[swak4Foam] Setting field with a zone() condition using OpenFOAM V1912 setExprField |
January 5, 2020, 21:38 |
Jeff
Rep Power: 8 |
Does the new OpenFOAM V1912 utility setExprFields allow for the condition of zone() to be used as is available for funkySetFields?
I did not see it as an option in https://www.openfoam.com/documentati...xprFields.html but I wouldn't be surprised if it is there and I've missed it. I have a multi-region model defined by several cellZones. I'd like to set initial field values for each zone. I have unresolved installation issues with installing swak4Foam with all versions of OpenFOAM (separate threads). I have successfully installed OpenFOAM V1912 and it would be terrific if I could accomplish the same field initialization with the setExprFields utility and forget about attempting to install swak4Foam. Thanks, Jeff |
cellzones, funkysetfields, openfoam v1912, setexprfields, swak4foam |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 08:30 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 02:47 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 06:40 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 13:25 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
