[waves2Foam] Initial water level is not horizontal, but U shaped towards domain inlet and outlet
Old   April 19, 2023, 09:54
Unhappy Initial water level is not horizontal, but U shaped towards domain inlet and outlet
Nian
noodleluvmay is on a distinguished road
Hello there,
I am quite new to waves solver, so sorry in advance if the answer to this is obvious.
I have run the 2D waveFlume tutorial okay, now I have adapted the case to be 3D, as well as added a fixed object in the water domain.
However, the results seem to show I have not defined the water field properly, and that water is only present at the beginning and end sections of the domain, which I suspect is the relaxation zone I have added. Please see image1:
I am not completely sure why this is the case, could it maybe have been the boundary conditions I have set?
My blockMesh dict:
|  \\    /   O peration     | Version:  1.5                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    ( -3 -3 -1 )
    (  7 -3 -1 )
    ( -3  1 -1 )
    (  7  1 -1 )
    ( -3 -3  1 )
    (  7 -3  1 )
    ( -3  1  1 )
    (  7  1  1 )
blocks
    hex (0 1 3 2 4 5 7 6) ( 100 40 20 ) simpleGrading (1 1 1)
edges
patches
    patch inlet
        (0 4 6 2)
    wall bottom
        (0 1 5 4)
    patch outlet
        (1 5 7 3)
    patch atmosphere
        (2 3 7 6)
    patch frontBack
        (0 1 3 2)
        (4 5 7 6)
mergePatchPairs
waveProperties.input:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      environmentalProperties;
seaLevel	0.00;
// A list of the relaxation zones in the simulation. The parameters are given
// in <name>Coeffs below.
relaxationNames (inlet outlet);
initializationName outlet;
inletCoeffs
    // Wave type to be used at boundary "inlet" and in relaxation zone "inlet"
    waveType    stokesFirst;
    // Ramp time of 2 s
    Tsoft       2;
    // Water depth at the boundary and in the relaxation zone
    depth       1.200000;
    // Wave period
    period      2.0;
    // Phase shift in the wave
    phi         0.000000;
    // Wave number vector, k.
    direction  (1.0 0.0 0.0);
    // Wave height
    height      0.1;
    // Specifications on the relaxation zone shape and relaxation scheme
    relaxationZone
        relaxationScheme Spatial;
        relaxationShape  Rectangular;
        beachType        Empty;
        relaxType   INLET;
        startX      (-3 0.0 -1);
        endX        (-1 0.0  1);
        orientation      (1.0 0.0 0.0);
outletCoeffs
    waveType    potentialCurrent;
    U           (0 0 0);
    Tsoft       2;
    relaxationZone
        beachType        Empty;
        relaxType   OUTLET;
        startX      (5 0.0 -1);
        endX        (7 0.0  1);
p_rgh in 0/:
|  \\    /   O peration     | Version:  v1912                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    bottom
        type            zeroGradient;
    outlet
        type            zeroGradient;
    atmosphere
        type            totalPressure;
        rho             rho;
        psi             none;
        gamma           1;
        p0              uniform 0;
        value           uniform 0;
    frontBack
        type            zeroGradient;
It should be noted that, this file seems to be different from my p_rgh in 0.org/ after the setWaveField command - I have added a boundaryField for the fixed object wall in p_rgh.org, but it disappears (resets) after I run setWaveField.
alpha1.org:
|  \\    /   O peration     | Version:  1.5-dev                               |
|   \\  /    A nd           | Revision: 1740                                  |
|    \\/     M anipulation  | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.org;
dimensions      [0 0 0 0 0 0 0];
boundaryField
	//- Set patchGroups for constraint patches
    #includeEtc "$WM_PROJECT_DIR/etc/caseDicts/setConstraintTypes"
    inlet
        type            zeroGradient; //waveAlpha;
        refValue        uniform 0;
        refGrad         uniform 0;
        valueFraction   uniform 1;
        value           uniform 0;
    bottom
        type            zeroGradient;
    outlet
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    frontBack
        type            zeroGradient; //empty;
	WCGroup
		type 			zeroGradient;
I would appreciate some insights on this, thank you for your time reading this!
noodleluvmay is offline   Reply With Quote
Old   April 21, 2023, 06:35
Nian
To add to this, I am running in parallel - it seems to run fine without the object in the domain, it feels like an issue with either snappyHexMesh or the setting of boundary conditions/initial input conditions for decomposed domains!
My run file procedure is:
runApplication surfaceFeatureExtract
runApplication blockMesh
runApplication waveGaugesNProbes
runApplication setWaveParameters
runApplication decomposePar -copyZero
runParallel snappyHexMesh -overwrite
runApplication reconstructParMesh
runApplication setFields
mpirun -np 4 waveFoam -parallel > log.waveFoam 2>&1
The reason I reconstructed before setFields is because I have read other posts where it seems to be the best way going about it, as setFields seems to not set the decomposed domains properly, I am not sure if my approach is correct though!
Last edited by noodleluvmay; April 21, 2023 at 06:54. Reason: Adding more information
Old   April 27, 2023, 13:24
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Please note that setFields is native to OpenFOAM, while setWaveField is the tool developed for waves2Foam.
Kind regards and good luck
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
boundary condition, initial condition
Atmospheric BCs for domain with a single boundary serving as both the inlet & outlet Newtonian OpenFOAM Running, Solving & CFD 0 July 21, 2022 15:07
interFoam wave propagation and explosion of Courant number and residuals ChiaraViola OpenFOAM Running, Solving & CFD 1 June 26, 2019 06:36
Flowrate at inlet and outlet not balancing ( centrifugal pump ) -- pimpleDyMFoam coolcrasher OpenFOAM Running, Solving & CFD 20 November 25, 2015 06:33
Keeping inlet mass flux the same as outlet mass flux in an water tank vaibhav402 Main CFD Forum 0 October 13, 2015 04:02
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
