[swak4Foam] funkySetFields - how to set two "zones"? |
#21 |
Gijsbert Wierink
Rep Power: 18 ![]() |
Ah ok, I understand
![]() It seems your expression and condition work, because I tested it on the icoFoam cavity case by setting an alpha1 to 1 for x <= 0.05 (took a bigger value than you to see something clearly) and it worked. Half the domain was set to 1 and the rest to 0. The command I used was Code:
funkySetFields -field alpha1 -expression "52.96281*(pow(pos().z,0.262054))+273" -time 0 -keepPatches -condition "pos().x <= 0.05"
Regards, Gijs |
#22 |
G B
Rep Power: 16 ![]() |
I think i found my error in the line you just wrote. I have conditionS instead of condition... I mustve read that wiki 1000 times and i still manage to make that kind of mistake. Thanks for you help Gijs and sorry for all this trouble! Ill post it anyways
#23 |
Gijsbert Wierink
Aha great! Yeah, typos can be a lot of fun
Regards, Gijs |
#24 |
G B
Yes, it worked perfectly. Thanks again! And im sorry about all this commotion. I'll be back with more problems soon enough, hopefully not as silly as this one turned out to be (however, im glad it was something silly and of my own fault! :P).
#25 |
Gijsbert Wierink
Haha, no worries, **** happens. I'm glad it works now!
Regards, Gijs |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 08:00 |
set BC mass-flow-inlet via UDF and via GUI perform different result | sawa25 | FLUENT | 1 | February 25, 2015 00:51 |
error with icoDyMFOAM; how to set face extrusion zones | kiyono | OpenFOAM | 1 | June 17, 2011 15:07 |
[swak4Foam] Problem with funkySetFields: How to set field on patch? | DanielPT | OpenFOAM Community Contributions | 4 | May 6, 2011 09:45 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
