#1 | |
Kmeti Rao
Rep Power: 8 ![]() |
Hi dear Foamers,
So far I have used cfMesh, with .stl files, and everything worked well, thanks to the guidance and tutorials in the forum. On the verge of improvement, I have started using Salome and so far It ran smooth. Now, I would like to visualize the .fms, obtained through Salome. For this I have used, FMSToVTK input.fms output.vtk, this generated a .vtm file (output.vtk.vtm) as mentioned in the cfMesh user guide. When I tried to access this .vtm file through paraview, I am getting the following error Quote:
Krao |
Deutschland
Rep Power: 0 ![]() |
Hi Krao,
could you solve the Problem? I am sticking at the same point. Best Jan |
.fms, cfmesh, mesh, salome 9.3 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
