[Other] varRhoTurbVOF: a new set of VOF solvers for turbulent isothermal multiphase flows |
September 11, 2019, 06:25 |
Wenyuan Fan
Rep Power: 9 |
Hi all,
Our work is based on the fact that, under the VOF framework, the flow of the isothermal mixture belongs to the variable-density incompressible flow category. For such flows, VOF-based solvers of OpenFOAM fail to construct the correct governing equations for turbulence modeling. varRhoTurbVOF contains a set of newly designed VOF-based solvers which could use the desired governing equations for turbulence quantities. The paper which explains the issue and solution in detail is available at https://doi.org/10.1016/j.cpc.2019.106876 and https://arxiv.org/abs/1811.12580v2 Implementations for various OpenFOAM versions are provided at https://github.com/wenyuan-fan/varRhoTurbVOF I have already reported this to both ESI Group and OpenFOAM Foundation, details and updates could be found at https://develop.openfoam.com/Develop...us/issues/1433 and https://bugs.openfoam.org/view.php?id=3344 I hope the community could test the new solvers on a wide range of cases and give feedback. Best regards, Wenyuan |
interfoam, interisofoam, turbulence modeling, vof |
does Hyperthreading affect the application of UDF? | SJSW | Fluent UDF and Scheme Programming | 11 | October 10, 2018 23:28 |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 12:52 |
Difference of multicomponent and multiphase homogenous flows | Luk_Fiz | CFX | 11 | April 4, 2013 06:29 |
Free surface flows and multiphase flows | Vidar | Main CFD Forum | 0 | September 18, 2008 06:05 |
Multiphase and FreeSurface Flows at OpenFOAM Workshop Milan 2008 | egp | OpenFOAM | 0 | March 20, 2008 07:34 |
