[cfMesh] Interpreting console output during meshing |
August 16, 2019, 04:13 |
Rep Power: 8 |
Hello everyone
cfMesh is quite fast. But still, large meshes (>20M) still take more time than i'm willing to stare on the screen. This is especially noticable when trying to mesh a complex geometry and the meshing fails over and over. If I could know during the meshing process that its not going well and will result in a bad mesh, i don't have to wait till the end. Unfortunately I couldn't find any information regarding the console output of cfMesh and maybe some opinions from experience. Important thins to know would be something like:
Informations like this would be nice to see in the user guide: http://cfmesh.com/wp-content/uploads...VS8R8D5NTStPFF Any information is appreciated and of value for all cfMesh users. Regards, nope |
August 16, 2019, 20:59 |
Raul Ciria Aylagas
Rep Power: 8 |
From my experience, if you have FOAM serious error, or a big number of inverted faces (>10.000) you will have a very bad mesh.
If the number of inverted faces is not going to zero but is not very big, you can work with that. You can stop the meshing proccess after the edgeExtraction step to inspect the mesh and see if it is going well or if it has serious defects. With that you can skip smoothing procedure and save some time. |
cfmesh, console, experience, output |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
Extracting the output from the FLUENT console window | kesari | Fluent UDF and Scheme Programming | 0 | February 21, 2014 05:37 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 06:16 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
