[Tutorials] How to find the valid choices of mapMethod of mapFields? |
March 6, 2023, 07:35 |
Jasmine Feng
Rep Power: 3 |
Does anybody think the OpenFOAM documentation (esp. the CFD Direct version) is somewhat inadequate?
I'm now using OpenFOAM-V9 of CFD Direct. Take the command mapFields for example. It has an option `mapMethod` to specify the mapping method. But I cannot find any description from the User Guide or the command `mapFields -help`. Under protest, I came to the C++ source code of OpenFOAM, and found the valid choices are `mapNearest`, `interpolate`, `cellPointInterpolate`. Notwithstanding, I still know nothing about the difference between `interpolate` and `cellPointInterpolate`. I cannot find any description of these choices. The OpenCFD version seems better from this angle, since it provides valid choices at least, though without any detailed descriptions. Personally I think, a mature software must provide detailed API documentation, to make the users find the valid choices of some arguments conveniently. How do you think about it? Or simply, where can I find the choices of `mapFields` and its description conveniently |
api, documentation, mapfields, user guide |
error to check simulation result: could not find valid OpenFOAM mesh | xiaoyoyo | OpenFOAM | 5 | May 18, 2017 11:38 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 00:52 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
