[swak4Foam] Non-normal inflow with groovyBC
Old   March 30, 2010, 23:12
Default Non-normal inflow with groovyBC
bjr
Ben Racine
bjr is on a distinguished road
Send a message via AIM to bjr Send a message via Skype™ to bjr
Anybody have any general guidance on this? I am trying to work my way up to 45 degree flow... but starting with this 80/10 ratio. I've got it working without groovyBC, but does anybody know how the formulation would need to be changed if using Groovy... my current attempt looks like this...
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (80 10 0);
boundaryField
front
type groovyBC;
variables "zp=pts().z;minZ=min(zp);maxZ=max(zp);para=-pow(pos().z/0.390667,0.13)*normal();";
valueExpression "(1+0.00005*sin(500*time()))*para";
value uniform (80 10 0);
inlet
type groovyBC;
back
type inletOutlet;
inletValue uniform (0 0 0);
outlet
type inletOutlet;
lowerWall
type fixedValue;
value uniform (0 0 0);
OBJECT_patch0
type fixedValue;
upperWall
type slip;
bjr is offline   Reply With Quote
Old   March 31, 2010, 16:24
Default Getting there... this works
bjr
Ben Racine
FoamFile
version 2.0;
format ascii;
location "0";
object U;
internalField uniform (63.63 63.63 0);
boundaryField
inlet
type fixedValue;
value $internalField;
inlet
type groovyBC;
//variables "zp=pts().z;minZ=min(zp);maxZ=max(zp);para=-pow(pos().z/0.390667,0.13)*normal();";
//valueExpression "vector(63.63*para, 63.63*para, 0)";
valueExpression "vector(63.63, 63.63, 0)";
value uniform (63.63 63.63 0);
front
//type slip;
type fixedValue;
front
type groovyBC;
//valueExpression "90*para";
back
//type slip;
type inletOutlet;
//value uniform (90 0 0);
back
type groovyBC;
valueExpression "vector(0,0,0)";
//valueExpression "vector(63.63,63.63,0)";
gradientExpression "vector(0,0,0)";
fractionExpression "(phi > 0) ? 0 : 1";
//value uniform (0 0 0);
outlet
type inletOutlet;
outlet
type groovyBC;
lowerWall
type slip;
//type fixedValue;
OBJECT_patch0
type fixedValue;
upperWall
type slip;
Old   March 31, 2010, 18:26
bjr
Ben Racine
But, if I switch the commented lines from
to
//valueExpression "vector(63.63, 63.63, 0)";
it gives the error...
Starting time loop
Time = 1
Parser Error at "1.18" :"syntax error, unexpected ','"
Any ideas?
Old   March 31, 2010, 19:21
Assistant Moderator
Bernhard Gschaider
to
Starting time loop
Time = 1
Any ideas?
Looks like a bug in the parser. Could you report a bug at http://sourceforge.net/apps/mantisbt...e_status_id=-2
Bernhard
Old   March 31, 2010, 19:30
bjr
Ben Racine
I don't get it because there seems to be a successful case here... he thinks he has a pow(x,y) error, but seems to have gotten the above syntax to work.
http://www.cfd-online.com/Forums/ope...-groovybc.html
I managed to get a parabolic profile with
variables "w=0.00005;m=3;n=2;Umax=1*(m+1)*(n+1)/m/n;c=pos().y-w;d=pos().z-w;a=pow((c/w),2);b=pow((d/w),2);speed=Umax*(1-a)*(1-b);";
valueExpression "vector (speed, 0, 0)";
in my starting file for U but i have two problems.
pow() does not accecpt non integer values for the exponent like pow(a,1.5) is this a "normal" behaviour?
and
i need some function to get the distance from a point like
distance = pos().z-w now this will result in an negative value if pos().z <w which "should" be positive, i tried abs() but it seems its not implemented and i tried something like sqr(pow(pos().z-w,2)) which doesnt work either.
Old   March 31, 2010, 19:46
Default Found the problem as far as syntax is concerned...
bjr
Ben Racine
I've at least made the syntax happy... I believe the normal and the negative sign do not combine with the vector function. I suppose this makes sense, to be explicit about the vector components in this way. As for making sure it's physically correct... that's my problem. Thanks for entertaining my thoughts out loud though Bernhard! Once again it's us and not groovyBC!
inlet
type groovyBC;
valueExpression "vector(pow(pos().z/0.390667,0.13)*63.63,pow(pos().z/0.390667,0.13)*63.63,0)";
Old   January 14, 2011, 20:42
Default help with inflow to groovybc
bunni is on a distinguished road
Sorry for the newbie questions, but clearly I'm misunderstanding something. I'd like to use groovyBC to vary the inlet velocity both in time and space. I've been playing with the examples circulatingsplash.
I'll use that example, from the 0/U file:
atmosphere
type groovyBC;
valueExpression "-(alpha1+internalField(alpha1))*0.5*normal()";
So, my questions:
(1) why do you need
value uniform(0,0,0) ?
From what I understand valueExpression is going to assign a value to each cell face, what role is the uniform playing?
(2) how is
type groovyBC
valueExpression " vector(0,2,0)";
different from
type groovyBC
valueExpression "2*normal()";
different from:
type fixedValue
value uniform(0,2,0)
(in this case, atmosphere is on the y=1 plane)
Cheers
bunni is offline   Reply With Quote
Old   January 15, 2011, 12:27
Assistant Moderator
Bernhard Gschaider
atmosphere
type groovyBC;
So, my questions:
(1) why do you need
value is only needed by programs that "don't understand" the groovyBC (usual reason is that they are not OpenFOAM-programs - therefor they can't load the libs - that understand the OF-Fileformat. Usually postprocessors like Paraview and Visit) and want some information about the value on the border (although for the IC the value is probably inconsistent with the groovyBC)
(2) how is
type groovyBC
different from
type groovyBC
different from:
type fixedValue
They are all equivalent. The middle one is the most flexible because it makes no assumption about the orientation of the boundary. So if you got to 3D and your atmosphere is z=1 you can reuse the files from the IC and they will still work.
Old   January 15, 2011, 22:32
Default thanks
Ok, thanks for that. It's good to know I have some idea. So, the
value uniform (0,2,0) is for postprocessing - I do use paraview. Now,
I haven't noticed any difference from the following BC's:
(1)
type groovybc;
valueExpression 2*normal;
(2)
type groovybc;
valueExpression 2*cos(time())*normal;
The latter should give me a periodic wave, but as I run the case, and post-processes using paraview I see no difference as a function of time. This could then be a paraview problem? can you suggest a different way of processing the data to see what's going on?
Thanks so much for your help, it's good to know I'm somewhat on the right track.
Old   January 17, 2011, 11:35
Assistant Moderator
Bernhard Gschaider
(1)
type groovybc;
(2)
type groovybc;
Could you please copy the relevant expressions here so that we're not chasing ghosts? The entries you copied won't work (wrong case of BC, no " around expression, no () after normal)
Bernhard
crossflow, inlet profile
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 08:49
[swak4Foam] Boundary Conditions with GroovyBC, Normal Gradient treima OpenFOAM Community Contributions 32 November 17, 2017 04:44
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
[swak4Foam] Boundary Conditions with GroovyBC, Normal Gradient treima OpenFOAM Community Contributions 2 January 26, 2013 03:37
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
