[waves2Foam] wave2Foam tutorial case waveFlume doesn't output correct wave shape
Old   March 12, 2024, 13:47
Default wave2Foam tutorial case waveFlume doesn't output correct wave shape
panda007 is on a distinguished road
Hi Neils,
I'm new to waves2Foam. I just got OpenFOAM-v2206 and waves2Foam set up in my windows subsystem Linux - ubuntu.
I tried the tutorial case waveFlume, standingWave, and 3Dwaves. The results look weird, and it's very obvious for the wave shape of waveFlume case. The wave interface for alpha.water=0.5 is not a smooth wave shape. The tutorial case was run as it was, and no modification was made to the case.
See attached screenshots.
Any idea why this happens and how to fix it?
panda007 is offline   Reply With Quote
Old   April 3, 2024, 16:30
I managed to figure this tutorial case issue out. I post it here in case other people encounter similar issues in the future.
The fix is actually simple, I tried many ways and eventually found out it was because of the tutorial case wave amplitude/wave height was too high compared to the water depth. The original waveheight was 0.1 in constant/waveProperties.input, after I changed it to 0.2, the wave are all normal now. I compared it with theoretical solution for stokesFirst, it's all right.
I'm not sure why the tutorial case set up that way and causes issues, but that's what I found.
waves2foam waveflume
pisoFoam tutorial case (RAS cavity) solution breaks down after 2.5s jtrg OpenFOAM Running, Solving & CFD 0 May 10, 2023 08:02
psi in the rhoThermo class cryabroad OpenFOAM Running, Solving & CFD 10 October 21, 2020 05:09
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
