[swak4Foam] swak4foam Installation Error on OpenFOAM 7 |
April 23, 2023, 03:03 |
Jonathan Adams
Rep Power: 3 |
Hello all,
I apologise if this has been asked before, but I've had no luck finding anything similar online, and I don't know where to go from here. I'm new to OpenFOAM, and I'm having an error installing swak4foam on OpenFOAM 7. I know the version is old, and newer versions may have better luck, but OF7 is the one I need to use for my project. OpenFOAM 7 is installed in my /home/ directory, and I'm using a relatively fresh install of Ubuntu 22.04.01, if that helps. I tried following Torsten Schenkel's tutorial on YouTube, which basically consisted of navigating to the OpenFOAM applications folder, and running: ''' hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam swak4Foam cd swak4Foam ./AllwmakeAll ''' Running this yields the error below. I can't really tell what the error is saying is wrong, nonetheless how to fix it: ''' Current OpenFOAM version is 7. This is a clean install /home/jonathan/OpenFOAM/OpenFOAM-7/applications/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison) Reading variables from 'swakConfiguration' Looking for Python 2 Looking for Python 3 Using our own Lua at /home/jonathan/OpenFOAM/OpenFOAM-7/applications/swak4Foam/privateRequirements Checking swak4Foam-version and generating file Swak version is 2021.05.0 hg info: af74ec7e1714 No 'bear' installed Bison: /home/jonathan/OpenFOAM/OpenFOAM-7/applications/swak4Foam/privateRequirements/bin/bison Flex: /usr/bin/flex Bison at /home/jonathan/OpenFOAM/OpenFOAM-7/applications/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4) Flex is version 2.6.4 (Minor version: 4) OpenFOAM-version: Major 7 Minor 0 Patch -1 (-1 == x / 98) Fork: org No swak4FoamParsers/foamVersion4swak.H. Generated Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem wmakeLnInclude: linking include files to simpleFunctionObjects/lnInclude wmake libso swak4FoamParsers /home/jonathan/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/options:52: /home/jonathan/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory make: *** No rule to make target '/home/jonathan/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/../myflex'. Stop. /home/jonathan/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/options:52: /home/jonathan/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory make: *** No rule to make target '/home/jonathan/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/../myflex'. Stop. wmake error: file '/home/jonathan/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/sourceFiles' could not be created in /home/jonathan/OpenFOAM/OpenFOAM-7/applications/swak4Foam/Libraries/swak4FoamParsers Parser library did not compile OK. No sense continuing as everything else depends on it Requirements for Library not satisfied. I see no sense in going on Check the README before you go on to ask. And search: Most likely your problem occurred to 5 other people before and has been solved on the MessageBoard ''' Initially I got the error that there was no binary 'python', which I was able to fix by installing python-is-python3, but now I get this, which has no clear message telling me what the error is. Any help would be very much appreciated. Thanks, Jon. Last edited by j.adams; April 23, 2023 at 03:08. Reason: Fixing formatting |
April 24, 2023, 00:17 |
Fixed!
Jonathan Adams
Rep Power: 3 |
Nevermind, all fixed now.
Using the github mirror of swak4foam seemed to work. |
August 30, 2024, 11:49 |
Saadbin Khan
Hi, which one of the clones are you using? Could you share the link? I am facing the same issue.
swak4foam |
[swak4Foam] Swak4FOAM installation for OpenFOAM v1806 | exx110 | OpenFOAM Community Contributions | 1 | July 5, 2021 21:07 |
[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM | steven123 | OpenFOAM Community Contributions | 35 | January 11, 2021 17:53 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
[Discussion] Restructuring the Installation page at openfoamwiki.net | wyldckat | OpenFOAM Installation | 16 | November 2, 2013 12:43 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
