Mattia de\' Michieli Vitturi
Rep Power: 17 ![]() |
I'm trying to use GroovyBC to impose a variable temperature profile on the walls of a cylinder. I've started to learn something about GroovyBC from the OpenFOAMWiki page. I don't understand if I should view with paraview the new BC also at the time 0 or only at the following time steps (>0). This is what the wiki says: "There are four demo-cases included in the repository in a folder Demos. All of these cases only require a blockMesh." So it seems that it is not required to run the solver but blockMesh should be sufficient to check if it is working (at time 0?), but at time 0, for the first Demo, I have a constant value at the inlet and not a parabolic one. Is it correct? Thank you Mattia |
[swak4Foam] groovyBC for oscillatory flow | liybzd | OpenFOAM Community Contributions | 5 | November 12, 2018 07:53 |
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC | zanilu70 | OpenFOAM Community Contributions | 4 | December 13, 2016 06:46 |
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam | dani2702 | OpenFOAM Community Contributions | 0 | November 17, 2016 03:30 |
[swak4Foam] groovyBC issue - k and epsilon | sagnikmazumdar | OpenFOAM Community Contributions | 24 | March 1, 2015 07:16 |
[swak4Foam] groovyBC and Eqn.setReference() | benk | OpenFOAM Community Contributions | 3 | June 2, 2011 08:49 |
