[Tutorials] Tutorial of how to plot residuals ! |
November 19, 2011, 18:34 |
#41 |
Sandy Lee
Rep Power: 18 |
It's ok, I think. If p equation gets convergent, you can judge other equations have got convergent early.
April 19, 2012, 03:53 |
#42 |
Hello, everyone!
I use scripts for plot residuals and coefficients (thank you VERY MUCH). Residuals are plotting, but coefficients - not. I have only grid of graphics, and a tip, that lift coeff have red color, drag - green. I look inside file and change it according my solver. Did I do something wrong? Or how can I get the graphic of force coefficients? |
August 13, 2012, 06:29 |
#43 |
tanzil tjhin
Rep Power: 14 |
Thanks Wolfgang for the great script,
I was wondering what syntax is needed to plot Residual vs Time in transient case instead of Residual vs Iteration. Does anyone have an Idea? Regards |
August 14, 2012, 01:33 |
#44 |
ata kamyabi
Rep Power: 18 |
Hi
May be you can use pyFoam |
November 2, 2012, 02:05 |
#45 |
Suranga Dharmarathne
Rep Power: 15 |
how to save pyFoamPlotWatcher.py generated gunplots at the end of the run.
BR, Suranga. |
November 21, 2012, 12:00 |
#46 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
With all pyFoam-utilities the option "--help" is your friend. The option you're looking for is callled --hardcopy I believe (just because I write this stuff doesn't mean that I know how to use it ). There are also options to write the data to postprocess it with other programs (going through pyFoamRedoPlot.py even allows you to write CSV-files that you can directly use in a Spreadsheet)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
November 29, 2012, 16:41 |
#47 |
Rep Power: 13 |
This is quite nice, but is there anyway to import the data from the log file into excel for some nicer looking graphs?
November 29, 2012, 16:50 |
#48 |
mauricio
Rep Power: 18 |
hi! u can create a bash script to create a txt/csv like file so u can import it to excel..
the command "awk" is the best call imo gl
Best Regards /calim "Elune will grant us the strength" |
November 29, 2012, 17:55 |
#49 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
One possible way was described in the next sentence: read the file with the pickled data with pyFoamRedoPlot.py and instead of generating images write CSV-files (CSV is read by almost everyone including Excel) Other way would be to let the Watcher write files with the --write-files-option and use pyFoamConvertToCSV.py
November 29, 2012, 18:16 |
#50 |
Rep Power: 13 |
oops, no I meant using gnuplot however I'll take a look at using pyFoamWatcher. CSV data would be perfect. Thanks!
November 29, 2012, 19:10 |
#51 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
In the thread tree your posting showed up as a response to one of my postings. And that was all context there was for the "this". Didn't mean to impose PyFoam on you
November 30, 2012, 04:20 |
#52 |
Rep Power: 13 |
Ah right, the quick reply function is different here compared to other forums. Usually just adds a comment onto the thread without specifying who you reply to.
Found an easier way, simply copy and paste the log file into excel, split into columns by delimiting (use space and comma). Use an if/else function to select the row of the column that has (for me Uy) then return the row 3 columns to the right or return zero. Filter out the zeros, copy and paste the non-zero data into a new sheet as 'values' and you're sorted. |
November 30, 2012, 12:16 |
#53 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
December 7, 2012, 10:25 |
Problems with plotting by gnuplot, simpleFoam Residuals
#54 | |
Sören
Rep Power: 14 |
Hi foamers,
I have a maybe stupid question about how to plot the residuals of a simpleFoam Simulation. I'm used to pyFoam but this is no longer an option so I've tried gnuplot and the script provided by W.Heydlauff. As I understand the script it should plot the Final Residual of the log-file, right? But when I use it now it gives me the Initial Residual of the log-file. How comes? Here is my gnuplot-script: Quote:
Thank you in advance. |
December 7, 2012, 11:33 |
#55 |
tanzil tjhin
Rep Power: 14 |
It should be f13 instead of f9 to plot Final residual.
regards, Tanzil |
December 7, 2012, 11:44 |
#56 |
Sören
Rep Power: 14 |
Sure? I've tried f12, f13 and f14 but these tries just produced error-messages...
December 10, 2012, 06:31 |
#57 | |
Dima Risch
Rep Power: 15 |
Hi Sören,
with your gnuplot-script and the changes described by Tanzil the plot works without errors Quote:
dima |
December 10, 2012, 06:43 |
#58 |
Sören
Rep Power: 14 |
Thanks,
I copied your script - working fine. I guess that I've overlooked something in my script... Thnaks for the quick help. |
December 18, 2012, 12:15 |
how draw pressure coefficient in openFoam
#59 |
saeideh mohamadi
Rep Power: 15 |
hi dear Wolfgang;
it was really useful post, it help me alot. would you please tell us how can draw pressure coefficient on airfoil using paraview? our multi element airfoil have been solved with openFoam software. thank you very much |
January 4, 2013, 08:03 |
How about parallel situation
#60 |
Jianye Xia
Rep Power: 18 |
Hi, can this method applicable to parallel cases?
plot residuals in multiregion solver | val46 | OpenFOAM | 4 | December 12, 2016 06:06 |
To Plot Residuals on the fly. | neeraj | OpenFOAM Running, Solving & CFD | 5 | October 2, 2013 06:23 |
[PyFoam] why pyFoamPlotRunner doesn't plot continuity residuals? | immortality | OpenFOAM Community Contributions | 10 | May 5, 2013 06:13 |
plot of residuals | hawkeye321 | OpenFOAM | 5 | December 7, 2012 09:05 |
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread | wyldckat | OpenFOAM Installation | 2 | July 11, 2012 16:01 |
