[Tutorials] Tutorial of how to plot residuals ! |
October 28, 2009, 08:19 |
#21 |
Bernard Esterhuyse
Rep Power: 17 |
Hi
Thanks for this excellent script. Is it possible to zoom into a section of the residual plot? |
November 29, 2009, 02:27 |
#22 |
ata kamyabi
Rep Power: 18 |
Hi every one
When I try to plot residuals with gnuplot I got this error: plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,"< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,"< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,"< cat log | grep 'Solving for omega' | cut -d' ' -f9 | tr -d ','" title 'omega' with lines,"< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines,"< cat log | grep 'Solving for p' | cut -d' ' -f9 | tr -d ','" title 'p' with lines ^ "Residuals", line 10: warning: Skipping data file with no valid points plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,"< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,"< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,"< cat log | grep 'Solving for omega' | cut -d' ' -f9 | tr -d ','" title 'omega' with lines,"< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines,"< cat log | grep 'Solving for p' | cut -d' ' -f9 | tr -d ','" title 'p' with lines ^ "Residuals", line 10: warning: Skipping data file with no valid points plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,"< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,"< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,"< cat log | grep 'Solving for omega' | cut -d' ' -f9 | tr -d ','" title 'omega' with lines,"< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines,"< cat log | grep 'Solving for p' | cut -d' ' -f9 | tr -d ','" title 'p' with lines ^ "Residuals", line 10: warning: Skipping data file with no valid points plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,"< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,"< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,"< cat log | grep 'Solving for omega' | cut -d' ' -f9 | tr -d ','" title 'omega' with lines,"< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines,"< cat log | grep 'Solving for p' | cut -d' ' -f9 | tr -d ','" title 'p' with lines Can any body help me? Regards Ata |
#23 |
ata kamyabi
Rep Power: 18 |
Hi every one
January 14, 2010, 09:18 |
#24 |
Robin Koldeweij
Rep Power: 16 |
It just means you are trying to extract fields from the 'log' file, which don't exist. May be you don't have a turbulence model and try to extract k and eps in example. Change your residual.txt file accordingly.
January 15, 2010, 01:16 |
#25 |
ata kamyabi
Rep Power: 18 |
Hello RBj
Thanks. It seems so. Best Regards Ata |
April 1, 2010, 09:17 |
#26 |
Vincent RIVOLA
Rep Power: 18 |
Dear Openfoamers,
Wolfgang tool is very useful. However, I have a question. I usually start my computation with 3 nonOrthogonalCorector loops and then decreased to 0. if I use the script of wolfgang with the following line: "< cat log | grep 'Solving for p' | cut -d' ' -f9 | sed -n 'p;N;N' | tr -d ','" title 'p' with lines the line of p residual just stop on the graph when I decrease the number of p loops. how would it be possible to handle that? regards, Vincent |
November 13, 2010, 06:35 |
#28 |
Sarah Köhler
Rep Power: 16 |
Thanks for the code, its great ...
can i use it as well to plot the time step continuity errors? tried to exchange it, but i always get an error ... thanks in advance ... |
November 14, 2010, 02:10 |
#29 |
Alberto Passalacqua
Rep Power: 36 |
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
November 15, 2010, 15:11 |
listing please
#30 |
Thomas Wolfanger
Rep Power: 17 |
November 29, 2010, 11:31 |
#31 |
Matthias Voß
Rep Power: 20 |
hi,
i´m using the gnuplot approach quite a while and it is really helpful. But how about this: i want to know where the residuals are high and not convergent and want to look at the residual-fields (u,v,w, final p e.g.) in paraview. Basically it´s easy, just create field for each residualvalue and store them BUT i do not know how to manage smth. like residuals (u,v,w,p).write. Any ideas? neewbie |
December 2, 2010, 14:02 |
#32 |
Rep Power: 15 |
hello,
I've followed thew instruction of the tutorial to plot the forces.dat file with the forces of my simulation, generated by simpleFoam. here is my problem: gnuplot, only plots some of the columns, for example 1:3 (time versus Fy) but not 1:2 (time versus Fx) it gives me the following: Warning : skipping data file with no valid points attached there's the file. any ideas?? thanks! Michele ps thanks to Wolfgang for the thread! |
December 2, 2010, 14:26 |
#33 |
Rep Power: 15 |
I think the problem is due to the parentesis in my file..there's a way to convert the .dat file in order to be read properly by gnuplot?
EDIT: solved here: http://www.cfd-online.com/Forums/ope...-brackets.html |
December 3, 2010, 03:16 |
#34 |
Matthias Voß
Rep Power: 20 |
hi,
good to know about the previous post. I solved it with plot "..." using ... '%lf ( %lf %lf %lf) ( %lf %lf %lf)' but this only works up to 10 x %lf ...so max. 3 Vectors + first row. neewbie |
June 8, 2011, 07:22 |
#35 |
Mohsen KiaMansouri
Rep Power: 16 |
hi
thank you |
July 7, 2011, 07:46 |
#37 |
Tibo
Rep Power: 15 |
Awesome.
Thx Wolfgang. Tibo |
July 26, 2011, 11:04 |
#38 |
mauricio
Rep Power: 18 |
it's an old topic but still i feel like i need to thank, it surely speeds things up
August 16, 2011, 06:42 |
#39 |
Suhas
Rep Power: 15 |
Thanks for the script,
One additional information is, the sequence of residuals reading in command line for gnuplot also to be same as solved by that particular solver. Hope it helps someone. ThankYou. Regards Suhas |
November 17, 2011, 19:10 |
#40 |
Robin Gilbert
Rep Power: 16 |
Hi everyone,
I tried this: Code:
set logscale y set title "Residuals" set ylabel 'Residual' set xlabel 'Iteration' plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | sed -n 'Ux;N' | tr -d ','" title 'Ux' with lines,\ "< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | sed -n 'Uy;N' | tr -d ','" title 'Uy' with lines,\ "< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | sed -n 'Uz;N' | tr -d ','" title 'Uz' with lines,\ "< cat log | grep 'Solving for k' | cut -d' ' -f9 | sed -n 'k;N'| tr -d ','" title 'k' with lines,\ "< cat log | grep 'Solving for p' | cut -d' ' -f9 | sed -n 'p;N;N;N' | tr -d ','" title 'p' with lines pause 1 reread Last edited by robingilbert; November 17, 2011 at 20:13. |
plot residuals in multiregion solver | val46 | OpenFOAM | 4 | December 12, 2016 06:06 |
To Plot Residuals on the fly. | neeraj | OpenFOAM Running, Solving & CFD | 5 | October 2, 2013 06:23 |
[PyFoam] why pyFoamPlotRunner doesn't plot continuity residuals? | immortality | OpenFOAM Community Contributions | 10 | May 5, 2013 06:13 |
plot of residuals | hawkeye321 | OpenFOAM | 5 | December 7, 2012 09:05 |
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread | wyldckat | OpenFOAM Installation | 2 | July 11, 2012 16:01 |
