[swak4Foam] error installing swak4Foam for openfoam v1906 on WSL |
June 24, 2020, 12:09 |
George
I'm new to openfoam and was trying to to install swak4foam but I keep getting this error
/home/george/OpenFOAM/OpenFOAM-v1906/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison) Reading variables from 'swakConfiguration' swakConfiguration: line 13: [: : integer expression expected Checking swak4Foam-version and generating file abort: no repository found in '/home/george/OpenFOAM/OpenFOAM-v1906/swak4Foam' (.hg not found)! Swak version is 0.3.2 Bison is version 2.7.12-4996 Flex is version 2.6.4 (Minor version: 4) OpenFOAM-version: Major Minor v1906 Patch v1906 (-1 == x / v1906) No change to swak4FoamParsers/foamVersion4swak.H wmake libso swak4FoamParsers /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:61: /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../mybison: No such file or directory /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:62: /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:65: /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions: No such file or directory make: *** No rule to make target '/home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions'. Stop. /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:61: /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../mybison: No such file or directory /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:62: /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:65: /home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions: No such file or directory make: *** No rule to make target '/home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions'. Stop. wmake error: file '/home/george/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/sourceFiles' could not be created in /home/george/OpenFOAM/OpenFOAM-v1906/swak4Foam/Libraries/swak4FoamParsers Parser library did not compile OK. No sense continuing as everything else depends on it Requirements for Library not satisfied. I see no sense in going on Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard Code:
swakConfiguration: line 13: [: : integer expression expected Checking swak4Foam-version and generating file abort: no repository found in '/home/george/OpenFOAM/OpenFOAM-v1906/swak4Foam' (.hg not found)! thanks |
May 6, 2021, 20:14 |
Rebeca Marini
hi George,
have you solve this problem? I'm having the same issue and I'm a bit stuck :/ regards |
[swak4Foam] fails in parallel with -otherTime? | Phicau | OpenFOAM Community Contributions | 3 | June 26, 2013 14:00 |
