[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh
Like Tree6Likes
Old   March 3, 2010, 16:37
Philippose Rajan
philippose will become famous soon enough
Originally Posted by gschaider View Post
The ideal solution would be: you promise to behave, tell me your Sourceforge-account-name and I'll set you up for write access. Write access is not meant to be an ultra-exclusive club (the more the merrier), it's just that we want to be sure that people know what they're doing (which I assume, you do)
Bernhard
Hello Bernhard,
A Good Evening to you....!
I apologise for my silence and delay in replying to your post.... the last few days have been quite hectic at work, and on the Netgen Mesher front.
So... regarding the SVN access..... I think I should be able to manage the responsibility of write access to the repository :-)! As long as I can revert any accidental changes I might probably make, it should be fine....
I am currently a part of the Netgen Mesher project on Sourceforge, and since we use SVN there too, I am not new to SVN.
Wishing you a nice day ahead!
Philippose
philippose is offline   Reply With Quote
Old   March 3, 2010, 17:06
Default Making sure I'm using this correctly
  #102
Michael Jaworski
mike_jaworski is on a distinguished road
Hello groovy Foamers:
I have a quick question on the groovyBC because I want to make sure I'm using it correctly. groovyBC is really awesome, by the way.
Namely, I am implementing a heat flux boundary with it that includes radiation and evaporative power loss. In my solver, I have a field called "massFlux" which is a calculation based on the equilibrium vapor pressure, there is also a field called "k" for thermal conductivity.
So my groovyBC expression for the temperature field looks like this:
variables "epsilon=1;Aeff=1;sigma=5.67e-8;T0=273;h_fg=19.5e6;";
gradientExpression "<q_input_expression_not_important>-epsilon*Aeff*sigma*(pow((T+273),4)-pow(T0,4) ) - massFlux*h_fg*Aeff)/(internalField(k))";
valueExpression "300";
fractionExpression "0";
By the way, I found that by just defining gradientExpression, but not value and fraction, the BC would fail. Also, I had to add the libOpenFoam.so *before* having the groovyBC lib in the controlDict. I don't know why the order would matter, but it does for me.
So, my question is this: does this look about right? The units for the radiative and evaporation all work out to W/m2, which is the correct thing to use since the massFlux field is kg/(m2s).
[EDIT] More specifically, does the OpenFOAM and groovyBC framework apply the necessary mathematics to take the field values of massFlux, apply them to the boundary patch such that the equation above, massFlux*enthalpy of vaporization* area parameter come up correctly for a power flux?[/EDIT]
Input greatly appreciated.
Regards,
Mike Jaworski
mike_jaworski is offline   Reply With Quote
Old   March 4, 2010, 09:25
Assistant Moderator
Bernhard Gschaider
Originally Posted by bastil View Post
That seems to be an issue of the non-system bison 2.4.1 which does not work with the system m4. I tried the system bison 2.1 and now I get:
wmake
Making dependency list for source file ValueExpressionParser.yy
could not open file ValueExpressionParser.tab.hh for source file ValueExpressionParser.yy
Making dependency list for source file ValueExpressionLexer.ll
could not open file ValueExpressionParser.tab.hh for source file ValueExpressionLexer.ll
Making dependency list for source file ValueExpressionDriver.C
could not open file ValueExpressionParser.tab.hh for source file ValueExpressionDriver.C
Making dependency list for source file funkySetFields.C
could not open file ValueExpressionParser.tab.hh for source file funkySetFields.C
SOURCE=ValueExpressionParser.yy ; rm -f Make/linux64GccDPOpt/ValueExpressionParser.C Make/linux64GccDPOpt/ValueExpressionParser.tab.hh; bison -ra -v  -d $SOURCE ;  mv *.tab.cc Make/linux64GccDPOpt/ValueExpressionParser.C ; mv *.tab.hh Make/linux64GccDPOpt/ValueExpressionParser.tab.hh ; mv *.hh Make/linux64GccDPOpt ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/opt/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude   -fPIC -c  Make/linux64GccDPOpt/ValueExpressionParser.C -o Make/linux64GccDPOpt/ValueExpressionParser.o
In file included from ValueExpressionParser.yy:62,
                 from Make/linux64GccDPOpt/ValueExpressionParser.C:24:
./ValueExpressionDriver.H:23: error: incomplete type ‘ve::ValueExpressionParser’ used in nested name specifier
I'm not sure whether bison 2.1 is still sufficient (like it is stated on the Wiki). The problem is that some version changes in bison modify its C++ support in very subtle ways (I think I saw this problem once. Something with a namespace but I can't reproduce it as my "oldest" bison is 2.3)
Bernhard
Old   March 4, 2010, 09:30
Assistant Moderator
Bernhard Gschaider
Originally Posted by philippose View Post
Hello Bernhard,
Philippose
Perfect. You're set up for svn write-access. Welcome aboard
Bernhard
Old   March 4, 2010, 10:54
Assistant Moderator
Bernhard Gschaider
Namely, I am implementing a heat flux boundary with it that includes radiation and evaporative power loss. In my solver, I have a field called &quot;massFlux&quot; which is a calculation based on the equilibrium vapor pressure, there is also a field called &quot;k&quot; for thermal conductivity.
variables &quot;epsilon=1;Aeff=1;sigma=5.67e-8;T0=273;h_fg=19.5e6;&quot;;
gradientExpression &quot;<q_input_expression_not_important>-epsilon*Aeff*sigma*(pow((T+273),4)-pow(T0,4) ) - massFlux*h_fg*Aeff)/(internalField(k))&quot;;
valueExpression &quot;300&quot;;
fractionExpression &quot;0&quot;;
Regards,
Mike Jaworski
What groovy does is - get the current (it does not trigger any kind of calculation there) values from the other patches (in your case massFlux)
- manipulates them on a per-face basis (so in your case it does "massFlux[faceI]*enthalpy of vaporization[faceI]* area[faceI]" for all faceI
- the variables are expanded to fields the size of the patch and the above applies
Does this answer your question?
Old   March 4, 2010, 11:12
Michael Jaworski
Bernard, thank you. Yes. That's what I expected it to do, but I'm newbie enough to wonder.
-Mike
Old   March 11, 2010, 02:36
Default No success implementing boundary layer inlet profile yet
  #107
bjr
Ben Racine
bjr is on a distinguished road
Send a message via AIM to bjr Send a message via Skype™ to bjr
You can download a run that is known to "work" simply by issuing "simpleFoam" with OpenFOAM 1.6 and groovyBC at...
http://files.me.com/ben.racine/90cb5q
It appears to be working as far as compilation is concerned, but if you run it and check out the results you might see the odd pressure field and the reverse flow coming from the outlet towards the inlet.
This was my attempt to implement a velocity profile inlet condition in the spirit of the pulsedPitzDaily tutorial per: http://openfoamwiki.net/index.php/Co...ulsedPitzDaily
Any ideas and comments graciously welcomed,
Ben Racine
One can recover a somewhat physically reasonable run (no validation) by changing 0/U back to the original configuration as explicitly shown below...
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
#include "initialConditions"
dimensions [0 1 -1 0 0 0 0];
internalField uniform $flowVelocity;
boundaryField
//#include "fixedInlet"
inlet
type fixedValue;
value $internalField;
type inletOutlet;
inletValue uniform (10 0 0);
outlet
type inletOutlet;
inletValue uniform (0 0 0);
lowerWall
type fixedValue;
value uniform (0 0 0);
OBJECT_OBJECT
type fixedValue;
#include "frontBackUpperPatches"
bjr is offline   Reply With Quote
Old   March 12, 2010, 06:57
Default installation problems o
  #108
thomasduerr is on a distinguished road
Hi everybody,
it seems like I have similar problems as some of you with the installation of groovyBC. My error messages go:
Making dependency list for source file PatchResult.C
Making dependency list for source file PatchValueExpressionParser.yy
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy
Making dependency list for source file PatchValueExpressionLexer.ll
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionLexer.ll
Making dependency list for source file PatchValueExpressionDriver.C
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C
Making dependency list for source file groovyBCFvPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCFvPatchFields.C
SOURCE=PatchResult.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/export/opt/AS/OF/OpenFOAM-1.6.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/export/opt/AS/OF/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/export/opt/AS/OF/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/PatchResult.o
PatchResult.C: In member function ‘void Foam::PatchResult::uglyDelete()’:
PatchResult.C:97: warning: deleting ‘void*’ is undefined
SOURCE=PatchValueExpressionParser.yy ; rm -f Make/linux64GccDPOpt/PatchValueExpressionParser.C Make/linux64GccDPOpt/PatchValueExpressionParser.tab.hh; bison -v -d $SOURCE ; mv *.tab.cc Make/linux64GccDPOpt/PatchValueExpressionParser.C ; mv *.tab.hh Make/linux64GccDPOpt/PatchValueExpressionParser.tab.hh ; mv *.hh Make/linux64GccDPOpt ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/export/opt/AS/OF/OpenFOAM-1.6.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/export/opt/AS/OF/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/export/opt/AS/OF/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64GccDPOpt/PatchValueExpressionParser.C -o Make/linux64GccDPOpt/PatchValueExpressionParser.o
In file included from PatchValueExpressionParser.yy:52,
from Make/linux64GccDPOpt/PatchValueExpressionParser.C:24:
lnInclude/PatchValueExpressionDriver.H:68: error: incomplete type ‘pve::PatchValueExpressionParser’ used in nested name specifier
lnInclude/PatchValueExpressionDriver.H:68: error: ‘yylval’ was not declared in this scope
lnInclude/PatchValueExpressionDriver.H:68: error: expected primary-expression before ‘*’ token
lnInclude/PatchValueExpressionDriver.H:68: error: ‘yylloc’ was not declared in this scope
lnInclude/PatchValueExpressionDriver.H:68: error: expected primary-expression before ‘&’ token
lnInclude/PatchValueExpressionDriver.H:68: error: ‘driver’ was not declared in this scope
lnInclude/PatchValueExpressionDriver.H:68: error: initializer expression list treated as compound expression
PatchValueExpressionParser.tab.cc: In member function ‘virtual int yy::PatchValueExpressionParser:arse()’:
PatchValueExpressionParser.tab.cc:504: error: ‘pvelex’ cannot be used as a function
PatchValueExpressionParser.tab.cc: In member function ‘unsigned char yy::PatchValueExpressionParser::yytranslate_(int)’ :
PatchValueExpressionParser.tab.cc:3981: warning: use of old-style cast
PatchValueExpressionParser.yy: At global scope:
PatchValueExpressionParser.yy:695: error: expected unqualified-id before ‘&’ token
PatchValueExpressionParser.yy:695: error: expected ‘,’ or ‘...’ before ‘&’ token
PatchValueExpressionParser.yy:695: error: invalid use of incomplete type ‘struct pve::PatchValueExpressionParser’
lnInclude/PatchValueExpressionDriver.H:63: error: forward declaration of ‘struct pve::PatchValueExpressionParser’
make: *** [Make/linux64GccDPOpt/PatchValueExpressionParser.o] Error 1
Like some of you wrote in the forum, I have tried commenting out the Make/files groovyBCPointPatchFields.C but no progress. I have Bison 2.1 is that the main problem?
Thanks for your help!
Thomas
thomasduerr is offline   Reply With Quote
Old   March 15, 2010, 06:27
Assistant Moderator
Bernhard Gschaider
Probably. The "oldest" bison I have available is 2.3 so I can't really test it. Anybody got experience with groovy and older bisons?
Old   March 15, 2010, 06:38
Assistant Moderator
Bernhard Gschaider
Ben Racine
What would be more interesting would be the actual expressions you're using (don't feel like looking at the complete case)
Bernhard
Old   March 15, 2010, 17:02
bjr
Ben Racine
In 0/U, the inlet condition that gives physical results...
inlet
type fixedValue;
And a groovy BC attempt to do the same thing that results in very odd flow-field... although the inlet is specified correctly.
inlet
type groovyBC;
variables "zp=pts().z;minZ=min(zp);maxZ=max(zp);power=1.0*no rmal();";
valueExpression "90*power";
Where...
internalField uniform (90 0 0);
A cleaned up version (still run with just simpleFoam) with new geometry lives here if anybody cares to download it http://files.me.com/ben.racine/225fzi .
Old   March 16, 2010, 06:44
Assistant Moderator
Bernhard Gschaider
inlet
type fixedValue;
inlet
type groovyBC;
Where...
Just some comments:
- Why do you calclulate maxZ and minZ if you don't use them?
- Your formulation assumes that z is >=0?
- Have you had a look at the values on the patch on its own? Either by looking at the file (first written timestep) or by looking at paraview (deselect the internal mesh, select the patch)?
- If you post excerpts from a dictionary please enclose them in CODE-tags: I can't see the actual expression because the board interprets the curly brackets. The mail that it sends out doesn't show the text (so I had to piece together your posting from two sources)
Bernhard
Old   March 16, 2010, 13:51
Default This version works... negative sign to counteract outward normals on inlet?
  #113
bjr
Ben Racine
FoamFile
version 2.0;
format ascii;
location "0";
object U;
boundaryField
inlet
type groovyBC;
variables "zp=pts().z;minZ=min(zp);maxZ=max(zp);para=-pow(pos().z/0.390667,0.13)*normal();";
valueExpression "90*(1+0.00005*sin(500*time()))*para";
value uniform (90 0 0);
outlet
type inletOutlet;
lowerWall
type fixedValue;
OBJECT_patch0
type fixedValue;
Old   March 24, 2010, 17:34
Default Failed wmake libso attempt...
  #114
bjr
Ben Racine
I'm trying to install groovyBC on my cluster and get...
host2:~/OpenFOAM/openfoam-extend/trunk/Breeder_1.6/libraries/groovyBC # wmake libso
/usr/lib64/gcc/x86_64-suse-linux/4.4/cc1: /root/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib64/libppl_c.so.2)
/usr/lib64/gcc/x86_64-suse-linux/4.4/cc1: /root/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib64/libppl.so.7)
/usr/lib64/gcc/x86_64-suse-linux/4.4/cc1: /root/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib64/libgmpxx.so.4)
make: *** [linux64GccDPOpt/options] Error 1
make: *** [linux64GccDPOpt/files] Error 1
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created
host2:~/OpenFOAM/openfoam-extend/trunk/Breeder_1.6/libraries/groovyBC # bison -V
bison (GNU Bison) 2.3
Written by Robert Corbett and Richard Stallman.
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
host2:~/OpenFOAM/openfoam-extend/trunk/Breeder_1.6/libraries/groovyBC # flex -V
flex 2.5.35
Old   March 24, 2010, 18:02
Assistant Moderator
Bernhard Gschaider
This is not a problem wit groovyBC, but a problem with the libaries from your system (libppl_c.so.2) not fitting the standard-libraries that come with OpenFOAM (libstdc++.so.6). BTW: It looks like your using the system-compiler and not the OF-compiler. Is this intended?
Have you successfully compiled any other OF-Software on your Cluster?
Bernhard
Old   March 24, 2010, 18:20
bjr
Ben Racine
I have on my local machine, but not here on the cluster.
bjr
Ben Racine
host1:~/OpenFOAM/openfoam-extend/trunk/Breeder_1.6/libraries/groovyBC # which gcc
/root/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/gcc
host1:~/OpenFOAM/openfoam-extend/trunk/Breeder_1.6/libraries/groovyBC # gcc -v
Using built-in specs.
Target: x86_64-unknown-linux-gnu
Configured with: ../configure --enable-languages=c,c++ --with-pkgversion=OpenFOAM --enable-__cxa_atexit --enable-libstdcxx-allocator=new --with-system-zlib --prefix=/home/dm2/henry/OpenFOAM/ThirdParty/gcc-4.3.3/platforms/linux64 --with-mpfr=/home/dm2/henry/OpenFOAM/ThirdParty/mpfr-2.4.1/platforms/linux64 --with-gmp=/home/dm2/henry/OpenFOAM/ThirdParty/gmp-4.2.4/platforms/linux64
Thread model: posix
gcc version 4.3.3 (OpenFOAM)
Old   March 25, 2010, 03:22
hi everybody,
the newest Bison I could get on our systems is Bison 2.3.
I still get the same errors when compiling:
wmake libso
SOURCE=PatchResult.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/acrobat/webe_ol/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/acrobat/webe_ol/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/acrobat/webe_ol/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/PatchResult.o
SOURCE=PatchValueExpressionParser.yy ; rm -f Make/linux64GccDPOpt/PatchValueExpressionParser.C Make/linux64GccDPOpt/PatchValueExpressionParser.tab.hh; bison -v -d $SOURCE ; mv *.tab.cc Make/linux64GccDPOpt/PatchValueExpressionParser.C ; mv *.tab.hh Make/linux64GccDPOpt/PatchValueExpressionParser.tab.hh ; mv *.hh Make/linux64GccDPOpt ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/acrobat/webe_ol/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/acrobat/webe_ol/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/acrobat/webe_ol/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64GccDPOpt/PatchValueExpressionParser.C -o Make/linux64GccDPOpt/PatchValueExpressionParser.o
PatchValueExpressionParser.tab.cc: In member function ‘unsigned char pve::PatchValueExpressionParser::yytranslate_(int) ’:
PatchValueExpressionParser.tab.cc:4030: warning: use of old-style cast
SOURCE=PatchValueExpressionLexer.ll ; rm Make/linux64GccDPOpt/PatchValueExpressionLexer.C ; flex -f $SOURCE ; mv *.c Make/linux64GccDPOpt/PatchValueExpressionLexer.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt -I/home/acrobat/webe_ol/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/acrobat/webe_ol/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/acrobat/webe_ol/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64GccDPOpt/PatchValueExpressionLexer.C -o Make/linux64GccDPOpt/PatchValueExpressionLexer.o
rm: cannot remove `Make/linux64GccDPOpt/PatchValueExpressionLexer.C': No such file or directory
/bin/sh: flex: command not found
mv: cannot stat `*.c': No such file or directory
g++: Make/linux64GccDPOpt/PatchValueExpressionLexer.C: No such file or directory
g++: no input files
make: *** [Make/linux64GccDPOpt/PatchValueExpressionLexer.o] Error 1
Anybody got some ideas? It still looks like a bison problem, doesn't it?
Thanks
Thomas
Old   March 25, 2010, 05:10
Assistant Moderator
Bernhard Gschaider
Thread model: posix
Yeah. But in your original posting a cc1 (not sure what that is, I guess a compiler stage) from your systems installation (Susi, gcc 4.4) was complaining
Old   March 25, 2010, 05:12
Assistant Moderator
Bernhard Gschaider
hi everybody,
wmake libso
<snip>
g++: no input files
No. It's a missing-flex-problem. The "command not found" is a strong indication.
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent Qingsong FLUENT 2 March 21, 2022 16:08
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[ICEM] Dynamic mesh setup with ICEM David121284 ANSYS Meshing & Geometry 0 April 11, 2014 05:19
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 23:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 09:03
