October 20, 2021, 07:09 |
Boundary layer at corners
chubb87
Rep Power: 15 |
my mesh generated with cfMesh has the problem, that at corners the boundary layers from two patches overlap. This leads to small quadratic cells, which are then interpolated to one much bigger cell in the red region. I would rather prefer the mesh to be as in the second picture. Does anyone know how this can be influenced? I tried to separate the two adjacent walls into different patches, but the result was the same. |
July 31, 2024, 04:27 |
Rep Power: 2 |
There is a feature in the boundary layer construction called allowDiscontinuity with a value of 0 or 1 depending if you say Yes or No. Have you tried that?
[snappyHexMesh] Holes in internal mesh when adding boundary layer snappyHex | otaolafr | OpenFOAM Meshing & Mesh Conversion | 3 | February 8, 2021 09:19 |
[snappyHexMesh] layer not added | Rasmusiwersen | OpenFOAM Meshing & Mesh Conversion | 1 | January 2, 2020 10:43 |
[snappyHexMesh] SnappyHexMesh: Layer on corners | Pj. | OpenFOAM Meshing & Mesh Conversion | 9 | July 17, 2014 05:26 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 13:41 |
