February 3, 2011, 09:30 |
#201 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Bernhard |
February 3, 2011, 09:56 |
#202 |
Rep Power: 16 |
Hello
Thanks for replying. The problem occurs immediately, and yes, I did change the type from cyclic to wall in the blockMeshDict and boundary files. Also, when I comment out fractionExpression, while leaving the other lines the same (ie type groovyBC etc.), I still get the error. Thanks, gk Error log: Create time Create mesh for time = 0 Reading combustion properties Found ignition cells: 8(43926 40685 40686 40687 40866 43925 43927 44106) Ignition on Reading g Reading thermophysical properties Selecting thermodynamics package hhuMixtureThermo<homogeneousMixture<sutherlandTran sport<specieThermo<janafThermo<perfectGas>>>>> --> FOAM FATAL ERROR: attempt to use janafThermo<equationOfState> out of temperature range 200 -> 5000; T = 0 |
February 3, 2011, 11:00 |
#203 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
value uniform 298.15; to the boundaries. To make sure that the thermophysical model has SOME value as long as the boundaryCondition has not been updated. If that does not work try replacing the value expressions "Tinf" with "298.15" (but that would be a very weird bug in groovyBC) Bernhard |
February 3, 2011, 11:43 |
#204 |
Rep Power: 16 |
Hi Bernhard,
Thanks for your reply. Adding the value did seem to avoid the janafThermo error, but then I got the following: Time = 1.19999e-07 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 4.54047e-07, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 5.33651e-07, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 5.62639e-07, No Iterations 1 Max St-Courant Number = 7.86145e-06 Igniting cell 43926 state : 1 1 0.135 2.12673e-13 Igniting cell 40685 state : 1 1 0.135 1.47286e-13 Igniting cell 40686 state : 1 1 0.135 1.65015e-13 Igniting cell 40687 state : 1 1 0.135 2.17713e-13 Igniting cell 40866 state : 1 1 0.135 1.40006e-13 Igniting cell 43925 state : 1 1 0.135 4.56461e-13 Igniting cell 43927 state : 1 1 0.135 2.50109e-13 Igniting cell 44106 state : 1 1 0.135 1.30268e-13 DILUPBiCG: Solving for b, Initial residual = 1, Final residual = 4.10428e-08, No Iterations 1 min(b) = 0.99976 DILUPBiCG: Solving for Su, Initial residual = 0.999999, Final residual = 7.40651e-07, No Iterations 21 DILUPBiCG: Solving for Xi, Initial residual = 1, Final residual = 4.13749e-08, No Iterations 19 max(Xi) = 1 max(XiEq) = 1.00103 Combustion progress = 6.34009e-07% --> FOAM FATAL ERROR: Parser Error at "1.1-2" :"field DT not existing or of wrong type" "DT*rho*cp" " ^^ " From function parsingValue in file PatchValueExpressionDriver.C at line 192. FOAM aborting (FOAM_ABORT set) #0 Foam::error:rintStack(Foam::Ostream&) in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::error::exit(int) in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so" #3 Foam::PatchValueExpressionDriver::error(pve::locat ion const&, std::string const&) in "/home/gk/OpenFOAM/gk-1.7.1/lib/linux64GccDPOpt/libgroovyBC.so" #4 pvelex(pve::PatchValueExpressionParser::semantic_t ype*, pve::location*, Foam::PatchValueExpressionDriver&) in "/home/gk/OpenFOAM/gk-1.7.1/lib/linux64GccDPOpt/libgroovyBC.so" #5 pve::PatchValueExpressionParser:arse() in "/home/gk/OpenFOAM/gk-1.7.1/lib/linux64GccDPOpt/libgroovyBC.so" #6 Foam::PatchValueExpressionDriver:arse(std::strin g const&) in "/home/gk/OpenFOAM/gk-1.7.1/lib/linux64GccDPOpt/libgroovyBC.so" #7 Foam::PatchValueExpressionDriver::evaluateVariable (Foam::word const&, Foam::string const&) in "/home/gk/OpenFOAM/gk-1.7.1/lib/linux64GccDPOpt/libgroovyBC.so" #8 Foam::PatchValueExpressionDriver::addVariables(Foa m::string const&, bool) in "/home/gk/OpenFOAM/gk-1.7.1/lib/linux64GccDPOpt/libgroovyBC.so" #9 Foam::groovyBCFvPatchField<double>::updateCoeffs() in "/home/gk/OpenFOAM/gk-1.7.1/lib/linux64GccDPOpt/libgroovyBC.so" #10 Foam::mixedFvPatchField<double>::evaluate(Foam::Ps tream::commsTypes) in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libcompressibleRASModels.so" #11 Foam::mixedUnburntEnthalpyFvPatchScalarField::upda teCoeffs() in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libreactionThermophysicalModels.so" #12 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensionSet const&) in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/XiFoam" #13 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricFi eld<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libfiniteVolume.so" #14 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libfiniteVolume.so" #15 Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libfiniteVolume.so" #16 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/XiFoam" #17 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/XiFoam" #18 in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/XiFoam" #19 __libc_start_main in "/lib/libc.so.6" #20 in "/home/gk/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/XiFoam" Aborted Any ideas? Thanks, gk |
February 3, 2011, 12:31 |
#205 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Well. It is perfectly OK for groovyBC to complain: DT is not one of your variables. If there is no volScalarField with that name in memory, what shall it do? Guess? |
February 3, 2011, 13:39 |
#206 |
Rep Power: 16 |
Hi
Thanks Bernhard . I had actually referred to this post: http://www.cfd-online.com/Forums/ope...acianfoam.html gk |
February 3, 2011, 17:54 |
#207 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
So you'll have to rework your expression Bernhard |
February 3, 2011, 19:04 |
#208 |
Rep Power: 16 |
Thanks a lot for your reply, Bernhard. I really appreciate it.
I tried to change the expression as: upperWall { type groovyBC; value uniform 293; gradientExpression "gradT"; fractionExpression "0"; variables "htot=100.0;Tinf=298.15;Cp=1000;k=alphaEff*rho*Cp; gradT=htot*(Tinf-T)/k;"; } I wasn't sure how to call Cp() inside the 0/T file, so defined a value for it, just to see if it works. However, I got the janafThermo error again: --> FOAM FATAL ERROR: attempt to use janafThermo<equationOfState> out of temperature range 100 -> 5000; T = 0 From function janafThermo<equationOfState>::checkT(const scalar T) const in file /home/gk/OpenFOAM/OpenFOAM-1.7.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 63. The code is based on a related post: http://www.cfd-online.com/Forums/ope...tml#post293538 Thanks, gk |
February 4, 2011, 15:51 |
#209 |
Rep Power: 16 |
I implemented the groovyBC in the XiFoam solver, and it appears to run fine; however, when I include radiation in the solver, and implement the BC, I get the following error: "field alphaEff not existing or of wrong type" which is weird, since all that I did was to include radiation, and because alphaEff is defined in turbulenceModel.H; but still the error seems to come up. Looking at a previous post, I replaced alphaEff with (alphat + alpha), then I get the error: Parser Error at "1.2-7" :"field alphat not existing or of wrong type" "(alphat + alpha)* rho* cp" " ^^^^^^ " which is possibly because alphat is not defined in turbulenceModel.H Has anyone faced a similar problem, and knows how to get rid of it? Thanks gk |
February 4, 2011, 18:49 |
#210 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
February 4, 2011, 19:07 |
#211 |
Rep Power: 16 |
Hi Bernhard
Thanks for replying. Actually, the BC does work (while using alphaEff in the BC definition) when I use the XiFoam solver that is provided with OpenFoam. Surprisingly, however, once I include radiation effects, it does not. Anyway, I'll try to see if alphat can be defined in the turbulence model. Thank you, gk |
February 7, 2011, 03:37 |
frequency of sine-wave
#212 |
Patrik
Hi all, in pulsed pitzdaily the sine-wave has the expression:
"1*(1+0.5*sin(500*time()))*para"; What frequency does this represent, i.e. How long is one period over time. I would like to have one period to be 4/3 s but cant figure it out. Sorry to bother you with quite a rudimentary mathematical problem like this. |
February 7, 2011, 11:38 |
#213 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
February 16, 2011, 12:44 |
Groovy BC +Wavetank
#214 |
Ramesh Yapalparvi
Rep Power: 17 |
Hi all,
I am trying to run this demo groovywave tank and I seem to be getting the following error Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Calculating field g.h time step continuity errors : sum local = 0, global = 0, cumulative = 0 Attempt to return dictionary entry as a primitive file: /home/ramesh/OpenFOAM/ramesh-1.5/run/tutorials/interFoam/groovyWaveTank/system/fvSolution:corr:reconditioner from line 23 to line 35. From function ITstream& primitiveEntry::stream() const in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 83. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/home/ramesh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::IOerror::abort() in "/home/ramesh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::dictionaryEntry::stream() const in "/home/ramesh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #3 Foam::dictionary::lookup(Foam::word const&, bool) const in "/home/ramesh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/ramesh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/ramesh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so" #6 main in "/home/ramesh/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/interFoam" #7 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #8 _start at /build/buildd/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 Aborted |
February 16, 2011, 18:59 |
#215 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
March 1, 2011, 07:09 |
#216 |
Hi Foamers, and in particular groovyBc users,
I am quite new in using this great utility, and I need some hints from experts in it! I have to do some compressible simulations of rarefied gases in a channel, with rhoSimpleFoam. To take into account the rarefaction, I would like to use the following slip wall b.c. U_slip = {(2-sigma)/sigma * lambda * [d(U dot tau)/dn + d(U dot n)/dtau ]} tau , where U_slip is the velocity at wall, sigma is an accomodation coefficient, lambda the mean free path, tau and n the tangential and normal vector to the wall, dot is the scalar product. Reading the threads about the heat flux b.c. I immagine that groovyBc could solve my problem, but I have no idea on how to implement this formula in it. Could anyone give me some hint to do that? Thank you in advance, Ivan |
March 1, 2011, 09:10 |
#217 |
Rep Power: 17 |
hi this is an example of a parabolic inlet velocity type BC
inlet { type groovyBC; variables "Umax=1;c=pos().y;cc=1*c;d=pow(c,2);e=cc-d;speed=4*Umax*e;"; valueExpression "vector (speed, 0, 0)"; } you can do similarly by placing your expression. For differnet expressions syntax see: http://openfoamwiki.net/index.php/Contrib_groovyBC Good Luck ! T.D. |
March 1, 2011, 09:15 |
#218 | |
March 1, 2011, 14:09 |
#219 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Did I understand your formulation correctly that if you can calculate U_slip correctly from the current flow conditions, then you can set it on the boundary as a Dirichlet? Otherwise you'll have to reformulate it. But as I said: you'll have to play around (not sur how to implement the d/dTau in you equation) and I can't guarantee success Bernhard |
March 2, 2011, 04:57 |
#220 | |||
Hi Bernhard, and thank you for your answer.
Yes, I take a look there sometimes ago. Quote:
For d(U dot n)/dtau, maybe it could be rewritten as grad(U dot n) dot tau Any other ideas? I definitely hope that groovyBc would do the trick... Thanks, Ivan |
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent | Qingsong | FLUENT | 2 | March 21, 2022 16:08 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
[ICEM] Dynamic mesh setup with ICEM | David121284 | ANSYS Meshing & Geometry | 0 | April 11, 2014 05:19 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 23:09 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 09:03 |
