[PyFoam] Error while running pyFoamPlotRunner |
January 2, 2021, 14:59 |
AA
Hi everyone.
I'm totally new to pyFoam. To cut to the chase, I face this error while trying to get cavity case outputs by: pyFoamPlotRunner.py icoFoam Code:
Error in /usr/local/bin/pyFoamPlotRunner.py : FatalError in PyFoam: 'PyFoam FATAL ERROR on line 617 of file /usr/local/lib/python3.8/dist-packages /PyFoam/Applications/PyFoamApplication.py: Case /home/ali/Desktop/cavity/logs does not have a 'system' directory' in Application-class: PlotRunner Thanks |
January 7, 2021, 03:22 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I guess you're trying to start a run in a sub-directory of your actual case (the last part "logs" of the path indicates that this is whhere you store the logs). Go up one directory and it should work
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
pyfoam, pyfoamplotrunner |
Simulation just stops output writing, but keeps running | blaise | OpenFOAM Running, Solving & CFD | 6 | March 27, 2024 04:49 |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
Error problem while running sadia d lts tutorial | kane | OpenFOAM Running, Solving & CFD | 2 | May 26, 2018 03:38 |
Error Running Design of Experiments in ANSYS Fluent | tytrzecki | FLUENT | 0 | April 22, 2018 15:01 |
Problem in running coarse mesh(on the other hand fine mesh is running) | ashokmoravaneni | OpenFOAM | 7 | July 17, 2017 04:56 |
