[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh
Like Tree6Likes
Old   March 28, 2010, 05:38
Default Mixed BC - Heat transfer
  #121
bhh
Bjorn H. Hjertager
bhh is on a distinguished road
I am working with heat transfer in solid material and using laplacianFoam. I have the possibility to impose
1) fixed temperature and
2) fixed temperature gradient (fixed heat flux (dT/dn)_w = q_w/k; q_w is given, k is the conductivity of the solid material) on the walls.
Often it is needed to set the heat flux on a boundary given by the heat transfer coefficient (h) and the outside temperature(T_inf)
3) (dT/dn)_w=h/k (T_w -T_inf). h and T_inf are given, k is the conductivity of the solid material and T_w is the wall temperature (Varies during the computations and along BC patch).
Will it be possible to use groovyBC? If yes, do you have any hints?
regards
Bjorn
bhh is offline   Reply With Quote
Old   April 12, 2010, 08:33
thomasduerr is on a distinguished road
Hi all,
I have a similar question, how is it possible to use groovyBC for a constant heat flux q, can maybe anybody give a quick example?
Thanks a lot!!
Thomas
thomasduerr is offline   Reply With Quote
Old   April 12, 2010, 08:50
bhh
Bjorn H. Hjertager
Hi Thomas,
If you want to impose constant flux in laplacianFoam you can use fixedGradient as indicated in point 2) above. This applies also for all solvers where the energy (enthalpy) equation is solved for. In these solvers the fixedGradient will be the constant heat flux.
rgds
Bjorn
Old   April 13, 2010, 21:38
Michael Jaworski
mike_jaworski is on a distinguished road
I have a solver that keeps the conductivity as a separate field for temperature variable material properties.
I use the following with GroovyBC to make a specified heat flux boundary:
gradientExpression "(pos().x<strikePt)? 1/k*(peak*exp((pos().x-strikePt)/decayPFZ)+offset-epsilon*Aeff*sigma*(pow((T+273),4)-pow(T0,4))-massFlux*h_fg*Aeff): 1/k*(peak*exp(-(pos().x-strikePt)/decayL)+offset-epsilon*Aeff*sigma*(pow((T+273),4)-pow(T0,4))-massFlux*h_fg*Aeff)";
      valueExpression "210";
      //      gradientExpression "250*sin(pos().x/decay*pi)+250";
      fractionExpression "0";
I have some of the time varying files that specific what's going on with some of the variables, but this is the gist of it. Basically, q = -k grad T at the boundary. You should be able to move things around to make a convection BC if you're reading in the variables (I have radiation in this one).
-Mike
mike_jaworski is offline   Reply With Quote
Old   April 28, 2010, 15:31
Evren
pbe_cfd is on a distinguished road
I use OF 1.6, groovyBC for OF1.6 and bison 2.3 (due to incompatibility of OS in compute servers and bison 2.4.1). I could compile groovyBC by commenting out groovyBCFvPatchFields.C in files, otherwise i get some errors. Finally, I got the test case "groovyWaveTank" from openfoamwiki. However, when I run <setFields>, I get the following error
Reading setFieldsDict
Setting field default values
Setting volScalarField gamma
Setting volVectorField U
Cannot find 'value' entry on patch inlet of field U in file "/home/doncamillo/ebayrakt/OpenFOAM/ebayrakt-1.6/run/run/groovyWaveTank/0/U"
which is required to set the values of the generic patch field.
(Actual type groovyBC)
Please add the 'value' entry to the write function of the user-defined boundary-condition
or link the boundary-condition into libfoamUtil.so
file: /home/doncamillo/ebayrakt/OpenFOAM/ebayrakt-1.6/run/run/groovyWaveTank/0/U::inlet from line 26 to line 29.
From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&)
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 72.
FOAM exiting
Has someone experienced a similar problem or I am the lucky guy? :-) looking forward to some enlightening ideas...
Cheers,
Evren
pbe_cfd is offline   Reply With Quote
Old   April 28, 2010, 17:43
Assistant Moderator
Bernhard Gschaider
Originally Posted by pbe_cfd View Post
And THAT is the problem. Because groovyBCFvPatchFields.C is where the action is. Without it there is no groovyBC (which is what OF is telling you with "generic patch field")
I think you'll have to fix these first. What kind of errors?
Bernhard
Old   May 7, 2010, 10:23
yannH
yannH is on a distinguished road
Hi Bernhard and everyone,
Firstly congratulations for your work on groovyBC !
I'm actually working on breaking waves and I use FunkySetFields to initiate an unsteady stokes waves (3rd order), and using variable is not possible, so I spend a lot of time calculating expressions, re-writing it etc...
So you're gonna ask what's the purpose in a topic about groovyBC ?
I would like to have variables like in groovyBC for my conditions like :
interfaceAlpha
{ field alpha1 0;
expression "1";
condition "pos().y <= d + A*cos(k*pos().x) + 0.5*k*A*A*cos(2*(k*pos().x)) + 0.375*k*k*A*A*A*cos(3*(k*pos().x)) " ? 1 : 1;
variables "A = 0.1 ; L=20 ; k = 2*pi/L ; d = 15;";
I've already looked on groovyBC files to "copy" functions for variables into FunkySetFields files, but I'm not an expert of C++.
I know my questions looks like hua's one on reply #13, but is there an easy way to implement it or can you give me the first step to do it?
best regards,
Yann
yannH is offline   Reply With Quote
Old   May 10, 2010, 06:19
Assistant Moderator
Bernhard Gschaider
interfaceAlpha
{ field alpha1 0;
expression "1";
best regards,
Yann
In principle variables are there: just create new fields A, L etc on disc and use them in your final expression. This can be done in one file using:
http://openfoamwiki.net/index.php/Co...ctionary_usage
Of course creating unneeded files on disc is not the best solution, but recent versions of FSF cache fields in memory so the solution would be to "create" fields in the dictionary that are not written to disc. This only requires minor modifications and if a bugReport/featureRequest torns up on http://sourceforge.net/apps/mantisbt...status_id%3D-2 I might find time to do it
Bernhard
Old   May 10, 2010, 12:00
yannH
I did with the dictionary usage. I saw it before but I haven't tought to use it like that! Nevertheless it would be better not creating files on the disc for sure.. anyway, thanks bernhard
best regards,
Yann
Old   May 14, 2010, 12:40
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
Anyone compile groovy and funky on an SGI Altix ICE 8200? I am trying to build using icpc 11.1, bison 2.1, flex 2.5.31, but am getting a bunch of errors. After reading through this thread, I think it is the version of bison. I've put in a request for the admins to upgrade to at least bison 2.3. Typical errors are, e.g.,
243 harold-l1> wmake libso
/bin/sh: /usr/cta/unsupported/OpenFOAM/OpenFOAM-1.5-dev/wmake/rules/linux64Icc/wmkdep: No such file or directory
SOURCE=PatchResult.C ; icpc -DIntel -Dlinux64 -DDP -DFOAM_DEV_REVISION_NUMBER=1731 -wd584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fargument-noalias-global -unroll0 -DNoRepository -IMake/linux64IccDPOpt -DFOAM_DEV -I/usr/cta/unsupported/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/cta/unsupported/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/usr/cta/unsupported/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/PatchResult.o
SOURCE=PatchValueExpressionParser.yy ; rm -f Make/linux64IccDPOpt/PatchValueExpressionParser.C Make/linux64IccDPOpt/PatchValueExpressionParser.tab.hh; bison -ra -v -d $SOURCE ; mv *.tab.cc Make/linux64IccDPOpt/PatchValueExpressionParser.C ; mv *.tab.hh Make/linux64IccDPOpt/PatchValueExpressionParser.tab.hh ; mv *.hh Make/linux64IccDPOpt ; icpc -DIntel -Dlinux64 -DDP -DFOAM_DEV_REVISION_NUMBER=1731 -wd584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fargument-noalias-global -unroll0 -DNoRepository -IMake/linux64IccDPOpt -DFOAM_DEV -I/usr/cta/unsupported/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/cta/unsupported/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/usr/cta/unsupported/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -c Make/linux64IccDPOpt/PatchValueExpressionParser.C -o Make/linux64IccDPOpt/PatchValueExpressionParser.o
SOURCE=PatchValueExpressionLexer.ll ; rm Make/linux64IccDPOpt/PatchValueExpressionLexer.C ; flex -f $SOURCE ; mv *.c Make/linux64IccDPOpt/PatchValueExpressionLexer.C ; icpc -DIntel -Dlinux64 -DDP -DFOAM_DEV_REVISION_NUMBER=1731 -wd584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fargument-noalias-global -unroll0 -DNoRepository -IMake/linux64IccDPOpt -DFOAM_DEV -I/usr/cta/unsupported/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/cta/unsupported/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/usr/cta/unsupported/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -c Make/linux64IccDPOpt/PatchValueExpressionLexer.C -o Make/linux64IccDPOpt/PatchValueExpressionLexer.o
rm: cannot remove `Make/linux64IccDPOpt/PatchValueExpressionLexer.C': No such file or directory
lnInclude/PatchValueExpressionDriver.H(68): error: incomplete type is not allowed
YY_DECL;
lnInclude/PatchValueExpressionDriver.H(68): error: identifier "yylval" is undefined
YY_DECL;
lnInclude/PatchValueExpressionDriver.H(68): error: expected a ")"
YY_DECL;
PatchValueExpressionParser.tab.cc(504): error: expression must have (pointer-to-) function type
yylooka = yylex (&yylval, &yylloc, driver);
PatchValueExpressionParser.yy(650): error: incomplete type is not allowed
void pve::PatchValueExpressionParser::error (const pve::PatchValueExpressionParser::location_type& l,const std::string& m)
PatchValueExpressionParser.yy(652): error: identifier "driver" is undefined
driver.error (l, m);
YY_DECL;
YY_DECL;
YY_DECL;
lex.ve.c(9101): error: incomplete type is not allowed
YY_DECL
lex.ve.c(9101): error: variable "pvelex" has already been defined
YY_DECL
lex.ve.c(9101): error: expected a ")"
YY_DECL
lex.ve.c(9102): error: expected a ";"
lex.ve.c(9126): warning #12: parsing restarts here after previous syntax error
(yy_start) = 1; /* first start state */
egp is offline   Reply With Quote
Old   May 14, 2010, 14:09
Assistant Moderator
Bernhard Gschaider
<snipped>
YY_DECL;
YY_DECL;
YY_DECL;
Hi Eric!
I'm afraid your analysis is right (I remember this YY_DECL-thing and I think it was the same thing that caused the problems with funkySetFields). The best thing in this situation would be to cheat: bypass the old bison: Take the files generated on a machine with an up-to-date bison, put them onto the SGI and modify Make/files accordingly. There are some scripts in funkySetFields that do that (actually it's quite trivial), but obviously they'll have to be adapted (for a one-off you'll be faster doing this by hand)
Bernhard
Old   May 31, 2010, 08:40
Daniele
Daniele111 is on a distinguished road
I tried to compile this library but I have this message during compilation:
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file PatchResult.C
Making dependency list for source file PatchValueExpressionParser.yy
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy
Making dependency list for source file PatchValueExpressionLexer.ll
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionLexer.ll
Making dependency list for source file PatchValueExpressionDriver.C
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C
Making dependency list for source file groovyBCFvPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCFvPatchFields.C
Making dependency list for source file groovyBCPointPatchFields.C
could not open file MixedPointPatchField.H for source file groovyBCPointPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCPointPatchFields.C
could not open file PointPatchFieldMapper.H for source file groovyBCPointPatchFields.C
SOURCE=PatchResult.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/acconcia/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/acconcia/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/acconcia/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/PatchResult.o
PatchResult.C: In member function ‘void Foam::PatchResult::uglyDelete()’:
PatchResult.C:97: warning: deleting ‘void*’ is undefined
SOURCE=PatchValueExpressionParser.yy ; rm -f Make/linuxGccDPOpt/PatchValueExpressionParser.C Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh; bison -ra -v -d $SOURCE ; mv *.tab.cc Make/linuxGccDPOpt/PatchValueExpressionParser.C ; mv *.tab.hh Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh ; mv *.hh Make/linuxGccDPOpt ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/acconcia/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/acconcia/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/acconcia/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/PatchValueExpressionParser.C -o Make/linuxGccDPOpt/PatchValueExpressionParser.o
In file included from Make/linuxGccDPOpt/location.hh:44,
from PatchValueExpressionParser.tab.hh:65,
from PatchValueExpressionParser.tab.cc:61:
position.hh: In function ‘bool pve:perator==(const pve:osition&, const pve:osition&)’:
position.hh:136: warning: suggest parentheses around && within ||
PatchValueExpressionParser.tab.cc: In member function ‘unsigned char pve::PatchValueExpressionParser::yytranslate_(int) ’:
PatchValueExpressionParser.tab.cc:4941: warning: use of old-style cast
SOURCE=PatchValueExpressionLexer.ll ; rm Make/linuxGccDPOpt/PatchValueExpressionLexer.C ; flex -f $SOURCE ; mv *.c Make/linuxGccDPOpt/PatchValueExpressionLexer.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/acconcia/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/acconcia/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/acconcia/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/PatchValueExpressionLexer.C -o Make/linuxGccDPOpt/PatchValueExpressionLexer.o
rm: impossibile rimuovere `Make/linuxGccDPOpt/PatchValueExpressionLexer.C': Nessun file o directory
/bin/sh: flex: not found
mv: impossibile fare stat di `*.c': Nessun file o directory
g++: Make/linuxGccDPOpt/PatchValueExpressionLexer.C: Nessun file o directory
g++: no input files
make: *** [Make/linuxGccDPOpt/PatchValueExpressionLexer.o] Errore 1
it's correct?
Daniele111 is offline   Reply With Quote
Old   May 31, 2010, 08:53
yannH
g++: no input files
I think you have to install 'flex' first
Old   May 31, 2010, 09:09
Daniele
Thanks
What flex is?
Old   May 31, 2010, 09:30
yannH
I suggest you to search in the thread before posting, have a look at post #120. Otherwise, flex is a fast lexical analyser generator, you need it to compile groovyBC. ou can easily get it if you use a debian distribution by synaptic for example
Old   May 31, 2010, 09:42
Daniele
You are right, i serched but non all posts, thanks you
Old   June 5, 2010, 05:14
Default problem compiling groovyBC
  #137
Chrisi1984 is on a distinguished road
I also have a problem in compiling groovyBC. I am using OF 1.6.x.
I have bison (GNU Bison) 2.4.1 and flex 2.5.35.
I copied all the files of groovyBC from here https://openfoam-extend.svn.sourcefo...ries/groovyBC/.
and put it into my run folder. When I compile it I get the following error:
root@chrisilinux:~/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/groovyBC# wmake libso
make: *** Keine Regel vorhanden, um das Target »PatchValueExpressionDriver.dep«,
benötigt von »Make/linuxGccDPOpt/dependencies«, zu erstellen. Schluss.
I yet tried compiling with out coomented groovyBCPointPatchFields.C, but it did not help.
Can anyone help me compilling groovyBC?
Thanks in advance.
Regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   June 7, 2010, 05:41
Assistant Moderator
Bernhard Gschaider
Originally Posted by Chrisi1984 View Post
Thanks in advance.
Regards
Chrisi
Did you download the files one-by-one by hand? If so you might have missed PatchValueExpressionDriver.C (which would explain the error message)
Bernhard
Old   June 14, 2010, 13:50
Ovie Doro
ovie is on a distinguished road
Originally Posted by gschaider View Post
Hi Eric!
Bernhard
Please could you be more specific on how this can be done? Some of us dont just have a clue. I am trying to compile groovyBC on a cluster and the bison is not up to date. So I need help on implementing this bypass.
Thanks
ovie is offline   Reply With Quote
Old   June 14, 2010, 15:00
Assistant Moderator
Bernhard Gschaider
Thanks
Getting an object-file from a bison/flex-grammar is a two-step process:
1. bison/flex translates the grammar into a .c and .h file
2. the c-compiler compiles those files
Usually an out of date bison produces in step 1 a C-file that doesn't compile in step 2.
In groovyBC and funkySetFields both steps are done by one rule.
So the idea is to compile groovyBC on machine A with a working bison. Then copy the generated C/H-files to machine B. Modify Make/files there to skip bison/flex and directly compile the C-files.
For an example have a look at the sources of funkySetFields. The script getGenerated.sh is basically what should be done on machine A (filenames are slightly different). Script insertGenerated.sh is what should be done on machine B.
I think the scripts make pretty clear what should be done. If you don't understand them (which is OK, your job is CFD) go to your sysadmin. If your sysadmin has a problem with them: get a new sysadmin
Bernhard
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent Qingsong FLUENT 2 March 21, 2022 16:08
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[ICEM] Dynamic mesh setup with ICEM David121284 ANSYS Meshing & Geometry 0 April 11, 2014 05:19
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 23:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 09:03
