March 10, 2010, 02:14 |
A Problem
#21 |
Mohammad Zakerzadeh
Rep Power: 17 |
Dear foamers!
I have a problem when I using Funky to set a complicated fields .my profile is as below: funkySetFields -time 0 -field alpha1 -expression 1 -condition "pos().y-1e-9-7.5e-9*exp((pow(pos().x-15e-9,10)+1)*log(1-pow((pos().x-15e-9)/7.5e-9,2)))<=0" but I think that this module have some problem with power function. I have this error: Putting "1" into field alpha1 at t = "0" if condition "pos().y-1e-9-7.5e-9*exp((pow(pos().x-15e-9,10)+1)*log(1-pow((pos().x-15e-9)/7.5e-9,2)))<=0" is true
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/Zakerzadeh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/Zakerzadeh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 log in "/lib/libm.so.6" #4 Foam::log(Foam::Field<double>&, Foam::UList<double> const&) in "/home/Zakerzadeh/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::log<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/Zakerzadeh/OpenFOAM/Zakerzadeh-1.6/applications/bin/linuxGccDPOpt/funkySetFields" #6 .L21360 at ValueExpressionParser.C:0 #7 ValueExpressionDriver:arse(std::string const&) in "/home/Zakerzadeh/OpenFOAM/Zakerzadeh-1.6/applications/bin/linuxGccDPOpt/funkySetFields" #8 doAnExpression(Foam::fvMesh const&, Foam::word const&, Foam::string const&, Foam::string const&, Foam::Time const&, bool, bool, bool, Foam::dimensionSet const&, bool, Foam::List<Foam::word> const&) in "/home/Zakerzadeh/OpenFOAM/Zakerzadeh-1.6/applications/bin/linuxGccDPOpt/funkySetFields" #9 main in "/home/Zakerzadeh/OpenFOAM/Zakerzadeh-1.6/applications/bin/linuxGccDPOpt/funkySetFields" #10 __libc_start_main in "/lib/libc.so.6" #11 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/Zakerzadeh/OpenFOAM/Zakerzadeh-1.6/applications/bin/linuxGccDPOpt/funkySetFields" Floating point exception Is there anyone have any idea about it. Sincerely |
March 10, 2010, 04:44 |
#22 |
Niels Gjoel Jacobsen
Rep Power: 37 |
According to error #3 it is due to the log-function. So make sure that you are not evaluating log(r), with r<=0.
Best regards, Niels |
March 10, 2010, 05:05 |
#23 |
Mohammad Zakerzadeh
Rep Power: 17 |
Yes,you are right!
But when I have this problem unless I decrease the power to 2 or 1. I test an easier case with just power term . Its better to test this case . I believe that this program have some problems with power.I appreciate if you have any suggestion about it? Sincerely |
March 12, 2010, 10:13 |
#24 |
G B
Rep Power: 16 |
This is very embarassing! What had worked previously with OF-1.6, now is not working with OF-1.6.x. I followed my steps but now im getting this error:
position.hh: In function ‘bool ve::operator==(const ve::position&, const ve::position&)’: position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’ ValueExpressionDriver.C: In member function ‘Foam::surfaceScalarField* ValueExpressionDriver::makeAreaField()’: ValueExpressionDriver.C:462: error: call of overloaded ‘GeometricField(Foam::IOobject, const Foam::fvMesh&, int)’ is ambiguous /home/gustavo/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/GeometricField.C:421: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dictionary&) [with Type = double, PatchField = Foam::fvsPatchField, GeoMesh = Foam::surfaceMesh] /home/gustavo/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/GeometricField.C:257: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensioned<Type>&, const Foam::word&) [with Type = double, PatchField = Foam::fvsPatchField, GeoMesh = Foam::surfaceMesh] ValueExpressionDriver.C: In member function ‘Foam::volScalarField* ValueExpressionDriver::makeVolumeField()’: ValueExpressionDriver.C:482: error: call of overloaded ‘GeometricField(Foam::IOobject, const Foam::fvMesh&, int)’ is ambiguous /home/gustavo/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/GeometricField.C:421: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dictionary&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/gustavo/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/GeometricField.C:257: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensioned<Type>&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] ValueExpressionDriver.C: In member function ‘Foam::volScalarField* ValueExpressionDriver::makeDistanceField()’: ValueExpressionDriver.C:506: error: call of overloaded ‘GeometricField(Foam::IOobject, const Foam::fvMesh&, int)’ is ambiguous /home/gustavo/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/GeometricField.C:421: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dictionary&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/gustavo/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/GeometricField.C:257: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensioned<Type>&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] ValueExpressionDriver.C: In member function ‘Foam::volScalarField* ValueExpressionDriver::makeRDistanceField(const Foam::volVectorField&)’: ValueExpressionDriver.C:529: error: call of overloaded ‘GeometricField(Foam::IOobject, const Foam::fvMesh&, int)’ is ambiguous /home/gustavo/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/GeometricField.C:421: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dictionary&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/gustavo/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/GeometricField.C:257: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensioned<Type>&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] make: *** [Make/linux64GccDPOpt/ValueExpressionDriver.o] Error 1 |
March 12, 2010, 13:30 |
#25 |
G B
Rep Power: 16 |
I do not know what i did, but it is working now. Thanks all.
March 15, 2010, 07:07 |
#26 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
If you really feel that there is a bug in FSF report it at https://sourceforge.net/apps/mantisb...e_status_id=-2 Bernhard |
May 7, 2010, 08:00 |
#27 | |
C.Z.
Rep Power: 16 |
I'm trying to install funkySetFields (v1.6) on OF-1.6, but i get this error in "Allwmake" :
Thanks in advance! |
May 10, 2010, 06:24 |
#28 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Something seems to be fundamentally wrong with your OF installation (there seem to be at least two libraries missing). Have you ever successfully compiled another third-party OF-utility? Could you post the stuff just before the error messages start?
May 10, 2010, 18:06 |
#29 | |
Rep Power: 17 |
Tx man. this message is very useful for such beginner like me
May 17, 2010, 10:20 |
#30 | |
C.Z.
Rep Power: 16 |
No, i did not even try to compile any OF-utility before. But i realised, that i was trying to install the funkySetFields-Tool from the POSTprocressing-directory. I don't know if that made any difference. Anyway, now i tried to install it from the PREprocessing directory and got these lines : Code:
hiwi@wmpc05:~/OpenFOAM/OpenFOAM-1.6/applications/utilities/preProcessing/FunkySetFields> ./Allwmake + wmake funkySetFields Making dependency list for source file ValueExpressionParser.C Making dependency list for source file ValueExpressionLexer.C Making dependency list for source file ValueExpressionDriver.C Making dependency list for source file funkySetFields.C SOURCE=ValueExpressionParser.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ValueExpressionParser.o In file included from location.hh:44, from ValueExpressionParser.tab.hh:65, from ValueExpressionParser.tab.cc:68: position.hh: In function ‘bool ve::operator==(const ve::position&, const ve::position&)’: position.hh:136: warning: suggest parentheses around && within || ValueExpressionParser.tab.cc: In member function ‘unsigned char ve::ValueExpressionParser::yytranslate_(int)’: ValueExpressionParser.tab.cc:3207: warning: use of old-style cast SOURCE=ValueExpressionLexer.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ValueExpressionLexer.o lex.ve.c:363: warning: use of old-style cast lex.ve.c:433: warning: use of old-style cast lex.ve.c:433: warning: use of old-style cast In file included from location.hh:44, from ValueExpressionParser.tab.hh:65, from ValueExpressionDriver.H:14, from ValueExpressionLexer.ll:3: position.hh: In function ‘bool ve::operator==(const ve::position&, const ve::position&)’: position.hh:136: warning: suggest parentheses around && within || lex.ve.c: In function ‘int velex(ve::ValueExpressionParser::semantic_type*, ve::location*, ValueExpressionDriver&)’: lex.ve.c:8888: warning: use of old-style cast lex.ve.c:8888: warning: use of old-style cast lex.ve.c:8905: warning: use of old-style cast lex.ve.c:8918: warning: use of old-style cast lex.ve.c:9368: warning: use of old-style cast lex.ve.c: In function ‘int yy_get_next_buffer()’: lex.ve.c:9547: warning: use of old-style cast lex.ve.c:9570: warning: use of old-style cast lex.ve.c:9583: warning: use of old-style cast lex.ve.c:9583: warning: use of old-style cast lex.ve.c:9604: warning: use of old-style cast lex.ve.c:9604: warning: use of old-style cast lex.ve.c:9629: warning: use of old-style cast lex.ve.c:9632: warning: use of old-style cast lex.ve.c:9632: warning: use of old-style cast lex.ve.c: In function ‘yy_state_type yy_get_previous_state()’: lex.ve.c:9667: warning: use of old-style cast lex.ve.c:9667: warning: use of old-style cast lex.ve.c: In function ‘int yyinput()’: lex.ve.c:9785: warning: use of old-style cast lex.ve.c: In function ‘yy_buffer_state* ve_create_buffer(FILE*, int)’: lex.ve.c:9884: warning: use of old-style cast lex.ve.c:9893: warning: use of old-style cast lex.ve.c: In function ‘void ve_delete_buffer(yy_buffer_state*)’: lex.ve.c:9919: warning: use of old-style cast lex.ve.c:9922: warning: use of old-style cast lex.ve.c:9924: warning: use of old-style cast lex.ve.c: In function ‘void veensure_buffer_stack()’: lex.ve.c:10091: warning: use of old-style cast lex.ve.c:10111: warning: use of old-style cast lex.ve.c: In function ‘yy_buffer_state* ve_scan_buffer(char*, yy_size_t)’: lex.ve.c:10139: warning: use of old-style cast lex.ve.c: In function ‘yy_buffer_state* ve_scan_bytes(const char*, int)’: lex.ve.c:10192: warning: use of old-style cast lex.ve.c: In function ‘void yy_push_state(int)’: lex.ve.c:10228: warning: use of old-style cast lex.ve.c:10231: warning: use of old-style cast lex.ve.c:10231: warning: use of old-style cast lex.ve.c: In function ‘int yy_init_globals()’: lex.ve.c:10398: warning: use of old-style cast lex.ve.c:10411: warning: use of old-style cast lex.ve.c:10412: warning: use of old-style cast lex.ve.c: In function ‘void* vealloc(yy_size_t)’: lex.ve.c:10478: warning: use of old-style cast lex.ve.c: In function ‘void* verealloc(void*, yy_size_t)’: lex.ve.c:10490: warning: use of old-style cast lex.ve.c:10490: warning: use of old-style cast lex.ve.c: In function ‘void vefree(void*)’: lex.ve.c:10495: warning: use of old-style cast lex.ve.c: At global scope: lex.ve.c:10215: warning: ‘void yy_push_state(int)’ defined but not used lex.ve.c:10243: warning: ‘void yy_pop_state()’ defined but not used lex.ve.c:10255: warning: ‘int yy_top_state()’ defined but not used SOURCE=ValueExpressionDriver.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ValueExpressionDriver.o In file included from location.hh:44, from ValueExpressionParser.tab.hh:65, from ValueExpressionDriver.H:14, from ValueExpressionDriver.C:3: position.hh: In function ‘bool ve::operator==(const ve::position&, const ve::position&)’: position.hh:136: warning: suggest parentheses around && within || SOURCE=funkySetFields.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/funkySetFields.o In file included from location.hh:44, from ValueExpressionParser.tab.hh:65, from ValueExpressionDriver.H:14, from funkySetFields.C:41: position.hh: In function ‘bool ve::operator==(const ve::position&, const ve::position&)’: position.hh:136: warning: suggest parentheses around && within || g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/HiWi/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/ValueExpressionParser.o Make/linux64GccDPOpt/ValueExpressionLexer.o Make/linux64GccDPOpt/ValueExpressionDriver.o Make/linux64GccDPOpt/funkySetFields.o -L/home/HiWi/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt \ -lfiniteVolume -lmeshTools -lOpenFOAM -liberty -ldl -lm -o /home/HiWi/OpenFOAM/hiwi-1.6/applications/bin/linux64GccDPOpt/funkySetFields /usr/bin/ld: cannot open output file /home/HiWi/OpenFOAM/hiwi-1.6/applications/bin/linux64GccDPOpt/funkySetFields: Permission denied collect2: ld returned 1 exit status make: *** [/home/HiWi/OpenFOAM/hiwi-1.6/applications/bin/linux64GccDPOpt/funkySetFields] Fehler 1 Thanks. Last edited by querdynamik; May 18, 2010 at 05:52. |
May 18, 2010, 06:48 |
#31 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Bernhard |
May 18, 2010, 07:56 |
#32 | |
C.Z.
Rep Power: 16 |
Now it compiled without errors. Thank you very much, again ! |
August 11, 2010, 04:18 |
funkySetFields and OpenFOAM 1.7.0
#33 |
Kelvin Loh
Rep Power: 17 |
Hi all,
Tried to compile the FSF library and encountered the same error as the post previously about it being calling overloaded function. I can't figure out what's wrong... Anyone here willing to help? Thanks. Regards, Kelvin Code:
SOURCE=ValueExpressionDriver.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -I/home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ValueExpressionDriver.o In file included from location.hh:44, from ValueExpressionParser.tab.hh:65, from ValueExpressionDriver.H:14, from ValueExpressionDriver.C:3: position.hh: In function ‘bool ve::operator==(const ve::position&, const ve::position&)’: position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’ ValueExpressionDriver.C: In member function ‘Foam::surfaceScalarField* ValueExpressionDriver::makeAreaField()’: ValueExpressionDriver.C:462: error: call of overloaded ‘GeometricField(Foam::IOobject, const Foam::fvMesh&, int)’ is ambiguous /home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.C:420: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dictionary&) [with Type = double, PatchField = Foam::fvsPatchField, GeoMesh = Foam::surfaceMesh] /home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.C:256: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensioned<Type>&, const Foam::word&) [with Type = double, PatchField = Foam::fvsPatchField, GeoMesh = Foam::surfaceMesh] ValueExpressionDriver.C: In member function ‘Foam::volScalarField* ValueExpressionDriver::makeVolumeField()’: ValueExpressionDriver.C:482: error: call of overloaded ‘GeometricField(Foam::IOobject, const Foam::fvMesh&, int)’ is ambiguous /home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.C:420: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dictionary&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.C:256: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensioned<Type>&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] ValueExpressionDriver.C: In member function ‘Foam::volScalarField* ValueExpressionDriver::makeDistanceField()’: ValueExpressionDriver.C:506: error: call of overloaded ‘GeometricField(Foam::IOobject, const Foam::fvMesh&, int)’ is ambiguous /home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.C:420: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dictionary&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.C:256: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensioned<Type>&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] ValueExpressionDriver.C: In member function ‘Foam::volScalarField* ValueExpressionDriver::makeRDistanceField(const Foam::volVectorField&)’: ValueExpressionDriver.C:529: error: call of overloaded ‘GeometricField(Foam::IOobject, const Foam::fvMesh&, int)’ is ambiguous /home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.C:420: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dictionary&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] /home/kklloh/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.C:256: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const typename GeoMesh::Mesh&, const Foam::dimensioned<Type>&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh] make: *** [Make/linux64GccDPOpt/ValueExpressionDriver.o] Error 1 |
August 11, 2010, 05:24 |
#34 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The most interesing information required would be: version of bison and version of funkySetFields (where you got it from)
August 11, 2010, 05:35 |
#35 | |
Kelvin Loh
Rep Power: 17 |
As added information, the bison version I have is 2.4.1, flex 2.5.35, and FSF from the OpenFOAM extend project, which I got from the source file "ICE Revision: $Id: funkySetFields.C 7567 2007-06-20 12:38:50Z bgschaid $" Am compiling FSF in OF 1.7.0 with 64-bit Fedora Core 13 OS. Thanks. Regards, Kelvin |
August 11, 2010, 10:49 |
#36 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
You're using the version from the OF 1.6-Breeder are you? That compiles on my 1.7 without problems. The error message indicates a version mismatch (a constructor is called which is not present in your current OF-version) |
August 24, 2010, 14:09 |
#37 |
G B
Rep Power: 16 |
yes, i'm back with more funky set fields trouble. This time im actually getting the same error as the original poster, i.e, floating point exception. And i know what is causing it exactly, i just can't fathom why.
ill write my funkysetfields dict here, the abbreviate version: Code:
temperature1 { field T; expression "52.96281*(pow(pos().z,0.262054))+273"; condition "pos().x <= 0.0105"; keepPatches 1; } This is the error message Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/home/gustavo/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/gustavo/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 in "/lib/libc.so.6" #3 in "/lib/libm.so.6" #4 Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, double const&) in "/home/gustavo/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #5 in "/home/gustavo/OpenFOAM/gustavo-1.6.x/applications/bin/linux64GccDPOpt/funkySetFields" #6 in "/home/gustavo/OpenFOAM/gustavo-1.6.x/applications/bin/linux64GccDPOpt/funkySetFields" #7 in "/home/gustavo/OpenFOAM/gustavo-1.6.x/applications/bin/linux64GccDPOpt/funkySetFields" #8 in "/home/gustavo/OpenFOAM/gustavo-1.6.x/applications/bin/linux64GccDPOpt/funkySetFields" #9 in "/home/gustavo/OpenFOAM/gustavo-1.6.x/applications/bin/linux64GccDPOpt/funkySetFields" #10 __libc_start_main in "/lib/libc.so.6" #11 at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exceptio Thanks for your time GB |
August 24, 2010, 19:22 |
#38 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
pos().z and check whether the result is definitely bigger than 0 for your mesh Bernhard |
August 25, 2010, 12:05 |
#39 |
G B
Rep Power: 16 |
Hello Bernhard, thanks for your reply (and sorry for taking so much time). It indeed is positive as expected. Ill try other values of z to see how the problem develops. I still find it peculiar that it woudl work with 25 and not 15.
Thanks again UPDATE: i discovered it works on funky set fields from 18 onwards. 17 already gives floating point exception. But ill post this here for everyone to see: http://www.wolframalpha.com/input/?i=plot+52.96281*%28z^0.262054%29+from+0+to+0.15 Why is it giving floating point exception? This must have such a simple reason. Last edited by Disco_Caine; August 25, 2010 at 12:23. Reason: update |
August 25, 2010, 12:49 |
#40 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
- modify OF-sources to print out intermediate results - use a Debug-version of OF, a core-dump and gdb to have a look at the backtrace - by trial and error try expressions of the form "pow(0.0345,0.262054)" to find a value that fails (start with the largest and smallest values from the previous experiment) OK. That's three possibilities, but who's counting. Anyway. As far as I can tell it is either a problem with pow or a problem with the expression (but you ruled that out) but not a problem of FSF per see BTW: have you tried it with different powers? ( 0.1, 0, 1, 2 ...) |
funkysetfields, installation, valueexpressionparser, wmake |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
Install OF 1.6.ext on Arch based distribution | miro2000 | OpenFOAM Installation | 4 | October 9, 2013 15:39 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 21:16 |
[swak4Foam] installing funkySetFields utility for OpenFOAM 1.4.1 | ozie | OpenFOAM Community Contributions | 8 | September 8, 2011 12:16 |
