[swak4Foam] post-processing using swakExpressionAverageDistribution do not work as expected
Old   June 26, 2020, 07:56
Default post-processing using swakExpressionAverageDistribution do not work as expected
samwong is on a distinguished road
hi everyone,
I would like to calculate the x,y plane average profile of a scalarField T(x,y,z)
i.e. T(x,y,z) -> T_avg(z)
I did my calculation in parallel with 5 regions from time 0 to 1200. Data is written every 300steps, such that my data are contained in case/processor{0..23}/{0..1200..300}/region{1..5}/T
The problem is, I execute the command
funkyDoCalc -time 1200 system/region2/postDict -region region2
but only the time = 0 (initial condition) is being calculated.
Any help would be appreciated!! Thank you
Details:
I follow the post,
Averaging along an axis.. swak4foam?
PostProcessing for finished calculation
and made a file called postDict containing:
avgTDistributionZ {
type swakExpressionAverageDistribution;
libs (
"libOpenFOAM.so"
"libsimpleSwakFunctionObjects.so"
"libswakFunctionObjects.so"
"libgroovyBC.so"
writeStartTime no;
verbose true;
outputControlMode outputTime;
valueType internalField;
expression "T";
weight "vol()";
mask "true";
abscissa "pos().z";
binNumber 54;
valueIfZero 0;
dynamicExtremesAbscissa false;
minAbscissa 0;
maxAbscissa 150;
accumulations ( average );
and I tried to execute the commands,
funkyDoCalc -latestTime system/region2/postDict -region region2
and
both of them give the same bash output and seems calculated the time = 0 only (but the average should not be 0, internal field is set to be 300).
| \\ / O peration | Version: v1912 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _f3950763fe-20191219 OPENFOAM=1912
Arch : "LSB;label=32;scalar=64"
Exec : funkyDoCalc -time 1200 system/region2/postDict -region region2
Date : Jun 26 2020
Time : 19:23:08
Host :
PID : 145527
I/O : uncollated
Case :
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
swakVersion: 2020.06 (Release date: 2020-06-04)
Create time
Overriding DebugSwitches according to controlDict
SolverPerformance 0;
Create mesh region2 for time = 0
No information about foreign meshes in "system/region2/postDict.avgTDistributionZ"
Time = 0
avgTDistributionZ : swak4Foam: Setting default mesh
swak4Foam: Allocating new repository for sampledMeshes
swak4Foam: Allocating new repository for sampledGlobalVariables
with mask with weight average=0
End
samwong is offline   Reply With Quote
Old   November 3, 2020, 11:43
Bodo1993 is on a distinguished road
Hi, I am wondering if you were able to resolve the problem. Thanks.
Bodo1993 is offline   Reply With Quote
openfoam 1912, post procesing, swak4foam error
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 21:51
