[swak4Foam] [solved]fatal error: meshToMesh.H: No such file or directory (under OpenFOAM2212)
Old   April 3, 2023, 21:45
Default [solved]fatal error: meshToMesh.H: No such file or directory (under OpenFOAM2212)
Ary
Ary is on a distinguished road
I installed swak4Foam under the path like this "/home/user/swak4Foam" in OpenFOAM 2212. And swak4Foam works now by typing "FunkySetFields".
When I use swak4Foam in a new solver
(mySolver/mySolver.C)
HTML Code:
#include "fvCFD.H"
#include "expressionSource.H"
(mySolver/Make/files)
HTML Code:
mySolver.C
EXE = $(FOAM_USER_APPBIN)/mySolver
(mySolver/Make/options)
HTML Code:
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I../../../../../swak4Foam/Libraries/swak4FoamParsers/lnInclude/ \
    -I../../../../../swak4Foam/Libraries/swakSourceFields/lnInclude/
EXE_LIBS = \
    -lfiniteVolume \
    -lmeshTools \
    -lswak4FoamParsers \
    -lswakSourceFields
There would be en fatal error
HTML Code:
In file included from ../../../../../swak4Foam/Libraries/swak4FoamParsers/lnInclude/CommonValueExpressionDriver.H:78,
                 from ../../../../../swak4Foam/Libraries/swak4FoamParsers/lnInclude/FieldValueExpressionDriver.H:57,
                 from ../../../../../swak4Foam/Libraries/swakSourceFields/lnInclude/expressionSource.H:43,
                 from laserAblation01.C:47:
../../../../../swak4Foam/Libraries/swak4FoamParsers/lnInclude/MeshesRepository.H:48:10: fatal error: meshToMesh.H: No such file or directory
   48 | #include "meshToMesh.H"
compilation terminated.
(It seems like swak4Foam cannot link to the libraries of OpenFOAM entirely.)
How to fix the error then?
Thank you very much for any help!
Ary
Ary is offline   Reply With Quote
Old   April 3, 2023, 22:25
Ary
Library of sampling is also needed in Make/options
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
