[Discretizer] error while writing files for new discretization scheme
Old   October 16, 2020, 03:06
Default error while writing files for new discretization scheme
Jnana Bhaskar Rao
jnanabrao is on a distinguished road
I'm trying to run a cavity case using the third order WENO scheme. This uses a WENOEXT library developed by Jan Gaertner and Tobias Martin . My OF versions are OF-6 and OF-7(I get the same error with both of them). I get the printstack and sigSevHandler IO errors while running the icoFoam solver as shown in the attached png. I'm running the cavity case provided in the tutorials by the developers of the library(attached). Needless to say to reproduce the error, the library will need to be downloaded and compiled first as per instructions in the readme file. Any help will be greatly appreciated.
jnanabrao is offline   Reply With Quote
Old   October 16, 2020, 03:09
Jnana Bhaskar Rao
for some reason the link to the library github repositories is not being attached.https://github.com/WENO-OF/WENOEXT.
I'll also write in plain text here:
Old   October 21, 2020, 15:55
Jan Gaertner
janGaertner is on a distinguished road
I hope you could fix your issue. If not please pull the latest version of WENO Ext from GitHub. There have been some substantial improvements concerning the speed of the scheme.
Also it has been now verified and published in SoftwareX: https://www.sciencedirect.com/scienc...52711020303241
janGaertner is offline   Reply With Quote
Old   October 21, 2020, 16:45
Default The issue is sorted
Jnana Bhaskar Rao
The problem was to do with my hardware. I was using an Ubuntu 18.04 LTS version. Once the distro was updated, to Ubuntu 20.04 LTS, the problem was resolved. The problem wasn't the Ubuntu version necessarily but more likely a corrupted kernel.
printstack, sigsegvhandler, weno, wenoext
Crank Nicolson scheme implemented wrong? rajibroy OpenFOAM Programming & Development 10 May 5, 2020 10:57
Writing Case and Data Files Using Journal/Scheme Files svp Fluent UDF and Scheme Programming 0 April 5, 2011 12:04
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
Writing geometry files in STAR-CD Sachin Siemens 5 April 22, 2008 17:38
Experimental Repository for UDFs, Journal Files and Scheme Scripts Jonas Larsson FLUENT 0 March 5, 2000 16:36
