Sample case of simplified energy transport simulation for incompressible flow
Old   September 20, 2020, 08:42
Default Sample case of simplified energy transport simulation for incompressible flow
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
I've attached a simplified energy transport simulation case for incompressible flow with the following functionality in OpenFOAM v2006:
  • energyTransport: to solve a simplified energy transport equation
  • readFields: to read kappa value to be able to use externalWallHeatFluxTemperature boundary condition
  • externalWallHeatFluxTemperature: to set heat flux boundary condition
Settings of readFields and energyTransport function objects in system/controlDict
    readKappaFields
        type        readFields;
        libs        (fieldFunctionObjects);
        fields      (kappaField);
        readOnStart true;
    energyTransport
        type            energyTransport;
        libs             (solverFunctionObjects);
        enabled         true;
        writeControl    outputTime;
        writeInterval   1;
        field           T;
        phi             phi;
        // Thermal properties
        Cp              Cp    [J/kg/K]  1e3;
        kappa           kappa [W/m/K]   0.0257;
        rhoInf          rho   [kg/m^3]  1.2;
        write           true;
        fvOptions
Settings of heat flux boundary condition(q=500[W/m^2]) in 0.orig/T
    hole
        type            externalWallHeatFluxTemperature;
        mode            flux;
        q               uniform 500;
        kappaMethod     lookup;
        kappa           kappaField;
        value           uniform 300;
where kappa value is read from 0.orig/kappaField
|  \\    /   O peration     | Version:  v2006                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      kappaField;
dimensions      [1 1 -3 -1 0 0 0];
internalField   uniform 0.0257;
boundaryField
    inlet
        type             fixedValue;
        value            $internalField;
    outlet
        type             fixedValue;
    up
        type            symmetry;
    hole
        type             fixedValue;
    frontAndBack
        type            empty;
Hope this helps,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
Energy balance in conjugative/ porous simulation; Domain Energy is greater than Input Vishnu_bharathi CFX 2 June 27, 2018 11:08
[General] Calculation of Cp in case of dynamic simulation. Metikurke ParaView 1 May 30, 2018 10:52
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
