[Other] Solid4FOAM query about FSI.
Old   November 6, 2024, 15:57
Default Solid4FOAM query about FSI.
Subodh
Subodh21 is on a distinguished road
I am new to FSI and recently started using solids4Foam and working on a fluid-structure interaction (FSI) problem, specifically the benchmark case "FSI between an Elastic Object and Laminar Incompressible Flow" by Turek and Hron (2006). This benchmark problem is featured in one of the solids4Foam tutorials, and I have successfully managed to run the simulation.
However, during post-processing, I observed that only the fluid mesh appears to be moving, while the solid mesh remains static. Upon further investigation, I discovered that the solid mesh is indeed set as static, while the fluid mesh is updated dynamically. The relevant configuration for the solid mesh is as follows:
FoamFile
version 2.0;
format ascii;
class dictionary;
object dynamicMeshDict;
dynamicFvMesh staticFvMesh;
I am trying to understand the reasoning behind having a static solid mesh in an FSI problem. Despite the solid mesh being static, I can see the interface moving. Could someone please help clarify why the solid mesh is considered static in this setup?
Thanks in advance!
Subodh21 is offline   Reply With Quote
Old   November 13, 2024, 06:43
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Subodh,
To show the deformed solid, you need to use the "Warp by Vector" filter in ParaView with the displacement field (D or pointD).
In this case, the solid model employs a total Lagrangian (static mesh) approach but calculates the true deformed geometry (which the fluid sees).
Philip
bigphil is offline   Reply With Quote
Old   December 4, 2024, 01:02
Subodh
Thanks I am able to run the simultion, but when i compare my result to the HuronTurek FSI case, I am finding the drag and lift values are significantly low, I have checked the material properties in both fluid and solid and they are matching , also I activated g in the solid. Is there anything I could be missing?
Old   December 4, 2024, 05:35
bigphil's Avatar
Philip Cardiff
Which versions of solids4foam and OpenFOAM are you using? Did you try solids4foam-v2.1 and OpenFOAM-v2312?
Old   December 4, 2024, 10:17
Subodh
I am using openFOAM9 and solid4Foamv2.1.
Old   December 4, 2024, 10:26
Subodh
This is the plot for my forces.
Old   December 4, 2024, 13:59
Subodh
Btw my friend who is using the version you suggested is seeing same issue of low drag and lift values.
[FSI] Sudden divergence of elastic pipe FSI MFWilliams OpenFOAM CC Toolkits for Fluid-Structure Interaction 1 June 16, 2022 12:35
[solids4Foam] FSI case does not converge, foam extend 4.0 MFWilliams OpenFOAM CC Toolkits for Fluid-Structure Interaction 12 May 13, 2022 09:35
Two way FSI related Query n.soumya ANSYS 0 July 24, 2018 03:50
FSI query CC CFX 2 September 1, 2008 02:31
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
