[waves2Foam] installing waves2foam into OpenFoam 6
Old   April 1, 2020, 10:54
Default installing waves2foam into OpenFoam 6
Kostas
madgeogr is on a distinguished road
I am having a difficulty on correctly installing waves2foam in OpenFoam 6 in mac Catalina. As instructed in the manual, initially I have installed the following third-party dependencies:
git --version
git version 2.25.2
whereis svn
/usr/bin/svn
gfortran --version
GNU Fortran (GCC) 5.2.0
Copyright (C) 2015 Free Software Foundation, Inc.
gsl-config --version
2.6
After sourcing OPENFOAM environment, I have initialised the download process of waves2foam through the following link:
svn co http://svn.code.sf.net/p/openfoam-extend/svn/trunk/\
Breeder_1.6/other/waves2Foam
to the utilities directory of the OpenFoam directory:
/Volumes/OpenFOAM/OpenFOAM-6/applications/utilities
at the end of which I have encountered the following flag:
Checked out revision 2139.
I then moved to the bin/bashrc and correct the paths as follow:
export WAVES_DIR=/Volumes/OpenFOAM/OpenFOAM-6/applications/utilities/waves2Foam
I also point out that I convert the prepareCase.sh into an executable before the installation process began.
Then, I ran the installation command (./Allwmake inside the waves2foam directory), and I got the following error
COMPILE OCEANWAVE3D
Cloning the OceanWave3D git repository ...
Cloning into 'OceanWave3D-Fortran90'...
remote: Enumerating objects: 5024, done.
remote: Total 5024 (delta 0), reused 0 (delta 0), pack-reused 5024
Receiving objects: 100% (5024/5024), 16.61 MiB | 756.00 KiB/s, done.
Resolving deltas: 100% (3755/3755), done.
Set the environmental variables for waves2Foam
Exiting compilation process
Problems with the compilation of the third party dependencies
Exiting
It says that I have some issues related to third party dependencies, but I have properly installed all the proposed ones (see beginning of this post). The problem occurs at OceanWave3D, which the compiler can access through git.
Any advice?
madgeogr is offline   Reply With Quote
Old   June 15, 2021, 12:17
Azin
azin93 is on a distinguished road
I am having the same issue in compiling waves2foam, could you figure out the issue?
Would you please let me know if you found the solution to this?
Best,
Azin
azin93 is offline   Reply With Quote
[OpenFOAM.org] Installing OpenFOAM 2.3 on Ubuntu 18.04 Joe1best OpenFOAM Installation 15 August 5, 2021 23:21
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
[waves2Foam] A few notes about problems and solutions when installing with OpenFOAM v1712 oceanFoam OpenFOAM Community Contributions 0 June 22, 2018 09:52
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
[OpenFOAM.org] Installing OpenFoam 3.0.1 on cluster hello177 OpenFOAM Installation 1 April 24, 2016 09:35
