 1. Problem - solved: ~/OpenFOAM/discretizer$ sudo gem install fxruby Fetching: fxruby-1.6.27.gem (100%) Building native extensions. This could take a while... ERROR: Error installing fxruby: ERROR: Failed to build gem native extension. ... Solution: You have to remove this code shred '-Werror=format-security' from this file '/usr/lib/ruby/1.9.1/x86_64-linux/rbconfig.rb'. There are two or three lines with this option. Now 2. problem -solved: :~/OpenFoam/discretizer$ ./discretizer.sh /usr/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in `require': cannot load such file -- tableio (LoadError) from /usr/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in `require' from discretizer.rb:54:in `<main>' Solution: You have to edit the file 'discretizer.rb'. The files which are in the same directory than discretizer.rb will be loaded in the skript, but a change in ruby will produce a failure. Because the system wide 'gem' librarys will be loaded, since ruby 1.8.x, with the command require. So you have to change the command 'require' to 'require_relative' for the files which are in the same directory than 'discretizer.rb'. That's a change in the ruby language code! I've changed this lines: require 'benchmark' require 'zlib' require_relative 'tableio' require_relative 'objectlist' #require "glmeshbox" #require 'infoline' require_relative 'dialogs' require 'mathn' require_relative 'methods' require_relative 'cross' require_relative 'mesh' But now i have a new problem again! ![]() If i tipe in the command line 'ruby discretizer.rb', it gives me this back: /var/lib/gems/1.9.1/gems/fxruby-1.6.28/lib/fox16/exceptions_for_fxerror.rb:14: [BUG] Segmentation fault ruby 1.9.3p194 (2012-04-20 revision 35410) [x86_64-linux] I'm using Ubuntu 13.04 with OpenFoam 2.2.2. I'm still using the SolidWorks CFD, but i need OpenFoam for parallel computing! Maybe someone can help me? kind regards, mk2 Last edited by mk2; November 17, 2013 at 04:54. |
#24 |
Bruno Santos
Greetings mk2 and welcome to the forum!
And many thanks for the solution you gave for step #1, because that helped pass the biggest problem that was occuring on Ubuntu 12.10 and above! I've finished testing the instructions adapted for Ubuntu 13.04 and made them available here: http://openfoamwiki.net/index.php/In...u#Ubuntu_13.04 Please let me know if they work for you as well! Best regards, Bruno edit: Finished writing and testing for Ubuntu 12.10 as well: http://openfoamwiki.net/index.php/In...u#Ubuntu_12.10 edit2: And Ubuntu 13.10: http://openfoamwiki.net/index.php/In...u#Ubuntu_13.10
Last edited by wyldckat; November 17, 2013 at 06:43. Reason: see "edit:" and "edit 2" |
#25 |
Nat
I really would love to try out Discretizer so I would like to install it on Ubuntu 14.04. Should I go with the installation guide for 13.10 and hope for the best? I have two versions of OpenFoam installed (of211 and of230). Will that cause problem for me? Should I do something special during installation? Any help would be appreciated! Thanks |
#26 | |
Anil Kunwar
Rep Power: 12 ![]() |
If you are using two versions of OpenFoam, i guess you are using "Aliases" for these two versions. Typing Alias name of a given version of openfoam or given software in terminal means that the environment of the corresponding software is called. However, these two versions of openfoam are installed separately. In my guess, you need to install discretizer twice - by going to folder of each OpenFOAM versions. Yours Sincerely Anil Kunwar |
#27 |
Fynn
Rep Power: 10 ![]() |
Hi Nat9,
Have you had any success in installing discretizer in ubuntu 14.04? I also want to use it in ubuntu 14.04 with openFoam 4.x but my installation fails already with the download of ruby 1.8. Or has anybody else successfully gone through that installation recently? cheers, Fynn |
discretizer, installation, meshing, openfoam, snow leopard |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
Install OF 1.6.ext on Arch based distribution | miro2000 | OpenFOAM Installation | 4 | October 9, 2013 14:39 |
Runing cavity on Discretizer | RTom | OpenFOAM Pre-Processing | 3 | June 25, 2013 01:11 |
[Discretizer] Discretizer | Rajshekar | OpenFOAM Community Contributions | 2 | November 23, 2010 11:13 |
