[cfMesh] creating a multi-patch airfoil in external flow mesh in 2D
Old   November 2, 2024, 10:53
Default creating a multi-patch airfoil in external flow mesh in 2D
TWB
quarkz is on a distinguished road
Hi, I'm trying to create an airfoil of special shape to simulate in an external flow. I have attached a picture of the airfoil. Btw, its sides are hollow.
So the top region is divided into 3 sections and I'm going to give them different boundary condition so they have to be named differently.
I can use cartesian2DMesh to create the mesh if the stl of the airfoil is a single region mesh. But I want to give different BC to different patches so I use a multi-patch stl, as mentioned here:
https://openfoamwiki.net/index.php/T...trization#Tips
I use surfaceFeatureEdges and the fms shows lots of regions which are empty:
7
wing_top_rear empty
mass_suc empty
wing_top_mid empty
Also, although the final mesh looks ok, it has lots of error as reported by checkMesh, such as negative cell volume, incorrectly orientation etc. I have attached the meshDict for reference. So how should i be done? Did I do something wrong somewhere?
Thanks.
quarkz is offline   Reply With Quote
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 7 September 18, 2024 06:52
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
[Gmsh] Gmsh - External Flow Mesh Generation - Airfoil STL file Eefoe OpenFOAM Meshing & Mesh Conversion 2 August 22, 2017 10:27
