May 19, 2023, 12:51 |
Edge problem
Mohamed Diop
Rep Power: 3 |
Hi ! I'm a beginner on both cfmesh and snappyHexMesh. I started first on Snappy and quickly faced boundary layer deletion problems. Due to my complex geometry, I turned to cfmesh which is efficient for boundary layers addition but it destroys my trailing edge. Is there any suggestion to correct this problem ? Check the pictures attached to see the problem. I've tried to refine the mesh (31M cells ) but it didn't solve the problem.
geometry.png geometry_post_cfmesh.png Last edited by momod; May 22, 2023 at 05:11. |
May 23, 2024, 09:31 |
#2 | |
Rep Power: 2 |
cfMesh is a bit particular about surface edges, normally they get lost in the stl file. Are you using a .fms file in this case? It is the preferred for cfMesh. To obtain it, you can use the following command: Quote:
Best of luck. |
Autogrid Leading Edge/Trailing Edge Wizard intersection problem | Fabisiko | Fidelity CFD | 2 | November 14, 2022 05:28 |
[ANSYS Meshing] Problem with creating Infaltion (Only Edge Selection) | Towe91 | ANSYS Meshing & Geometry | 1 | March 13, 2017 08:52 |
[ICEM] Problem in Edge meshing | Daniel_Khazaei | ANSYS Meshing & Geometry | 1 | October 17, 2013 07:45 |
[ANSYS Meshing] blocking 2D planar, problem associate edge to curve | hadrien51 | ANSYS Meshing & Geometry | 10 | February 21, 2012 13:37 |
Through-Flow solver, Leading-Trailing edge problem | Menander | Main CFD Forum | 0 | May 14, 2008 19:14 |
