[cfMesh] Using cfMesh on HPC in parallel (with MPI) for large meshes - MPI_Bsend error
Old   December 8, 2024, 06:18
Post Using cfMesh on HPC in parallel (with MPI) for large meshes - MPI_Bsend error
standingVortex is on a distinguished road
Hello foamers,
I have been using cfMesh successfully for several years now (both on local machine and HPC environments), where I was creating medium size meshes without any problem whatsoever. This time however, I would like to create a large mesh with approx. 200M cells, which I would like to create on HPC environments - by using resources available across multiple nodes.
As far as I understand, cfMesh by default uses all available CPU resources on a single node through Shared Memory Parallelization (SMP) - using the OpenMP - but I believe that is no longer sufficient as the meshing procedure in my case is quite slow using that approach. Therefore I would like to use the MPI parallelization using let's say 5 nodes, where each node has 128 cores.
To do so, I did the following:
1) prepared the case as usual - FMS file preparation and specification of corresponding meshDict settings.
2) I ran the
preparePar
by specifying
numberOfSubdomains 5;
in decomposeParDict, as I would like to parallelize across 5 MPI tasks.
3) I prepared the cartesianMesh_SLURM.sh script for the SLURM job scheduler.
cartesianMesh_SLURM.sh:
#!/bin/bash
#SBATCH --nodes=5                # Total number of nodes requested
#SBATCH --ntasks-per-node=1      # 1 MPI task per node
#SBATCH --ntasks=5
#SBATCH --cpus-per-task=128  # Use all these cpus for intra-node parallelization handled by cfMesh by default
#SBATCH --time=72:00:00
#SBATCH --mem=300000
#SBATCH --exclusive
#SBATCH --contiguous
#SBATCH --error=cartesianMesh.err
#SBATCH --output=cartesianMesh.out
# Load appropriate modules and make OpenFOAM available
module load OpenFOAM/v2206
source $FOAM_BASH
solver=cartesianMesh
# Run cfMesh with hybrid MPI + OpenMP parallelization
mpirun -np 5 cartesianMesh -parallel >> log.cartesianMesh
The cartesianMesh starts running, but it crashes. Hereby the content of the corresponding log files.
log.cartesianMesh:
|  \\    /   O peration     | Version:  2206                                  |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
Build  : _76d719d1e6-20220624 OPENFOAM=2206 version=v2206
Arch   : "LSB;label=32;scalar=64"
Exec   : cartesianMesh -parallel
Date   : Dec 07 2024
Time   : 19:28:30
Host   : tcn941.local
PID    : 3685925
I/O    : uncollated
Case   : <path_to_rootFolder>
nProcs : 5
Hosts  :
    (tcn941.local 1)
    (tcn942.local 1)
    (tcn943.local 1)
    (tcn944.local 1)
    (tcn945.local 1)
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Setting root cube size and refinement parameters
Root box (-46192.4 -42195.6 -49707.5) (56207.6 60204.4 52692.5)
Requested cell size corresponds to octree level 10
Refining boundary
Refining boundary boxes to the given size
Number of leaves per processor 1
Distributing leaves to processors
Finished distributing leaves to processors
Distributing load between processors
Finished distributing load between processors
cartesianMesh.err:
[tcn942.local.snellius.surf.nl:3684931] pml_ucx.c:738  Error: bsend: failed to allocate buffer
[tcn942.local.snellius.surf.nl:3684931] pml_ucx.c:882  Error: ucx send failed: No pending message
[tcn942:3684931] *** An error occurred in MPI_Bsend
[tcn942:3684931] *** reported by process [3133276161,1]
[tcn942:3684931] *** on communicator MPI_COMM_WORLD
[tcn942:3684931] *** MPI_ERR_OTHER: known error not in list
[tcn942:3684931] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[tcn942:3684931] ***    and potentially your MPI job)
I couldn't understand where this error was coming from, thus after a bit of searching online I came across two different threads where it was suggested to specify OMP_NUM_THREADS and MPI_BUFFER_SIZE.
Therefore I also tried with adding the following piece of code into the SLURM script before executing cartesianMesh, but it was without any success as well.
# Set OpenMP environment variable
# => number of threads OpenMP will use for shared-memory parallelism on intra-node level
export OMP_NUM_THREADS=$SLURM_CPUS_PER_TASK,$SLURM_CPUS_PER_TASK # 128,128
# Set MPI buffer size
export MPI_BUFFER_SIZE=200000000
However, specifying MPI_BUFFER_SIZE and/or OMP_NUM_THREADS did not fix the issue, as I still cannot run the cartesianMesh in parallel using MPI.
I tried searching for a way of solving these MPI_Bsend/UCX issues, but unfortunately I didn't manage to understand what to do.
Does anyone have any idea, or suggestion to point out what am I actually doing wrong and how could one make using this amazing meshing tool on clusters with cfMesh using MPI and CPU resources distributed across multiple nodes for large meshes?
I would appreciate a lot any insights.
Thank you so much!
standingVortex is offline   Reply With Quote
cartesianmesh, cfmesh, hpc cluster, mpi, mpi errors
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
