[swak4Foam] GroovyBC - issue with non-uniform inlet
Old   July 3, 2019, 07:15
Default GroovyBC - issue with non-uniform inlet
Sina
Sina.Li is on a distinguished road
I am new to GroovyBC but will try to explain the issue. I have built the last version of GroovyBC on openfoam 5. Now trying to apply a non-uniform velocity as an inlet boundary condition to a jet fan suspending in the air (solver: simpleFoam). This is the BC I set:
     fanOutlet
        type                groovyBC;
        variables "Uavg=-7;yp=pts().y;xp=pts().x;minY=min(yp);maxY=max(yp);minX=min(xp);maxX=max(xp);ctrX=0.5*(min(xp)+max(xp));ctrY=0.5*(min(yp)+max(yp));";
        valueExpression "(Uavg/0.64)*(1-pow((pos().x-ctrX)/ctrX,4)*(1-pow((pos().y-ctrY)/ctrY,4)*normal()";
        value           uniform (0 0 -7);
and when trying to run, I get the following message and the run before starting ends:
swak4Foam: Allocating new repository for sampledGlobalVariables
tried to debug: When changing the expression to a constant it works. when changing pts() to pos() (to check if it is compilation problem) then it would start the run, but from the beginning it diverges.
PS: just attached the screenshot when running with uniform fixed velocity.
Sina.Li is offline   Reply With Quote
groovybc, non-uniform bc, openfoam, swak4foam
Pipeflow with interFoam, kOmegaSST floating point error by initial condition? silencebreak OpenFOAM Running, Solving & CFD 4 July 2, 2017 10:56
Circulating Tank - Unphysical results shootthemoon OpenFOAM Running, Solving & CFD 1 May 16, 2017 06:11
[swak4Foam] Trouble setting groovyBC interFoam Inlet BC mgdenno OpenFOAM Community Contributions 4 July 1, 2012 09:16
chtMultiRegionSimpleFoam javad814 OpenFOAM 1 September 26, 2011 14:30
Problems with Turbulence Modeling ezsoal OpenFOAM Running, Solving & CFD 4 November 26, 2009 16:12
