[swak4Foam] swakExpression not writing to log
Old   March 13, 2020, 05:53
Default swakExpression not writing to log
Alex Fells
alexfells is on a distinguished road
I have written a functionObject using a swakExpression to calculate the total volume of a phase in an interFoam simulation by multiplying the local volume coefficient alpha by the cell volume. I have produced it using the damBreak tutorial and then copied the functionObject to another simulation. Unfortunately, when running interFOAM -postProcess in the new simulation, the functionObject is not writing for timesteps other than the initial one.
I am running openFOAM 4.1.0 and swakVersion 0.4.2. My controlDict for the case that is not running correctly is included below.
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     interFoam;
startFrom       latestTime; //startTime;
startTime       0;
stopAt          endTime;//writeNow;
endTime         60;
deltaT          1e-04;
writeControl    adjustableRunTime;
writeInterval   0.1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           1;
maxAlphaCo 	    1;
maxDeltaT 0.01;
minDeltaT 1e-15;
compute ALH  no;
writeOnCrash no;
libs
	"libsprghInterfaceTotalPressurePatchField.so"
	"libOpenFOAM.so"
	"libsimpleSwakFunctionObjects.so"
	"libswakFunctionObjects.so"
	"libgroovyBC.so"
functions
	dP
		type			probes;
		functionObjectLibs	("libsampling.so");
		enabled			true;
		writeControl		writeTime;
		fields			(p);
		probeLocations
		(0 0 0)
		(0 0 1.137)
	columnHoldUp
		type		swakExpression;
		valueType	internalField;
		verbose		true;
		outputControlMode timeStep;
		outputInterval	1;
		writeStartTime	no;
		aliases
			alpha alpha.HNO3;
		expression	"vol() * alpha";
		accumulations (
			sum
The following is the taken from my log file after running interFoam -postProcess. If you look you can see that swak4Foam sets the default mesh. I have also found that if I enable writeStartTime then the total volume fraction is written at this point. However, after the "MRF models present" line, there is no mention of swak. I have tried changing the outputControlMode to outputTime, deltaT, timeStep etc. with no luck.
|  \\    /   O peration     | Version:  4.1                                   |
Build  : 4.1
Exec   : interFoam -postProcess
Date   : Mar 13 2020
Time   : 09:39:31
Host   : "login2.arc3.leeds.ac.uk"
PID    : 162027
Case   : /nobackup/pm11af/VOF_001
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: max iterations = 10
    field "(U|p_rgh)"   : relTol 0, tolerance 0.001
    field "(flm|fmm)"   : relTol 0, tolerance 0.0001
swak4Foam: Setting default mesh
Time = 0
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type LES
Selecting LES turbulence model dynamicLagrangian
Selecting LES delta type cubeRootVol
dynamicLagrangianCoeffs
    filter          simple;
    ce              1.048;
    theta           3;
    Ce              1.048;
Reading g
Reading hRef
Calculating field g.h
No MRF models present
Time = 0.1
Reading field p_rgh
Reading field U
    filter          simple;
    ce              1.048;
    theta           3;
    Ce              1.048;
Reading g
Reading hRef
Below is the controlDict from the damBreak tutorial where the functionObject works fine.
|  \\    /   O peration     | Version:  4.x                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         1;
deltaT          0.001;
writeInterval   0.1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
adjustTimeStep  yes;
maxCo           1;
maxAlphaCo      1;
maxDeltaT       1;
libs
	"libOpenFOAM.so"
	"libgroovyBC.so"
functions
	dP
		type			probes;
		enabled			true;
		fields			(p);
		probeLocations
		(0.292 0.292 0)
		(0.292 0.292 0.0146)
	columnHoldUp
		verbose		true;
		outputInterval	1;
		writeStartTime	no;
		aliases
			alpha alpha.water;
		accumulations (
			sum
Finally, I have also included the log file from the damBreak tutorial showing the functionObject calculating volumefraction.
Build  : 4.1
Date   : Mar 13 2020
Time   : 09:51:53
PID    : 132270
Case   : /nobackup/pm11af/functionObjectSandbox
nProcs : 1
Create time
PIMPLE: Operating solver in PISO mode
Time = 0
Reading field p_rgh
Reading field U
Selecting turbulence model type laminar
Reading g
Reading hRef
Expression columnHoldUp : swak4Foam: Allocating new repository for sampledMeshes
swak4Foam: Allocating new repository for sampledGlobalVariables
 sum=0.000646099
Time = 0.1
Reading field p_rgh
Reading field U
Reading g
Reading hRef
Expression columnHoldUp :  sum=0.000646099
Time = 0.2
Reading field p_rgh
Reading field U
Reading g
Reading hRef
Time = 0.3
Reading field p_rgh
Reading field U
Reading g
Reading hRef
Expression columnHoldUp :  sum=0.000646098
Time = 0.4
Reading field p_rgh
Reading field U
Reading g
Reading hRef
Expression columnHoldUp :  sum=0.000640313
Time = 0.5
Reading field p_rgh
Reading field U
Reading g
Reading hRef
Expression columnHoldUp :  sum=0.00063341
Time = 0.6
Reading field p_rgh
Reading field U
Reading g
Reading hRef
Expression columnHoldUp :  sum=0.000632398
Time = 0.7
Reading field p_rgh
Reading field U
Reading g
Reading hRef
Time = 0.8
Reading field p_rgh
Reading field U
Reading g
Reading hRef
Expression columnHoldUp :  sum=0.000632397
Time = 0.9
Reading field p_rgh
Reading field U
Reading g
Reading hRef
Time = 1
Reading field p_rgh
Reading field U
Reading g
Reading hRef
End
Hopefully this is enough information, please let me know if you need any more info from me.
Thanks,
Alex
alexfells is offline   Reply With Quote
Old   March 15, 2020, 18:00
Assistant Moderator
Bernhard Gschaider
To be honest: I haven't tested these things with the -postProcess option. I usually use funkyDoCalc when I want to evaluate some expressions after the run. So it is possible that this is just not working
I'll have a look whether this can be fixed. But don't hold your breath. The relevant code is a bit fragile because it has to accommodate 3 different OF-branches (OF-Foundation, OF-ESI, Foam-extend) with slightly different behaviour and API of the functionObjects (which is because the functionObjects were rewritten at least 3 times and different distros stayed at different version)
BTW: Please use CODE (that is the icon with the # in the edit toolbar) for your examples.
CODE is readable:
test {
    type test;
while quote is a "flat" unreadable mess
test {
type test;
Thanks
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 16, 2020, 15:57
Alex Fells
Hi, thanks for the reply. I've updated to post to use QUOTE and will have a look at funkyDoCalc.
If I get round to it I'll have a go at incrementally changing my controlDict and try and identify what causes it to break and will post here incase it's useful.
Thanks,
Alex
Old   March 16, 2020, 19:19
Assistant Moderator
Bernhard Gschaider
Thanks
Alex
CODE! Not QUOTE
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
