[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh
Like Tree6Likes
Old   November 9, 2009, 06:19
Assistant Moderator
Bernhard Gschaider
Originally Posted by braennstroem View Post
thanks for the info! Shouldn't be so hard sounds good ...
But doesn't mean it will happen in the next days. Sorry.
Old   November 9, 2009, 06:22
Assistant Moderator
Bernhard Gschaider
Originally Posted by gautami View Post
I am trying to simulate a wave tank case in interDyMFoam.
I have set the inlet as groovyBC.
I want to set the expression for the inlet in pointMotionUx dictionary as follows:
if (time>1 and time<=2 expression-1) if (time>2 and time<3 expression-2) else zero.
I am trying to do it a follows,but I get an error.
valueExpression "toPoint((time()>1 && time()<=2) ? A*w*cos(w*time()) (time()>2 && time()<3) ? B*v*cos(w*time()) : 0 )";
How do I input such expression?
There is at least a ':' missing (between the first expression and the second condition)
Bernhard
Old   November 16, 2009, 15:39
Pierre-Olivier Dallaire
podallaire is on a distinguished road
Hi Bernhard,
I was playing with groovyBC today and it appears that "epsilon" was not
recognized whereas "k" was - am I missing something ?
Thanks !
PO
podallaire is offline   Reply With Quote
Old   November 17, 2009, 06:57
Assistant Moderator
Bernhard Gschaider
Originally Posted by podallaire View Post
Hi Bernhard,
I don't quite understand. You mean you have a boundary condition where the expression contains a k or an epsilon and for one it works and for the other it doesn't. Could you please be a bit more specific? When does it fail? Which field? Which solver?
I have a suspicion (the field has not yet been created in memory) but I need more information
Bernhard
Old   November 17, 2009, 08:30
I'm defining a BC condition in field nut at time=0 using k and epsilon, solver
is pisoFoam but you are right, if I'm using a turbulence model that is not loading epsilon, well I cannot use it - thanks for your comments. I forgot
about that yesterday when using kOmegaSST.
Regards,
PO
Old   December 2, 2009, 09:08
Default Got the WaveTank Demo worked on OF1.6
  #66
mks
mks is on a distinguished road
after some variations with gamma-alpha1 and some others I just got the demo WaveTank working. But the waves seem to stay in the tank (reflection on the outlet) and not to go "through" the wall. Any ideas how to fix (change) it?
mks is offline   Reply With Quote
Old   December 2, 2009, 15:23
Gautami Erukulla
gautami is on a distinguished road
Hello Mr Gschaider,
I am having a small trouble with valueExpression.
I need to specify flap wave maker expression for velocity="(y*(A/h)*w*cos(w*t))" of moving wall.
Baased on discussion earlier I understood that it has to be specified as follows:
valueExpression "toPoint((time()>0.0) ? pos().y*(A/h)*w*cos(w*time()) : 0)";--in the pointMotionUx dictionary.
valueExpression "((time()>0.0) ? toFace(pointMotionUx): 0 )"; ---in the cellMotionUx dictionary.
valueExpression "(time()>0.0) ? vector(toFace(pointMotionUx),0,0) : vector(0,0,0)";--in the U dictionary.
My simulation runs fine with no errors,but my results of free surface elevation is not quite satisfactory.
I may be wrong but I am thinking that it is because I am not specifying the expression correctly and so I tried to change my expression using pts().y as follows
valueExpression "(time()>0.0) ? pts().y*toPoint((A/h)*w*cos(w*time())) : 0";
but I get an error as follows
Parser Error at "1.15-17" :"syntax error, unexpected TOKEN_points"
Can you please suggest,how do I specify the flap wave maker velocity for the moving wall correctly.
Regards,
Gautami.
gautami is offline   Reply With Quote
Old   December 2, 2009, 17:29
Gautami Erukulla
Hello Mr Gschaider,
For the piston wave maker I need to specify the velocity=A*w*cos(w*t) for the moving wall
I have been doing this as follows:
valueExpression ""toPoint((time()>0.0) ? A*w*cos(w*time()) : 0)";--in the pointMotionUx dictionary.
My simulations run fine witout errors.
But for different values of A and w I dont not get the correct free surface elevation.For example the free surface elevation graph does not start from zero,instead it starts either above or below zero.
Can you please let me know if the problem is with the way I am specifying the expression or it is something else.
Regards,
Gautami.
Old   December 3, 2009, 05:28
Assistant Moderator
Bernhard Gschaider
Hello Mr Gschaider,
I need to specify flap wave maker expression for velocity=&quot;(y*(A/h)*w*cos(w*t))&quot; of moving wall.
valueExpression &quot;toPoint((time()>0.0) ? pos().y*(A/h)*w*cos(w*time()) : 0)&quot;;--in the pointMotionUx dictionary.
valueExpression &quot;((time()>0.0) ? toFace(pointMotionUx): 0 )&quot;; ---in the cellMotionUx dictionary.
valueExpression &quot;(time()>0.0) ? vector(toFace(pointMotionUx),0,0) : vector(0,0,0)&quot;;--in the U dictionary.
valueExpression &quot;(time()>0.0) ? pts().y*toPoint((A/h)*w*cos(w*time())) : 0&quot;;
Parser Error at &quot;1.15-17&quot; :&quot;syntax error, unexpected TOKEN_points&quot;
&quot; ^^^ &quot;
Regards,
Gautami.
Basically the problem seems to be that the first expression (time()>0) is a cell value and the parser therefor expects b and c in &quot;a ? b : c&quot; to be cell values, too. Enclose the condition with a toPoint and the constant at place c, too. (Havn't verified this, but am pretty sure that this is the problem)
Bernhard
Old   December 3, 2009, 05:33
Assistant Moderator
Bernhard Gschaider
Hello Mr Gschaider,
valueExpression &quot;&quot;toPoint((time()>0.0) ? A*w*cos(w*time()) : 0)&quot;;--in the pointMotionUx dictionary.
Regards,
Gautami.
I don't quite get the problem: cos(w*t) should be 1 for t=0, shouldn't it? If you want it to be zero, call it sin
Old   December 9, 2009, 14:08
Wolfgang W.
WiWo is on a distinguished road
Hello everybody,
I have started using groovyBC recently and I must say that it's really awesome! Thanks a lot for this contribution :-)
Anyway ... here comes my issue. I'm using dev-1.5 and groovyBC is getting along fine. But this week I was using groovyBC in connection with the icoFsiFoam solver, which is capable of doing fluid-structure-interaction as well as the respective mesh motion.
GroovyBC again worked fine in p and U - but what I need to do is have a definded transient wall deformation (which is possible by setting BC in motionU - I already succeeded using oscillationFixedValue but for my purpose I need more flexibility).
Now motionU is an object of tetPointVectorField class (not volScalarField or volVectorField as p or U) and groovyBC is refused with the following statement:
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: laplaceFaceDecomposition
Unknown patchField type groovyBC for patch type patch
Valid patchField types are :
15
symmetryPlane
oscillatingFixedValue
empty
fixedValue
mixed
componentMixed
processor
calculated
slip
timeVaryingUniformFixedValue
generic
value
global
wedge
zeroGradient
file: /home/wolfgang/Foams/playFoams/bloodVesselFSIsimple_longVessel_oscillating/fluid/0/motionU::topWall from line 41 to line 44.
From function PointPatchField<PatchField, Mesh, PointPatch, MatrixType, Type>::New(const PointPatch&, const DimensionedField<Type, Mesh>&, const dictionary&)
in file /home/wolfgang/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/newPointPatchField.C at line 221.
FOAM exiting
Is there anything I can do to make groovyBC work inside motionU? It would of course be fantastic to be able to define transient wall motion in an analytical way by using groovyBC.
Has anybody ever done such a thing or is this a stupid approach? I would be grateful for any advice or hint :-)
Cheers,
Wolfgang
WiWo is offline   Reply With Quote
Old   December 9, 2009, 17:43
Gautami Erukulla
Hello Mr Gschaider,
Thank you for your suggestions.Still working on it.Will let you know once I get good results.
Regards,
Gautami.
Old   December 11, 2009, 16:31
Philippose Rajan
philippose will become famous soon enough
Hello Gschaider,
A Good Evening to you!
I am surprised that though I have been using OpenFOAM for almost three years now, I have not had the opportunity to look into such an excellent contribution such as the groovyBC :-)!
I must say, it is seriously "groovy" :-)! Thanks a lot!
Recently I had the need to come up with a way of coupling two patches, such that the pressure on one patch (inlet), is dependent on the pressure on an another patch (outlet1) via a simple expression like:
p(inlet) = mean[p(outlet)]*m + c
After trying for a couple of hours to come up with a new boundary condition for OpenFOAM without success, I solved the problem by modifying my toplevel solver (in this case, simpleFoam) to read in a Master patch and Slave patch from a new dictionary file (called coupledPatchDict), along with a factor (m) and offset (c).
Continuing with my example,
.... Master patch = outlet1
.... Slave patch = inlet
.... m = 0.0
.... c = <a constant>
.... Slave patch = (Master patch)*m + c
This method worked very well, but I don't like that fact that the implementation is so specific..... starting from modification of a top-level solver, to the fact that as of now I can only specify one master patch and one slave patch, and also, that the field which is modified (in this case "p") is hard-coded into the modified solver.
Do you think it would be possible to extend the groovyBC boundary condition in order to support such coupled systems?
An additional entry like the timelines entry... for example "coupledPatches" or just "patches" could be used to specify something like:
patches (
.......... name <variable name to use within groovyBC expression>;
.......... patch <patch1>;
.......... field <field on patch to use>;
.......... component <component of field to use>; ---> in case of vectorField or "magnitude"?
What do you say?
Have a nice day!
Philippose
philippose is offline   Reply With Quote
Old   December 14, 2009, 08:13
Assistant Moderator
Bernhard Gschaider
Originally Posted by WiWo View Post
Hello everybody,
<cut>
<cut>
FOAM exiting
I'm afraid there is no trivial way to get this to work. tetPoint-Field is special to the dev-version and I'm not sure whether they map trivially to the point-Field (for which there is already a boundary-condition in groovyBC). You might get lucky if you copy the files from groovyBCpointPatchField to something like groovyBCtetPointPatchField and adapt those to use the corresponding tet-types. What will definitly not work with that approach is accessing other tetPoint-Fields (only volume and point), for that you'd have to modify the parser and the lexer.
Bernhard
Old   December 14, 2009, 08:28
Assistant Moderator
Bernhard Gschaider
patches (
I've been thinking about such an extension (actually it was requested by someone else some time ago) and will add it once I find the time to do so (it is not too hard, but I need to do some changes to the parser). The biggest restriction would be that from the other patch only a single value (an average, min, max or similar) could be used as for a general face-to-face mapping some serious checks would have to be done (how are the two patches aligned, have they conformal meshes) which would either result in a lot of code and/or terribly confusing options
Bernhard
Old   December 15, 2009, 07:44
Philippose Rajan
Hello Bernhard,
A Good Afternoon to you!
Cool :-)! So I am not the first to want something like this. I had looked around on the forum, but found no similar requirements from anyone else, and hence resorted to modifying the solver myself.
It is true that we can only expect to extract a single value from the Master patch. In my case, I took the area weighted average value of the pressure. I dont think it would be required to implement a generic mapping method.
I guess providing a couple of options like "min", "max", "mean", etc as part of the specification dictionary would suffice for most normal cases. adding on a dictionary key like "extract" should be sufficient.
Is there any way I can be of any help for implementing something like this into groovyBC? I briefly looked through the source files, but the parser part was literally "Greek and latin" for me :-)! Am not (yet) familiar with bison or yylexer, etc...
Have a nice day, and thank you for the response :-)!
Philippose
Old   December 15, 2009, 12:07
Assistant Moderator
Bernhard Gschaider
Hello Bernhard,
Basically what I'm intending to do is evaluate an expression on a remote patch and then apply one of those functions to it
Basically the problem is to rewrite the Driver-class in such a way that it can parse and evaluate stuff on a remote patch. In order to do this one has to introduce some subtle changes.
There are two ways you can help:
- provide me with a simple (preferably tutorial-based) test-case
- have patience
Bernhard
Old   February 16, 2010, 14:10
Philippose Rajan
Hello Bernhard,
A Very Good Evening to you :-)!
I just happened to be looking into the OpenFOAM-dev SVN repository, and found the changes you have made to GroovyBC :-)!
All I can say is.... wow :-)! You implemented the ability to couple patches via expressions!! Thank you very much!
On the other hand, I am feeling extremely sheepish now for not having sent you a test-case. I have no excuses for it except for "laziness", and I am very sorry...
Does this version of GroovyBC also work on OpenFOAM-1.5-dev? I have not yet started using OpenFOAM-1.6, and I prefer to stick to the "-dev" versions.
Shall try to compile the latest version of GroovyBC on OpenFOAM-1.5-dev, and let you know how it works out on the case I had.
I hope this time atleast I can post some pictures and a case too....
Once again.... thank you!
Have a nice evening ahead!
Philippose
Old   February 17, 2010, 14:19
Assistant Moderator
Bernhard Gschaider
Hello Bernhard,
Philippose
Hi Philippose!
No problem with the test-case. There is always a chance to make it up .
I think back-porting the changes to 1.5(-dev) should be rather easy (if I remember it correctly the majority of the effort to port groovy from 1.5 to 1.6 was modifying the demo-cases so that they work again). Should you succeed, you can check them into the SVN (that would be nice).
Bernhard
Old   February 17, 2010, 15:15
Philippose Rajan
Hello Bernhard,
Yet another Good Evening to you, though it could start getting a little warmer now :-)!! My eyes are getting bored of seeing black, white and grey... !!
I thought I would give you a first status update regarding the coupling facility you added to groovyBC recently:
1. I checked out the OF-1.6 version of groovyBC from SVN today, and directly, without making any changes, compiled it on OpenFOAM-1.5-dev.... Result: It worked without a hitch :-) So it looks like you could simply copy all the changes you made on the 1.6-branch of groovyBC to the 1.5-branch
2. Using help from the demo case which you set up to showcase this new feature, I modified my case for which I had used my modified simpleFoam solver earlier.... to use groovyBC together with the standard simpleFoam solver.... Result: It worked very well :-)! The fields converged to the same values I had seen earlier, and the groovyBC feature worked exactly as I hoped :-)!
3. An additional test-case for the repository.... I shall see if I can actually give out a modified version of the case I ran for inclusion into the groovyBC suite.
4. For others who might want to try out this cool feature.... here are my "0/p", "0/U" and "system/controlDict" files.....
*** "0/p" file -->
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 2352.9411;  // 20 bar
boundaryField
    fixedWalls
        type            zeroGradient;
    inlet
        type            groovyBC;
        valueExpression "pLS+(9.5*100000.0/850.0)";
        variables       "pLS@outletLS=sum(p*mag(Sf()))/sum(mag(Sf()));";    // Calculates the average value of p at the LS patch
        value           uniform 2352.9411;
    outlet
        type            fixedValue;
        value           $internalField;
    outletLS
        type            zeroGradient;
*** "0/U" file -->
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    fixedWalls
        type            fixedValue;
        value           uniform (0 0 0);
    inlet
        type            pressureInletVelocity;
    outlet
        type            zeroGradient;
    outletLS
        type            fixedValue;
        value           uniform (0 0.67905 0);
*** "system/controlDict" file -->
application     simpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         2000;
deltaT          1;
writeControl    timeStep;
writeInterval   10;
purgeWrite      2;
writeFormat     ascii;
writePrecision  6;
writeCompression compressed;
timeFormat      general;
timePrecision   6;
graphFormat     gnuplot;
runTimeModifiable yes;
libs ("libgroovyBC.so");
functions
    massFlow
        type patchMassFlow;
        functionObjectLibs ("libsimpleFunctionObjects.so");
        verbose true;
        patches
           inlet
           outlet
           outletLS
        factor 60000.0;
5. I shall post screenshots of the current case which I ran as soon as Paraview has finished compiling on my system (its busy right now :-)!)
Have a great day ahead!
Philippose
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent Qingsong FLUENT 2 March 21, 2022 16:08
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[ICEM] Dynamic mesh setup with ICEM David121284 ANSYS Meshing & Geometry 0 April 11, 2014 05:19
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 23:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 09:03
