[PyFoam] Unable to properly construct the sqlite database
Old   June 8, 2019, 10:51
Question Unable to properly construct the sqlite database
Elwardi Fadeli
ELwardi is on a distinguished road
I have a custom solver working on a certain Swp (vector2Field in extend-4.0).
When I try to run a parameter variation with PyFoam, it says "table analyzedData has no column named _linear//_swp".
I have tried suppressing solver performance output with no success. Here is the full error
Traceback (most recent call last):
  File "/opt/foam/foam-extend-4.0/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/bin/pyFoamRunParameterVariation.py", line 5, in <module>
    RunParameterVariation()
  File "/opt/foam/foam-extend-4.0/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Applications/RunParameterVariation.py", line 73, in __init__
    **kwargs)
  File "/opt/foam/foam-extend-4.0/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Applications/PrepareCase.py", line 89, in __init__
    **kwargs)
  File "/opt/foam/foam-extend-4.0/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Applications/PyFoamApplication.py", line 356, in __init__
    result=self.run()
  File "/opt/foam/foam-extend-4.0/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Applications/RunParameterVariation.py", line 375, in run
    db.add(run.data)
  File "/opt/foam/foam-extend-4.0/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Basics/RunDatabase.py", line 65, in add
    [("runId",runID)]))
  File "/opt/foam/foam-extend-4.0/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Basics/RunDatabase.py", line 132, in __addContent
    raise e
sqlite3.OperationalError: table analyzedData has no column named _linear//_swp
Any one knows how to fix this?
ELwardi is offline   Reply With Quote
pyfoam
How to make a code parallel? Bruno Machado Fluent UDF and Scheme Programming 15 May 27, 2016 10:18
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 12:03
GAMBIT Error Msg database file not properly closed Janomano ANSYS Meshing & Geometry 8 November 23, 2010 05:14
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 16:45
WARNING: Unable to compact database Reena CFX 0 June 23, 2006 13:00
