[cfMesh] Fatal error when parallel running with mpi |
August 2, 2019, 18:29 |
Junting Chen
Rep Power: 10 |
Hello all, I have made sure the test cases can run in serial cartesianMesh.
I keeps getting "segmentation fault" when I ran them again with mpi: mpirun -np 32 cartesianMesh -parallel The fault usually comes very randomly: ... Total number of cells 693956 Finished extracting polyMesh Checking for irregular surface connections Checking cells connected to surface vertices Found 40289 boundary faces Found 0 problematic vertices Finished checking cells connected to surface vertices Checking for non-manifold surface edges -------------------------------------------------------------------------- A process has executed an operation involving a call to the "fork()" system call to create a child process. Open MPI is currently operating in a condition that could result in memory corruption or other system errors; your job may hang, crash, or produce silent data corruption. The use of fork() (or system() or other calls that create child processes) is strongly discouraged. The process that invoked fork was: Local host: [[17085,1],27] (PID 18387) If you are *absolutely sure* that your application will successfully and correctly survive a call to fork(), you may disable this warning by setting the mpi_warn_on_fork MCA parameter to 0. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 27 with PID 18387 on node nnode9 exited on signal 11 (Segmentation fault). -------------------------------------------------------------------------- I looked some threads but no one really reported this issue seems like. Thanks Junting |
August 5, 2019, 04:55 |
Kmeti Rao
Rep Power: 8 |
Hi Junting Chen,
I hope the following link would help you to run your case in parallel. How to run CfMesh in parallel? |
August 5, 2019, 09:06 |
Junting Chen
Rep Power: 10 |
Hello Krao,
I am able to run it on one pc with OpenMP. The issue is MPI. Thanks, Junting |
August 5, 2019, 10:33 |
Kmeti Rao
Rep Power: 8 |
Did you run preparePar? before running cartesianMesh in parallel
Krao |
August 5, 2019, 12:46 |
Junting Chen
Rep Power: 10 |
yes I did. I ran preparePar so I got 32 files.
Junting |
August 5, 2019, 13:29 |
Junting Chen
Rep Power: 10 |
So my workflow is :
1. put aaa.stl in the folder 2. run 'surfaceGenerateBoundingBox aaa.stl aaa_boundingbox.stl xMin xMax yMin yMax zMin zMax 3. run 'surfaceFeatureEdges aaa_boundingbox.stl aaa_FeatureEdges.fms -angle 5' 4. run 'surfaceFeatureEdges aaa_boundingbox.stl aaa_FeatureEdges.vtk -angle 5' 5. write systme/meshDict: - surfaceFile "aaa_FeatureEdges.fms; - edgeFile "aaa_FeatureEdges.vtk"; 6. write decomposeParDict: - numberOfSubdomains 32; 7. run 'preparePar' 8. run 'mpirun -np 32 cartesianMesh -parallel > 01.cfMesh.log' output log says following at the end: Extracting edges Starting topological adjustment of patches No topological adjustment was needed Starting geometrical adjustment of patches Found 8 corners at the surface of the volume mesh Found 649 edge points at the surface of the volume mesh 12 edge groups found! --> FOAM Warning : From function void edgeExtractor::extractEdges() in file utilities/surfaceTools/edgeExtraction/edgeExtractor/edgeExtractor.C at line 2115 Found 0 points with inverted surface normals. Getting rid of them... Starting untangling the surface of the volume mesh Number of inverted boundary faces is 14 [nnode7:23282] *** An error occurred in MPI_Recv [nnode7:23282] *** reported by process [1091829761,12] [nnode7:23282] *** on communicator MPI_COMM_WORLD [nnode7:23282] *** MPI_ERR_TRUNCATE: message truncated [nnode7:23282] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, [nnode7:23282] *** and potentially your MPI job) Thanks a lot for your patience! Junting Chen |
August 6, 2019, 04:10 |
Kmeti Rao
Rep Power: 8 |
Hi Junting Chen,
I have followed something like what you mentioned and was able to run the case with the following steps, can you try it out once. 1. put aaa.stl in the folder 2. run 'surfaceGenerateBoundingBox aaa.stl aaa_boundingbox.stl xMin xMax yMin yMax zMin zMax 3. run 'surfaceFeatureEdges aaa_boundingbox.stl aaa_FeatureEdges.fms -angle 5' 4. run 'FMSToSurface -exportFeatureEdges aaa_FeatureEdges.fms new_aaa_FeatureEdges.fms' The 4th step mentioned above will generate a .vtk file along with new .fms file. Write this .vtk file under edge refinement of system/meshDict 5. write systme/meshDict: under edge refinement -outputof4thstep.vtk 6. write decomposeParDict: - numberOfSubdomains 32; 7. run 'preparePar' 8. run 'mpirun -n 32 cartesianMesh -parallel > 01.cfMesh.log' This workflow, which I followed on OpenFOAM6 and got no errors, please let me know if you have any issues with the above steps. Krao |
"Failed Starting Thread 0" | ebringley | OpenFOAM Running, Solving & CFD | 2 | April 26, 2019 06:45 |
The problem when i use parallel computation for mesh deforming. | Hiroaki Sumikawa | OpenFOAM Running, Solving & CFD | 0 | November 20, 2018 03:58 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
Problem running in parralel | Val | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 03:47 |
Issue with running in parallel on multiple nodes | daveatstyacht | OpenFOAM | 7 | August 31, 2010 18:16 |
