[Discretizer] Discretizer, a free mesh program for CFD (Computational Fluid Dynamics) |
October 29, 2010, 13:26 |
#41 |
Björn Bergqvist
Rep Power: 17 |
discretizer_setup64.sh knows where it is executed from so nothing should be taken care of. Maybe ./discretizer_setup64.sh ?
________________________________________ Björn Bergqvist, creator of Discretizer, a free mesh generator for OpenFOAM _________http://www.discretizer.org_____________
October 29, 2010, 14:36 |
#42 |
Antonio Liggieri
Rep Power: 15 |
Good evening Björn,
thanks for your quick reply. Do I have to copy every the whole descritizer directory which was created by doing tar zxf into the case directory?? Have a good weekend Antonio |
October 29, 2010, 14:39 |
#43 |
Björn Bergqvist
Rep Power: 17 |
Should not be needed. But you have to execute discretizer_setup64.sh :-)
November 1, 2010, 10:11 |
#44 |
Antonio Liggieri
Rep Power: 15 |
Hello everybody,
I'm very new to discretizer and I find it makes foamlife much easier. Unfortunately I faced some problems. Has anybody a solution to the following problems: - SHOW & HIDE buttons in the "view" menu is missing. - Conversion of Fluent Mesh with internal walls not possible! - Is the Heat Transfer Option at the moment an empty one, or has to be switched on something special to enable it? - After set up a case in discretizer_setup I'd like to safe it within my OpenFoam case directory. I found a "tutorial" on youtube, where all the files are written into the case dirctory with "sync Files" from the run Menu. If I do so, it starts to write, at least the dialog at the bottom shows this, but it doesn't write anything, and I must interrupt the program after a while, because it seems to be crashed. In principle I only need the 0 directory written! Constant and system is already created during setting up boundaries and so on. Thanx in advance, Antonio |
November 1, 2010, 15:36 |
#45 |
Björn Bergqvist
Rep Power: 17 |
SHOW & HIDE buttons missing -I've not discovered that. Which version of discretizer are you using? Conversion of internal walls in fluent -do the walls dissapear, or are they just not visible? Heat transfer is not enabled in any of the currently provided solvers. When you sync, did you open the resulting mesh first? Björn
November 3, 2010, 07:15 |
#46 |
Antonio Liggieri
Rep Power: 15 |
Hy Björn,
BUTTONS: - the version I'm using is downloaded from this page a couple of days ago: http://www.discretizer.org/node/2 - I couldn't make out those two buttons in discretizer_setup FLUENTMESH_CONVERSION: - It's not possible at all to convert fluentmeshes with internal walls. I receive a strange error which does not appear to have something to do with conversion. But the error is ONLY when converting a mesh with internal walls!! SYNC_FILIES: Yes I do, but after having used the sync button it seems something to happen, but nothing happens. No /0 directory is written! Maybe it's an installation issue. I unpacked descritizer into /opt, and start it always from there by typing ./descritizer_setup64 within that directory. Then, for mesh conversion I choose the option in the "File" drop down box and specify two paths: the OFcase directory path, and the path from where the mesh has to be imported. I DO NOT START discretizer from the OFcase directory!! |
February 3, 2011, 10:41 |
#47 |
Rep Power: 17 |
Hi all !
I'm more and more interested in this great tool discretizer. I saw that in discretizer_setup we can import fluent meshes by checking the "fluent3dMeshToFoam" box. Works great ! But now i would like to do the same with a star-ccm mesh and the function ccm26ToFoam. As far as I looked into the soft it is not allowed until now. Is there an easy way to do it ? Thanks, Fabien. |
March 28, 2011, 06:07 |
#48 |
Rep Power: 15 |
Hi dear bjornthe and thank you for great tool!
PS: have you donation button? Last edited by ST1; March 28, 2011 at 10:29. |
March 30, 2011, 01:59 |
#49 | |
Björn Bergqvist
Rep Power: 17 |
Discretizer at sourceforge: http://sourceforge.net/projects/discretizer/ donate button: http://sourceforge.net/project/proje...roup_id=160770 Regards
August 17, 2011, 08:52 |
Same problem while trying to run Discretizer on Linux/Ubuntu
#50 | ||
I am trying to run discretizer but I received the same error message as the first quote in this message. I tried to act on the solution mentioned in the second reply quote. Copied the simpleFoam and transformPoints utility application folders in the folder of discretizer, however still received the same message. After that I tried the "wmake" command from terminal inside the folders of simpleFoam and transformPoints respectively for compilation. However I received this error in the terminal window: "/usr/bin/ld: cannot open output file /opt/openfoam200/platforms/linux64GccDPOpt/bin/transformPoints: Permission denied collect2: ld returned 1 exit status make: *** [/opt/openfoam200/platforms/linux64GccDPOpt/bin/transformPoints] Error 1" Can anyone please guide and help me on this. Thank you. Reply will be highly appreciated. |
August 17, 2011, 09:01 |
#51 |
Björn Bergqvist
Rep Power: 17 |
You have to start discretizer with openfoam commands in your path. Before you start discretizer (from command line) you can check if openfoam commands are avalable by:
$which simpleFoam If simpleFoam isn't avaliable you get the output "no simplefoam in (...) then you have to initiate openfoam with $. ~/OpenFOAM/2.0.0/etc/bashrc (or something similar) Regards Björn
August 19, 2011, 06:46 |
#52 | |
I checked that simpleFoam and transformPoints both were available in my discretizer shell and confirmed it with the commands you told me too. However I noticed a difference in the "fvschemes" file which discretizer produces. In divSchems, the last line on discretizer prodeced fvschemes comes out to be "div((nuEff*dev(grad(U).T()))) Gauss linear;". While in some other similar openFOAM cases the "fvschemes" files includes this last line under divSchemes " div((nuEff*dev(T(grad(U))))) Gauss linear;". I believe there is a slight difference in syntax. And if i tried to run simpleFoam directly from terminal and not from discretizer on the discretizer produced mesh, I also received an error which mentions an error in divSchemes of fvSchemes. When I changed that line mentioned above, the solution rain perfectly fine. Please check this out and tell me if this can be the case. It worked with me. Regards, Umer |
August 19, 2011, 06:57 |
#53 |
Björn Bergqvist
Rep Power: 17 |
You are right. Some things has to be remade for OF 2.
Regards Björn
August 22, 2011, 05:02 |
Delete Option?
#54 |
Is there a delete option for points,faces,cubes etc for discretizer. I could not locate any. So if I want to delete a geometric entity I created, how do I do that? I could only see an edit option. Help will be useful. Thank you Kind Regards, Umer |
August 22, 2011, 05:07 |
#55 |
Björn Bergqvist
Rep Power: 17 |
There is no delete. You can open the file as a spreadsheet and delete :-) , then export semi-colon-separated.
Björn
October 3, 2011, 09:27 |
#56 |
Dear Björn Bergqvist
I need some help regarding how to create my desired geometry in Discretizer. Initially I made a very thin square cube but with very large sides (300mm) with a very small square cross section tube (5 x 5 mm) in its center for my CFD analysis. I did that by making a square face, making a cube then initially for the tube. Then making a small cube at its back representing the thickness of my large thin cube. Then from that, by extending its sides into cubes and joining them, I completed the geometry. Hence this way all the mesh was connected. Can you tell me how will it be possible to make all this geometry in a circular way. Having a large circular thin cylinder, and a very small circular pipe in its center with all the mesh connected? Thanks, your help will be highly appreciated, as I am stuck in it. Umer |
October 26, 2011, 23:55 |
#57 |
jundika
Rep Power: 15 |
Hi all,
I am new to linux and discretizer. Recently I installed Ubuntu 11.10 alongside with Windows Vista Home Premium 32 bit on my system: AMD Turion X2 1.90 GHz 2GB RAM I also installed discretizer from http://www.discretizer.org/ on Linux. I installed OpenFOAM 2.01 first before installation discretizer. I followed the installation instruction step by step 1. sudo apt-get install g++ libxrandr-dev libgemplugin-ruby rubygems libopengl-ruby ruby1.8-dev libfox-1.6-0 libfox-1.6-dev libfox-1.6-doc libfxscintilla17 libfxscintilla-dev subversion subversion-tools (here I change libfxscintilla17 with libfxscintilla19). 2. get http://rubyforge.org/frs/download.ph...uby-1.6.16.gem 3. sudo gem install fxruby-1.6.16.gem 4. svn co https://discretizer.svn.sourceforge....ot/discretizer discretizer 5. cd discretizer/discretizer/lib Everything went well till this step. However when I proceed to the next step ruby discretizer.rb I got this warning jundika@jundika-HP-Pavilion-tx1000-Notebook-PC:~/discretizer/discretizer/lib$ ruby discretizer.rb /usr/lib/ruby/vendor_ruby/1.8/rubygems/custom_require.rb:36:in `gem_original_require': no such file to load -- fox16 (LoadError) from /usr/lib/ruby/vendor_ruby/1.8/rubygems/custom_require.rb:36:in `require' from discretizer.rb:38 |
April 4, 2012, 10:27 |
#59 |
Rep Power: 16 |
I hope that this is not too much of a thread hijack... I've be attempting to learn how to use Discretizer, there's a couple of (probably simple) questions have... BTW I'm doing this using the latest BlueCape setup on Windows I downloaded this week. Firstly to get snappyHexMesh to run I need to add the lines: allowFreeStandingZoneFaces true; minTetQuality 1e-9; In file snappyHexMeshDict I think I've managed to get them in the correct place from another example file I have, I don't know why they are not there in the first place though? Can someone explain? Secondly once snappyHexMesh is run and the mesh brought into Discretizer, I get the issue shown in the attached image. With one face removed what should be the corner is pulled to the 0,0,0 location and there's couple of holes in the external faces. How do I go about fixing this? Thanks Doug. |
April 5, 2012, 13:28 |
#60 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Doug68 and welcome to the forum!
Discretizer isn't officially working yet with OpenFOAM 2.0 and 2.1. You can try and replace the contents of the "discretizer" sub-folder that is inside the main "discretizer" folder, with the contents available in the SVN in the sub-folder "discretizer200". You can get a snapshot from here: http://discretizer.svn.sourceforge.n...iscretizer200/ - click on the "Download GNU tarball" link to get a snapshot of that folder. But I don't know if this will working properly or not Best regards, Bruno
solution manual for essential computational fluid dynamics by oleg zikanov | okhitan | Main CFD Forum | 0 | October 25, 2014 16:54 |
computational fluid dynamics and finite element analysis | kabirgph | Main CFD Forum | 1 | October 17, 2014 07:59 |
unable to find any Online Course regarding Basic Computational Fluid Dynamics | Yuska Kamil | Main CFD Forum | 1 | December 17, 2007 15:39 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
