[waves2Foam] setWaveField and/or waveFoam not working in parallel |
January 20, 2023, 18:18 |
saeed barzegar
Rep Power: 14 |
Hi all,
I have a large CFD domain (1.2km X 1.3km X 27m), and I'm using an STL file and SHM to define the bed (bathymetry). I've done this type of large-scale CFD simulation many times with IHFOAM, but I wanted to explore waves2Foam this time. However, for some reason, one case worked, and the other with a small change in SHM to improve the mesh resolution didn't. setWaveField just stops/freezes in parallel, and it does nothing. I tried running it in parallel, and it didn't help. Please note that I tried two different versions of OpenFOAM (v2012 and v2206) and different decomposition approaches. I've attached the case file as well as the log file from setWaveField. Two SHM files, one working and one not working, are also attached. Link below is for the STL of the bed that needs to be copied into constant/triSurface https://wfbaird.sharefile.com/d-se6f...ed01af0bcaf11e Any advice/recommendations are appreciated! Thank you in advance, Saeed |
January 20, 2023, 18:23 |
saeed barzegar
Rep Power: 14 |
BTW, for installation for OpenFOAM-v2206, you might need to change the $(FOAM_APPBIN) to $(WAVES_APPBIN) in the /waveFoam/Make/files if you are installing it on a cluster.
January 25, 2023, 15:57 |
saeed barzegar
Rep Power: 14 |
Update,
Please use the attached waveProperties.input file. |
setwavefield, wavefoam, waves2foam |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 17:38 |
[mesh manipulation] Dynamic remeshing (mequite) in parallel not working [foam-extend-4.0] | Peter_600 | OpenFOAM Meshing & Mesh Conversion | 4 | August 1, 2017 07:07 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
parallel finally working | hedley | SU2 Installation | 0 | June 23, 2014 12:35 |
parallel fluent under pbs not working | kharnabnew | FLUENT | 0 | January 6, 2011 04:28 |
