[waves2Foam] IO error when running waveIsoFoam with OF1812: Dictionary entry not found |
March 20, 2020, 22:10 |
Jinshi Chen
Rep Power: 6 |
Hi all,
I am currently trying to run waveIsoFoam, one of the new solver from waves2Foam, with OF1812. However, when I tested a case that I have successfully run with waveFoam on OF1712, I got the following error message: Code:
[31] --> FOAM FATAL IO ERROR: [31] Dictionary entry for patch inlet not found [31] [31] file: IOstream [31] [31] From function static Foam::autoPtr<Foam::waveModel> Foam::waveModel::New(const Foam::word&, const Foam::fvMesh&, const Foam::polyPatch&) [31] in file waveModel/waveModelNew.C at line 58. Code:
[0] --> FOAM FATAL IO ERROR: [0] Dictionary entry for patch inlet not found [0] [0] file: /vortexfs1/scratch/jinshichen/waveFlume_rand_kostab_topo_parallel_iso_run/processor0/constant/waveProperties [0] [0] From function static Foam::autoPtr<Foam::waveModel> Foam::waveModel::New(const Foam::word&, const Foam::fvMesh&, const Foam::polyPatch&) [0] in file waveModel/waveModelNew.C at line 58. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1712 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object waveProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // seaLevel 4.5; seaLevelAsReference true; relaxationNames ( inlet outlet ); initializationName outlet; inletCoeffs { waveType irregular; N 50; //Number of sampling frequencies Tsoft 30; //Ramp time // Define the phases phaseMethod randomPhase; // Define the spectrum spectrum JONSWAP; Hs 0.8; // Significant wave height Tp 7; // Peak wave period gamma 3.3; // Peak enhancement factor depth 4.5; // Water depth direction (1 0 0); frequencyAxis { discretisation equidistantFrequencyAxis; lowerFrequencyCutoff 0.1; upperFrequencyCutoff 0.3; writeSpectrum false; } relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType INLET; startX ( 0 0 0 ); endX ( 30 1 0 ); orientation ( 1 0 0 ); } } outletCoeffs { waveType potentialCurrent; U ( 0 0 0 ); Tsoft 2; relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType OUTLET; startX ( 350.907 0 0 ); endX ( 370.907 1 0 ); orientation ( 1 0 0 ); } } // ************************************************************************* // My controlDict looks like the following: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application interFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 10; deltaT 0.001; writeControl adjustableRunTime; writeInterval 0.05; purgeWrite 6; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.05; maxAlphaCo 0.25; maxDeltaT 1; // ************************************************************************* // |
March 22, 2020, 16:17 |
Jinshi Chen
Rep Power: 6 |
Hi all,
I have found a temporary fix: If you delete the "waveModel" library from EXE_LIB list in file "/waves2Foam/applications/solvers/solvers1812_PLUS/waveIsoFoam/Make/options" and recompile it, it should fix the problem. However I am still looking for a more thorough solution. Thank you! Best, Jinshi |
March 23, 2020, 12:25 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Jinshi,
Thank you for reporting the bug. I have removed waveModels in Make/options and updated the repository. It is indeed a bug, because waveModels relate to the OpenFoam-ESI wave models and not waves2Foam. Kind regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
January 4, 2021, 11:08 |
‘g’ was not declared in this scope
#4 | |
le
Rep Power: 17 |
I try to combine interfoam and wavefoam in OF1812, but i got error when i wmake for new solver as: /home/leqt/OpenFOAM/leqt-v1812/applications/utilities/waves2Foam/src/waves2Foam/lnInclude/readWaveProperties.H:27:38: error: ‘g’ was not declared in this scope referencePoint.value() = g.value()/Foam::mag(g.value()); ^ Could you tell me how to fix it, please. Many thanks |
January 4, 2021, 14:45 |
Jinshi Chen
Rep Power: 6 |
Hi Le,
I am not entirely sure what you did, and I didn't make a new solver my own (just using Niels' waveIsoFoam solver). However, it does seem to me that you have missed defining g (gravitational acceleration) somewhere in your model but have included it in the back end equation. I'd personally like to refer your question to other people who are more experienced that me. Thank you! Best, Jinshi |
May 12, 2021, 04:33 |
#6 | |
Rasmus Iwersen
Rep Power: 8 |
January 4, 2022, 08:10 |
Francisco Pinto
Rep Power: 5 |
Hello everyone, I am using the OF2012 and I am facing the same problem as you. Do you know if the solution is the same as what you did for your OF version?
Did anyone face this problem with the OF2012? Thank you in advance. |
September 5, 2023, 12:51 |
#8 | |
Manuel Fraga Seoane
Rep Power: 6 |
First of all I would like to thank you for you great work with waves2Foam. I guess you were talking about /solvers1812_PLUS/. I have realized that in the next version solvers (2012, 2106 and 2206) the "wave model" library is still in the options file. I was having the same error " Dictionary entry for patch inlet not found". Once I recompile without it, there is no error. It is still a bug or am I missing something? Kind regards, Manuel |
September 10, 2023, 18:39 |
#9 | |
nf zhang
Could you elaborate the recompile process after you deleted the wavemodel library please? Thank you. |
September 11, 2023, 07:23 |
#10 |
Manuel Fraga Seoane
Rep Power: 6 |
Hi Zhang,
Once I deleted the file, I just executed "wmake" command in ~/waves2Foam/applications/solvers/solvers2206_PLUS/my_new_solver/ I followed the instructions given in the waves2Foam manual. I don't know if I have already solve your doubt... Kind regards, Manuel |
dictionary, syntax, waveisofoam, waves2foam |
Unknown function type pressureTools | Dorian1504 | OpenFOAM Post-Processing | 23 | May 25, 2021 10:24 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
FoamX error aachenBomb case | Ervin Adorean (Adorean) | OpenFOAM Pre-Processing | 13 | March 7, 2005 04:50 |
