[Tutorials] Tutorial of how to plot residuals !
Like Tree346Likes
Old   February 11, 2014, 06:03
Ilya
skeptik is on a distinguished road
Originally Posted by odin View Post
skript does not work with OpenFoam 2.1.1
It does not matter. Script uses standard unix-commands to work with txt log-file.
practice makes perfect
skeptik is offline   Reply With Quote
Old   February 12, 2014, 04:51
pingat is on a distinguished road
Originally Posted by Stephan8 View Post
Hey all,
i have a problem according to plotting the residuals. After the command gnuplot Residuals i got the following error:
at: write error: Broken pipe
plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,     "< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,     "< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines,     "< cat log | grep 'Solving for p' | cut -d' ' -f9 | tr -d ','" title 'p' with lines
"Residuals", line 8: warning: Skipping data file with no valid points
"Residuals", line 8: x range is invalid
solving you problem is quite easy.
I think the problem is, that the cut utility cuts out the wrong part.
you should have a look at the "-f9" part of the script.
In your case you maybe need to cut out the 3. or 7. word and not the 9., just try it
pingat is offline   Reply With Quote
Old   February 12, 2014, 18:00
Stephan
Stephan8 is on a distinguished road
Thank you for the idea, but if i use "-f3" i get the message "line 8: Bad data on line 1" with "-f7" i get same error than with -"f9"
Stephan8 is offline   Reply With Quote
Old   February 13, 2014, 11:17
1. do you have checked that you named your log file right?
2. 3 or 5 where just ideas. seems like you cut out words.
you have to look into your log file, to get the right position in the line, where you got a search hit by your grep.
maybe you should have a look at, what this script reallys does. it's a nice exercise to get known to the grep and cut utilities.
Stephan8 likes this.
Old   March 15, 2014, 08:50
Default pressure iterations -- final iteration final residual
  #85
Kai
ssboss is on a distinguished road
Hello all
First of all, Openfoam is PITA. Second of all, thanks for this very useful script. Now I am having an issue:
so my log file output looks like this:
smoothSolver:  Solving for Ux, Initial residual = 0.000427706, Final residual = 4.58245e-06, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.00102392, Final residual = 1.18461e-05, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.00490348, Final residual = 0.000327938, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.000625867, Final residual = 4.67654e-05, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.000200362, Final residual = 1.50974e-05, No Iterations 3
time step continuity errors : sum local = 1.33872e-07, global = -2.67987e-18, cumulative = 1.0102e-14
smoothSolver:  Solving for nuTilda, Initial residual = 0.000758284, Final residual = 7.80812e-06, No Iterations 2
Uncorrected Ubar = 0.886833	Ubar = 1.06	pressure gradient correction = 8749.53	pressure gradient = 13
ExecutionTime = 1062.22 s  ClockTime = 1551 s
So, as you can see, my pressure has 3 iterations, and I wish to plot the final residual value from the last iteration. My Residual.H script looks like this:
set logscale y
set title "Residuals"
set ylabel 'Residual'
set xlabel 'Time'
plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f13 | tr -d ','" title 'Ux' with lines,\
"< cat log | grep 'Solving for Uy' | cut -d' ' -f13 | tr -d ','" title 'Uy' with lines,\
"< cat log | grep 'Solving for p' | cut -d' ' -f13 | sed -n 'p;N;N' | tr -d ','" title 'p' with lines,\
"< cat log | grep 'Solving for nuTilda' | cut -d' ' -f13 | tr -d ','" title 'nuTilda' with lines
reread
What is happening, as far as I can see is that my gnuplot is plotting the final residual of the first iteration for pressure p. So note my final residual for first iteration is around 3e-04, and my final residual for last iteration is around 1e-05. What I am seeing in the pressure residual plot is of order 1e-04.
Can anyone tell me if there is something wrong with my code? If not how should I go about plotting final residual of last pressure iteration? Thank you very very much.
ssboss is offline   Reply With Quote
Old   April 26, 2014, 10:06
wubin
nuaawubin is on a distinguished road
nice ,thks for sharing
nuaawubin is offline   Reply With Quote
Old   May 7, 2014, 00:45
Mohammed Ameenuddin
ameen@cfd is on a distinguished road
Hello everyone,
I have used pyfoam to plot residuals but when I use parallel, I am not able to get the plots. Can anyone tell how can I make pyfoam to plot residuals when running in parallel.
Thank you
ameen@cfd is offline   Reply With Quote
Old   May 7, 2014, 06:08
Assistant Moderator
Bernhard Gschaider
Originally Posted by ameen@cfd View Post
Hello everyone,
Thank you
I guess you'll have to be more specific: I use it for parallel runs all the time (without problems)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 7, 2014, 07:14
Mohammed Ameenuddin
I am using scotch method to decompose my problem into two processors.
I used mpirun -np 2 simpleFoam -parallel > log& command to start my simulations.
Later I used pyFoamPlotWatcher.py log in order to plot my residuals but I get
gnuplot > plot
line 0: function to plot expected
but I don't find the output being generated.
Thank you
Old   May 7, 2014, 10:01
Assistant Moderator
Bernhard Gschaider
gnuplot > plot
Thank you
The Watcher doesn't care whether the run is serial or parallel. It only looks at the log. And that should be almost the same in both cases. Have you had a look at the log-file? (alternative possibility is that less than two timesteps have finished. PyFoam needs that many to start plotting properly)
Old   May 8, 2014, 01:27
Mohammed Ameenuddin
I have looked into the log file and it seems to be as it should be.
After using command for Watcher this is I get
gnuplot> set terminal x11
line 0: unknown or ambiguous terminal type; type just 'set terminal' for a list
gnuplot> set terminal x11 noraise
gnuplot> plot
smoothSolver: Solving for Ux, Initial residual = 0.000188298, Final residual = 6.1361e-06, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.000162305, Final residual = 5.29564e-06, No Iterations 4
Mean while these files have been generated
pyfoamFiles.tar.gz
log.tar.gz
Old   May 8, 2014, 09:29
Assistant Moderator
Bernhard Gschaider
Attachment 30677
Attachment 30678
PLEASE use CODE not QUOTE for output because that makes answering easier (see above)
Anyway: the problem is that your gnuplot is missing the default terminal type x11? Two possibilities: it is Windows or similar. The other: the environment variable DISPLAY is not set (probably because you connected to a remote machine via ssh without the -X-option) and gnuplot decided (No DISPLAY: no X11). Any way it seems that there is vital information that you're withholding from us
ameen@cfd likes this.
Old   May 9, 2014, 03:05
Mohammed Ameenuddin
The terminal x11 was the issue. I re-installed gnuplot and it is working fine now. Thank you for the help.
Old   June 6, 2014, 10:07
Thomas
Meister is on a distinguished road
Hi Foamers,
it is also possible to use cat to separate the data before using gnuplot. It is very much flexible in that way. I know it has also disadvantages but maybe it helps someone. I used it to plot the residuals vs Time:
cat log | grep -w 'Time =' | cut -d' ' -f3 | tr -d ',' > time_tmp.dat
cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ',' > Uy_tmp.dat
same for Ux, Uy
paste time_tmp.dat Ux_tmp.dat Uy_tmp.dat Uz_tmp.dat > residuals.dat
then in gnuplot
plot "residuals.dat" using 1:2 title 'Ux' with lines,"residuals.dat" using 1:3 title 'Uy' with lines,"residuals.dat" using 1:4 title 'Uz' with lines
regards
Thomas
ayhan515, skeptik and StefanW like this.
Meister is offline   Reply With Quote
Old   July 22, 2014, 12:45
Default Plot U and T residuals on reactingFoam
  #95
Duarte Magalhães
DuarteMagalhaes is on a distinguished road
Hi everyone!
I am trying to plot the U (Ux, Uy, Uz) and T residuals from reactingFoam. I am only able to plot the variables that are discriminated in my log file, not these.
Anyone knows how to plot these other variables? Or how to make them appear in my log file?
Thanks in advance
DuarteMagalhaes is offline   Reply With Quote
Old   July 22, 2014, 18:32
Assistant Moderator
Bernhard Gschaider
Originally Posted by DuarteMagalhaes View Post
Hi everyone!
Thanks in advance
If they're not in the log-file they can't be plotted (and probably not even solved for).
Missing U in the log-file is strange, but missing T is probably OK: usually OF solves for the enthalpy h. T is then calculated from that
Old   July 23, 2014, 12:04
Duarte Magalhães
Thank you for your reply Bernhard.
Yes, indeed I also found it strange to be missing U.
I have also run a reactingFoam tutorial, and again, U was not present in the log file. Is this a characteristic of the solver? Does not make much sense since it solves the momentum equation, U should be there, as the enthalpy and the species are.
Old   July 23, 2014, 17:50
Assistant Moderator
Bernhard Gschaider
Have a look at your fvSolution-file. If the momentumPredictor is switched off then the behaviour is perfectly OK (because the U-Eqn is never solver. Only used)
DuarteMagalhaes likes this.
Old   July 24, 2014, 04:39
Duarte Magalhães
Thank you so much Bernhard!
Old   September 30, 2014, 15:17
sampath
sampy is on a distinguished road
This is very useful. Thank you
sampy is offline   Reply With Quote
plot residuals in multiregion solver val46 OpenFOAM 4 December 12, 2016 07:06
To Plot Residuals on the fly. neeraj OpenFOAM Running, Solving & CFD 5 October 2, 2013 07:23
[PyFoam] why pyFoamPlotRunner doesn't plot continuity residuals? immortality OpenFOAM Community Contributions 10 May 5, 2013 07:13
plot of residuals hawkeye321 OpenFOAM 5 December 7, 2012 10:05
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 17:01
