[cfMesh] Mesh not "snapped" correctly at thin trailing edge and symmetry plane
Old   October 22, 2021, 00:44
Question Mesh not "snapped" correctly at thin trailing edge and symmetry plane
Supakorn Suttiruang
cosmictrex is on a distinguished road
I'm having issues with cfMesh and the region near the thin trailing edge which is adjacent to the symmetry plane. I'm meshing a flying wing with very thin root trailing edge and even thinner tip trailing edge. The geometry was defined by the FMS surface mesh file.
The tip trailing edge "snaps" and define the feature correctly; however, the root trailing edge adjacent to the symmetry plane does not (even with refined surface mesh). The picture of the resulting mesh and the surface mesh (FMS) file at the problematic region is in the attachments. The tip trailing edge mesh and surface are attached as well.
The content of my meshDict file is as follows:
| \\      /  F ield         | cfMesh: A library for mesh generation          |
|  \\    /   O peration     |                                                |
|   \\  /    A nd           | Author: Franjo Juretic                         |
|    \\/     M anipulation  | E-mail: franjo.juretic@c-fields.com            |
FoamFile
    version   2.0;
    format    ascii;
    class     dictionary;
    location  "system";
    object    meshDict;
surfaceFile "Vetal.fms";
maxCellSize 2; //[m]
// minCellSize 2; //[m]
boundaryCellSize 0.5; //[m]
// objectRefinements
//     mainBox
//         type box;
//         cellSize    3e-2;   //[m]
//         centre   (2.95 0 0);   //[m]
//         lengthX         6;   //[m]
//         lengthY         2;     //[m]
//         lengthZ         0.4;     //[m]
localRefinement
    wing.main
        additionalRefinementLevels 11;
        refinementThickness  1e-2; //[m]
    wing.wingtip
    wing.te
        additionalRefinementLevels 12;
        refinementThickness  5e-4; //[m]
// edgeMeshRefinement
//     wing
//         edgeFile "Vetal_FlatTE_Half.vtk";
//         additionalRefinementLevels 14;
//         // refinementThickness 1e-3;
// boundaryLayers
//     patchBoundaryLayers
//         wing.*
//              nLayers    15;
//              thicknessRatio     1.05;
//              allowDiscontinuity 1;
//              // maxFirstLayerThickness 2e-5;
//     optimiseLayer 1;
//     optimisationParameters
//         nSmoothNormals             5;
//         relThicknessTol         0.4;
//         featureSizeFactor         0.8;
//         reCalculateNormals         1;
//         maxNumIterations         5;
renameBoundary
    defaultType     wall;
    newPatchNames
        "farfield"
            newName farfield;
            type    patch;
My meshDict file only defines localRefinement patches, as you can see above.
cosmictrex is offline   Reply With Quote
[snappyHexMesh] How too improve y+ number at trailing edge and Wing tip AlbatrossR OpenFOAM Meshing & Mesh Conversion 3 October 18, 2021 04:33
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 15:41
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge TWaung CFX 2 February 16, 2010 09:11
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
