[swak4Foam] "make: *** No rule to make target ..." when installing swak4Foam within OpenFOAM10
Old   December 17, 2022, 23:18
Default "make: *** No rule to make target ..." when installing swak4Foam within OpenFOAM10
lyb
lyb99 is on a distinguished road
Hi!
I want to install swak4Foam within OpenFOAM 10 but I am getting errors related to bear and some Make files. I am using MacOS. Here is the error message I get when I try to install swak4Foam
Current OpenFOAM version is 10.
Previously compiled for OpenFOAM (10)
/home/openfoam/applications/Libraries/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Reading variables from 'swakConfiguration'
Looking for Python 2
Looking for Python 3
Using our own Lua at /home/openfoam/applications/Libraries/swak4Foam/privateRequirements
Checking swak4Foam-version and generating file
Swak version is 202x.yy.0
./Allwmake: line 79: hg: command not found
Could not get version of the sources
No 'bear' installed
Bison: /home/openfoam/applications/Libraries/swak4Foam/bison/bin/bison
Flex: /usr/bin/flex
Bison at /home/openfoam/applications/Libraries/swak4Foam/bison/bin/bison is version 3.8 (Major 3 Minor 8)
Flex is version 2.6.4 (Minor version: 4)
OpenFOAM-version: Major 10 Minor 0 Patch -1 (-1 == x / 98) Fork: org
No change to swak4FoamParsers/foamVersion4swak.H
Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem
wmake libso swak4FoamParsers
OpenFOAM.org version 10
make: *** No rule to make target 'Make/linux64GccDPInt32Opt/SubsetValueExpressionParser.o', needed by 'Make/linux64GccDPInt32Opt/CellSetValueExpressionDriver.o'.  Stop.
wmake error: file 'Make/linux64GccDPInt32Opt/files' could not be created in /home/openfoam/applications/Libraries/swak4Foam/Libraries/swak4FoamParsers
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occurred to 5 other people before and has been solved on the MessageBoard
I also do not know why it says that
when I already installed Mercurial prior to attempting installing swak4Foam. I hope somebody could help or point me in the right direction. I tried reading a lot of the thread here and got no solution that worked for my case. Thank you!
lyb99 is offline   Reply With Quote
installation of swak4foam, swak4foam
[foam-extend.org] Problem in installing foam-extend-4.1 on HPC Arman_N OpenFOAM Installation 2 October 13, 2020 05:42
[swak4Foam] Installing swak4Foam on ubuntu 12.04 fluidflowsteel OpenFOAM Community Contributions 1 June 28, 2016 15:02
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 03:36
FOAM installation error gcc amp g hanks OpenFOAM Installation 9 January 26, 2006 15:14
