November 25, 2022, 09:34 |
Solution singularity
Adeshina
Hi everyone,
I am coupling a new equation to an existing solver. I succeeded in adding thermal equation and in solving it. However, when I added a new equation for parameter P, it stopped too quickly. I will appreciate any help. The report it gives is: DICPCG: Solving for psi: solution singularity Error psi = 0.000292304 Picard Flow = 0 DILUPBiCG: Solving for T, Initial residual = 0.000136668, Final residual = 8.81779e-07, No Iterations 15 DILUPBiCG: Solving for P: solution singularity ExecutionTime = 56.06 s ClockTime = 57 s deltaT = 60 Time = 2280 DICPCG: Solving for psi: solution singularity Error psi = 0.000285359 Picard Flow = 0 DILUPBiCG: Solving for T, Initial residual = 0.000132102, Final residual = 8.51169e-07, No Iterations 15 Thank you in advance. |
July 9, 2023, 05:18 |
#2 | |
Grp
Rep Power: 3 |
singularity |
[OpenFOAM.org] OpenFoam singularity container MPI crash | ves | OpenFOAM Installation | 0 | November 5, 2020 09:22 |
Errors in compling icoFsiFoam | jin_xu | OpenFOAM Running, Solving & CFD | 5 | June 4, 2008 21:15 |
How to add the RhO to the icoStructFoam | msha | OpenFOAM Running, Solving & CFD | 8 | January 25, 2008 09:46 |
Rookiequestions error solution singularity etc | ham | OpenFOAM Running, Solving & CFD | 3 | June 1, 2006 03:47 |
Problem with jet flow | braennstroem | OpenFOAM Running, Solving & CFD | 16 | May 15, 2006 03:23 |
