[swak4Foam] A compilation problem with swak4Foam
Old   November 17, 2022, 11:44
Default A compilation problem with swak4Foam
stater's Avatar
H. Omar
stater is on a distinguished road
Hi everbody,
I'm trying to compile swak4Foam but I get the following error:
This script is rather crude. If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-installation (as ./maintainanceScripts/compileRequirements.sh). Otherwise it probably won't work
Bison already installed/compiled
Bison successfully compiled
Lua already installed/compiled
Lua successfully compiled
Add /home/user/swak4Foam/privateRequirements/bin to PATH-variable. The ./Allwmake-script will use this directory automatically
Current OpenFOAM version is 10.
Previously compiled for OpenFOAM (10)
/home/user/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Reading variables from 'swakConfiguration'
Looking for Python 2
Looking for Python 3
Using our own Lua at /home/user/swak4Foam/privateRequirements
Checking swak4Foam-version and generating file
Swak version is 202x.yy.0
hg info: 481d96f16780 (develop) tip
No 'bear' installed
Bison: /home/user/swak4Foam/privateRequirements/bin/bison
Flex: /usr/bin/flex
Bison at /home/user/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4)
Flex is version 2.6.4 (Minor version: 4)
OpenFOAM-version: Major 10 Minor 0 Patch -1 (-1 == x / 98) Fork: org
No change to swak4FoamParsers/foamVersion4swak.H
Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem
wmake libso swak4FoamParsers
OpenFOAM.org version 10
make: *** Aucune règle pour fabriquer la cible « Make/linux64GccDPInt32Opt/SubsetValueExpressionParser.o », nécessaire pour « Make/linux64GccDPInt32Opt/CellSetValueExpressionDriver.o ». Arrêt.
wmake error: file 'Make/linux64GccDPInt32Opt/files' could not be created in /home/user/swak4Foam/Libraries/swak4FoamParsers
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occurred to 5 other people before and has been solved on the MessageBoard
My Openfoam directory is:
/home/user/OpenFoam/Openfoam10
The OpenFoam environment is loaded from the .bashrc file with the command:
source $HOME/OpenFOAM/OpenFOAM-10/etc/bashrc
I launched the compilation from directory:
/home/user/OpenFoam/swak4Foam
Do you have any idea to fix the problem?
Thanks
H. Omar
stater is offline   Reply With Quote
openfoam 10, swak4foam
[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM steven123 OpenFOAM Community Contributions 35 January 11, 2021 16:53
[swak4Foam] Problem with triSurface.so and swak4Foam PieterjanR OpenFOAM Community Contributions 2 November 21, 2016 09:54
[swak4Foam] problem with slave cells using toposet while calculating volume flux with swak4foam Andy_Wang OpenFOAM Community Contributions 0 October 14, 2016 13:20
[swak4Foam] problem on installing swak4Foam navid2 OpenFOAM Community Contributions 2 May 30, 2012 04:32
[swak4Foam] compilation problem ganeshv OpenFOAM Community Contributions 5 November 11, 2011 16:39
