[waves2Foam] install wave2foam infoam-extend 4.0 error
Old   Today, 01:28
Default install wave2foam infoam-extend 4.0 error
haozhibin
Hao Zhibin is on a distinguished road
When I install wave2foam in foam-extend-4.0, there are the following errors, please teachers, how can I solve ? Thank you teachers for answering.
/usr/bin/ld: 找不到 -lwaves2Foam
collect2: error: ld returned 1 exit status
/home/hzb/foam/foam-extend-4.0/wmake/Makefile:159: recipe for target '/home/hzb/foam/hzb-4.0/applications/bin/linux64GccDPOpt/setWaveField' failed
make[1]: *** [/home/hzb/foam/hzb-4.0/applications/bin/linux64GccDPOpt/setWaveField] Error 1
/home/hzb/foam/foam-extend-4.0/wmake/MakefileApps:39: recipe for target 'setWaveField' failed
make: *** [setWaveField] Error 2
make: 由于错误目标“application”并未重新制作。
COMPILE BREEDER
Nothing available for compilation in the breeder
directory.
COMPILATION DONE
Hao Zhibin is offline   Reply With Quote
wave2foam
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 13:46
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
