[PyFoam] Installing PyFoam from pip, can't tell if its installed correctly? |
June 6, 2021, 20:23 |
Sultan Islam
Rep Power: 10 |
Hello everyone,
I am running Fedora 34 and I wanted to compile FE40 and FE41. However there thirdparty version of pyfoam won't compile due to shebang errors, I was suggested to just install pyfoam separately. I am using Python 3.9 and i used pip install PyFoam. However I can't tell if it installed correctly. I ran pyFoamVersion.py and it showed some outputs: Code:
[AI-FE@AI-Workstation ~]$ pyFoamVersion.py Machine info: Linux | AI-Workstation | 5.12.8-300.fc34.x86_64 | #1 SMP Fri May 28 15:20:54 UTC 2021 | x86_64 | x86_64 Python version: 3.9.5 (default, May 14 2021, 00:00:00) [GCC 11.1.1 20210428 (Red Hat 11.1.1-1)] Python executable: /usr/bin/python3 Python 3 is supported with PyFoam PYTHONPATH is not set Location of this utility: /home/AI-FE/.local/bin/pyFoamVersion.py PyFoam WARNING on line 229 of file /home/AI-FE/.local/lib/python3.9/site-packages/PyFoam/FoamInformation.py : Basedir /home/AI-FE/OpenFOAM for fork openfoam does not exist or is not a directory PyFoam WARNING on line 229 of file /home/AI-FE/.local/lib/python3.9/site-packages/PyFoam/FoamInformation.py : Basedir /home/AI-FE/foam for fork extend does not exist or is not a directory PyFoam WARNING on line 229 of file /home/AI-FE/.local/lib/python3.9/site-packages/PyFoam/FoamInformation.py : Basedir /home/AI-FE/OpenFOAM for fork openfoamplus does not exist or is not a directory Version () (reported as number )Fork openfoam of the installed 0 versions: pyFoam-Version: 2021.5 Path where PyFoam was found (PyFoam.__path__) is ['/home/AI-FE/.local/lib/python3.9/site-packages/PyFoam'] Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/AI-FE/.pyFoam/pyfoamrc'), ('directory', '/home/AI-FE/.pyFoam/pyfoamrc.d')] Configuration files (used): [] Installed libraries: cython : Yes version: 0.29.23 cProfile : Yes docutils : No Not necessary. Needed for RestructuredText to HTML conversion Gnuplot : No Not a problem. Version from ThirdParty is used hotshot : No Not a problem. Can't profile using this library line_profiler : No Not a problem. Can't profile using this library ipdb : No Not necessary. Only makes debugging more comfortable IPython : Yes version: 7.20.0 Matches required version 2.0.0 matplotlib : Yes version: 3.4.2 mercurial : Yes version: b'5.7.1' pytest : No Only needed for running the unit-tests (developers only) numpy : Yes version: 1.20.1 openpyxl : No Not a problem. Only used for exporting pandas-data to Excel-files (advanced). If xlsxwriter is installed it will handle this (xlsxwriter is recommended anyway) xlsxwriter : No Not a problem. Only used for exporting pandas-data to XLSX-files (advanced). If openpyxl is installed then this module can handle that pandas : No Not a problem. Only used for handling of advanced data-handling ply : Yes version: 3.11 profile : Yes psyco : No Not a problem. Acceleration not possible PyQt4 : No Only some experimental GUI-stuff relies on this PyQt4.Qwt5 : No Only an alternate plotting back-end scipy : No Not yet used. Possibly use signal-fitting etc Tkinter : No Not a problem. Used for the old version of DisplayBlockmesh and some matplotlib-implementations twisted : No Not yet used. Possibly reimplement MetaServer with it vtk : No Not a problem. Only used for some utilities xlwt : No Not a problem. Only used for exporting pandas-data to Excel-files xlrd : No Not a problem. Only used for importing Excel-files to pandas-data requests : Yes version: 2.25.1 zeroconf : Yes version: 0.31.0 psutil : Yes version: 5.8.0 PyFoam.ThirdParty.ply.yacc : Yes version: 3.9 PyFoam.ThirdParty.Gnuplot : Yes version: 1.8 PyFoam.ThirdParty.tqdm : Yes version: 4.8.4 PyFoam.ThirdParty.IPy : Syntax Error This is our own. If it is not found we've got problems PyFoam.ThirdParty.pyratemp : Yes version: 0.2.0 PyFoam.ThirdParty.six : Yes version: 1.10.0 PyFoam.ThirdParty.winhacks : Yes Library locations cProfile : /usr/lib64/python3.9/cProfile.py cython : /home/AI-FE/.local/lib/python3.9/site-packages/cython.py IPython : /usr/lib/python3.9/site-packages/IPython/__init__.py matplotlib : /usr/local/lib64/python3.9/site-packages/matplotlib/__init__.py mercurial : /usr/lib64/python3.9/site-packages/mercurial/__init__.py numpy : /usr/lib64/python3.9/site-packages/numpy/__init__.py ply : /usr/lib/python3.9/site-packages/ply/__init__.py profile : /usr/lib64/python3.9/profile.py psutil : /usr/lib64/python3.9/site-packages/psutil/__init__.py PyFoam.ThirdParty.Gnuplot : /home/AI-FE/.local/lib/python3.9/site-packages/PyFoam/ThirdParty/Gnuplot/__init__.py PyFoam.ThirdParty.ply.yacc : /home/AI-FE/.local/lib/python3.9/site-packages/PyFoam/ThirdParty/ply/yacc.py PyFoam.ThirdParty.pyratemp : /home/AI-FE/.local/lib/python3.9/site-packages/PyFoam/ThirdParty/pyratemp.py PyFoam.ThirdParty.six : /home/AI-FE/.local/lib/python3.9/site-packages/PyFoam/ThirdParty/six.py PyFoam.ThirdParty.tqdm : /home/AI-FE/.local/lib/python3.9/site-packages/PyFoam/ThirdParty/tqdm/__init__.py PyFoam.ThirdParty.winhacks : /home/AI-FE/.local/lib/python3.9/site-packages/PyFoam/ThirdParty/winhacks.py requests : /usr/lib/python3.9/site-packages/requests/__init__.py zeroconf : /home/AI-FE/.local/lib/python3.9/site-packages/zeroconf/__init__.py Checking additional envirnoment variables Checking for PYFOAM_DIR : Location of the PyFoam-installation. Not strictly necessary PYFOAM_DIR missing from environment Checking for PYFOAM_SITE_DIR : Location of non-PyFoam-disctributions script. Set and used by some Foam-distributions PYFOAM_SITE_DIR missing from environment User information Username: AI-FE Temporary directory: /tmp/PyFoam_AI-FE Public key: 060c9035e876693015d29b4a61f5f2b5:10512702a18638c159a01d2a29b21393 [AI-FE@AI-Workstation ~]$ |
[OpenFOAM.org] OF 2.4.0 Paraview not installing correctly | cbcoutinho | OpenFOAM Installation | 3 | June 12, 2015 17:03 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
uninstalling Ubuntu pack and installing source pack | vetnav | OpenFOAM Installation | 2 | July 13, 2010 19:11 |
Problems installing OpenFoam on a 64bit machine | jango | OpenFOAM Installation | 1 | June 4, 2007 14:53 |
Installing OpenFOAM in Ubuntu LINUX 510 Breeze | derjames | OpenFOAM Installation | 0 | April 7, 2006 08:22 |
