[Discretizer] Discretizer, a free mesh program for CFD (Computational Fluid Dynamics)
Like Tree3Likes
Old   May 3, 2010, 10:21
Default Fbo
  #21
Björn Bergqvist
bjornthe is on a distinguished road
in order to use an OpenGL application in a compositing window manager you have to have frame buffer overlay working. If you have a non-nvidia graphics card then dri2 has to be functional for this to work.
The solution is to disable "enhanced desktop effects".
Regards
Björn Bergqvist
________________________________________
Björn Bergqvist,
creator of Discretizer,
a free mesh generator for OpenFOAM
_________http://www.discretizer.org_____________
bjornthe is offline   Reply With Quote
Old   May 5, 2010, 08:20
Cean
shirazbj is on a distinguished road
Under Ubuntu 9.04, I goto:
System/Preferences/Appearance/Visual Effects
It shows:
None: Provides a simple desktop environment without any effects.
I am playing with an ancient PC. Maybe the display card is too old.
Regards,
Cean
shirazbj is offline   Reply With Quote
Old   May 5, 2010, 08:28
Björn Bergqvist
Do glxgears work fine?
Regards
Björn Bergqvist
Björn Bergqvist,
Old   May 6, 2010, 01:32
Cean
The gears rotate very well on the first pc where ::setup also works well but dicretizer occupies the whole screen. In fact this pc can't even set Normal Visual Effects. Can only choose None effects.
Will try the gears on the other pc where the discretizer drawing area is not correct. This pc can set on Extra visual effects.
Reagards,
Cean
Old   May 10, 2010, 10:11
Cean
discretizer occupies whole screen is beacuse my screen is set at 1024X768 and discretizer is also initialized at 1024*768. After change the discretizer.rb at 800X600, no problem now.
Still have problem with the other pc which can't show the drawing area correctly. what is 'dri2'? Maybe I need to change a non-compositing window manager.
Old   May 31, 2010, 11:56
Default pipe in discretizer
  #26
Nima Samkhaniani
nimasam is on a distinguished road
hi friend
i installed Discretizer , it works well , but is there anyone who has experience to model a pipe or a curved pipe in it ?
nimasam is offline   Reply With Quote
Old   June 1, 2010, 06:46
Björn Bergqvist
Originally Posted by nimasam View Post
hi friend
Yes check http://www.discretizer.org.
Björn
Björn Bergqvist,
Old   June 1, 2010, 07:01
Nima Samkhaniani
hi friend
i saw all the screen shots and screen casts in that website, but is there any step by step tutorial for modelling of a pipe and curved pipe ?
do you have any experience at it ?
Old   June 1, 2010, 08:00
Björn Bergqvist
No tutorial.
Some experience.
What do you want to model?
Are you aiming for an ogrid? maybe ogrid+snappy :-)
Björn Bergqvist,
Old   June 1, 2010, 08:20
Nima Samkhaniani
at first i want to grid a simple pipe (with out curved) + snappy mesh but i dont know how to do it in descritizer ?
should i model pipe in another software and bring it to descritizer or if i can model a pipe here, how?
Old   July 3, 2010, 02:13
Default Need help utilizing Discretizer
  #31
Charles
chuckjones55 is on a distinguished road
I am running the 64bit version of discretizer in CAELinux 2009, and the program operates without any problems, except the "import" option in the file menu is disabled (grayed out). Is this purposeful? When I try to follow the steps in the discretizer manual, or in the screencasts, everything works well with generating a mesh in netgen, and exporting as a neutral file; however, when I reach the importing step in discretizer, I can't proceed.
The only issue that I can think of is that my model was generated in Alibre Design, and then exported as an .STL rather than being generated in Freecad; however, I don't know why this would effect the import function of discretizer.
I haven't found any other posts of users with this particular issue, and any help would be greatly appreciated!
Charles
chuckjones55 is offline   Reply With Quote
Old   July 3, 2010, 02:58
Björn Bergqvist
So File -> Open STL doesn't work.
Then you can open stl in paraview and save it as ascii stl.
or
cd discretizer/svn
svn update
To activate import commands discretizer-setup has to be started in a shell where OpenFOAM commands are available
. ~/OpenFOAM/OpenFOAM-X/etc/bashrc
~/discretizer/discretizer_setup.sh
Björn Bergqvist,
Old   July 4, 2010, 01:30
Default Thanks
  #33
Charles
Bjorn,
Thanks for the immediate response. Because I am using CAELinux 2009, I don't actually have permission to open the folders using:
~/OpenFOAM/OpenFOAM-1.5/etc/bashrc
It returns "Permission Denied."
However, in "Applications - CAELinux - OpenFOAM terminal" I can enter the line:
~/discretizer/discretizer_setup64.sh
and it will open discretizer with the import function enabled!! Hope that this workaround will help other users.
Charles
Old   August 3, 2010, 06:44
Lee
lcnmy is on a distinguished road
I just installed the Discretizer and trying to solve some simple case. But I face an error with this:
boundary file written in 0.0100000000000016 s
faces file written in 1.59 s
time for mesh1: 6.34
sh: transformPoints: not found
simpleFoam -case step
Beside, I cant open my paraview by pressing the paraview button.
May I know whats go wrong with my setting and configuration?
Regards
Lee
lcnmy is offline   Reply With Quote
Old   August 3, 2010, 07:14
Björn Bergqvist
You have not initialized OpenFOAM. Make sure transformPoints and simpleFoam are available in the shell from where you start Discretizer.
Björn Bergqvist,
Old   August 20, 2010, 11:16
Abdel
bruxellois4 is on a distinguished road
I've installed discretizer under ubuntu 10.04 (32 bits),i 've unpacked the downloaded file and i've run "discretizer_setup.sh", now it works but ihave a screen problem it's not stable at all.
Any idea!?
Best regards.
bruxellois4 is offline   Reply With Quote
Old   September 8, 2010, 09:46
Default Could not launch discretizer.rb in Windows
  #37
Wai Sam Wong
anthropoy is on a distinguished road
Hi there,
I have followed the procedure in http://www.discretizer.org/node/12 to try to install Discretizer on Windows. When I double-clicked discretizer.rb, nothing happened. I have even tried installing the latest version of ruby but still nothing.
Any suggestions? Did i miss out on something?
Thanks,
Sam
anthropoy is offline   Reply With Quote
Old   September 24, 2010, 07:32
Björn Bergqvist
Windows binary release
Download: http://www.discretizer.org/node/2 (53 MB)
Uncompress the zip-file in c:\discretizer
If you want to install in another location, edit the bat-files (discretizer.bat and discretizersetup.bat).
For full functionality OpenFOAM has to be installed.
Screencast: http://www.discretizer.org/node/21
Björn
Björn Bergqvist,
Old   September 24, 2010, 09:33
Wai Sam Wong
Cool, thanks Björn!!
Old   October 29, 2010, 06:53
Default how do I use discretizer in conjunction with openfoam
  #40
Antonio Liggieri
alfa_8C is an unknown quantity at this point
Hello Björn,
you've definitely developed a useful tool. I'm impressed about the fact of getting such cool stuff for free!! It makes life much easier...
Now I'd like to use ist in the OpenFoam environment, but following the instructions that I found in the Descretizer Manual - Release date 09/01/10 paragraph 1.3 Installing Discretizer I can't get it working.
After unpacking it within the /opt directory, a "discretizer" directory was created. In that directory I can find two .sh files. I can start the discretizer easily by tying ./nameof.sh file.
But do I want to start it within a casedirctory of OpenFoam like explained on the download page:
"Just unpack and run "discretizer_setup64.sh" (example). For OpenFOAM functionality, start in a shell with OpenFOAM commands enabled."
it says: command discretizer_setup64.sh not found...
shouldn't be set an alias or an environment variable which points to the discretizer directory within the opt directory? If so, where and how do I have to set it. In the .bashrc or in the etc/apps/bashrc of the OpenFoam directory?
I appreciate any input.
Thanx in advance,
Antonio
alfa_8C is offline   Reply With Quote
solution manual for essential computational fluid dynamics by oleg zikanov okhitan Main CFD Forum 0 October 25, 2014 16:54
computational fluid dynamics and finite element analysis kabirgph Main CFD Forum 1 October 17, 2014 07:59
unable to find any Online Course regarding Basic Computational Fluid Dynamics Yuska Kamil Main CFD Forum 1 December 17, 2007 15:39
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
