[blastFoam] What material has parameters closest to the wall blockmesh boundary type? |
January 12, 2021, 03:33 |
Homer Bacanto
Rep Power: 5 |
I want to create a graph where I can compare results taken from blastFoam to the results from empirical formulas such as from UFC 3-340-02, or the Gelfand and Silnikov (2004) formula.
Unfortunately, to use some of the available formulas for an air burst calculation, I have to multiply the results by a reflection factor depending on the material. My question is, what material has parameters that allow it to behave closest to the wall boundary in OpenFOAM's blockmesh? Thank you! |
blastfoam, blockmesh, openfoam |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
rSF: p divergence in combustor (wt negative value) | zonda | OpenFOAM Pre-Processing | 4 | April 10, 2018 06:59 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
